Home » Language IDEs » C / C++ IDE (CDT) » Can't start debug:No symbol "auto" in current context.
Can't start debug:No symbol "auto" in current context. [message #65222] Wed, 26 March 2003 01:47 Go to next message
I can't start debug for my Windows C++ app. Normal run from Eclipse is OK.
Compile is OK.
cdtdebugger shows this message: No symbol "auto" in current context.
CDT 1.0.1 (last night build downloaded 03/25/2003 and 1.0.1 stable version)
I use gdb 5.2.1-2 (got it 03/25/2003)
Same with gdb from MigGW install (gdb v.5.1.1)
MigGW ver. 2.0.0.3
I compile my sources with -g flag
What's wrong?
Eclipse log:
!ENTRY org.eclipse.debug.ui 4 120 Р?Р?С? 25, 2003 17:37:05.750
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException[150]:
org.eclipse.cdt.debug.mi.core.cdi.MI2CDIException: No symbol "auto" in
current context.
org.eclipse.cdt.debug.mi.core.cdi.SharedLibraryManager.setAu toLoadSymbols(SharedLibraryManager.java:147)
org.eclipse.cdt.debug.mi.core.GDBDebugger.initializeLibrarie s(GDBDebugger.java:30)
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.java:48)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:86)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:136)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog$10.run(LaunchConfigurationDialog.java:2299)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
!ENTRY org.eclipse.cdt.launch 4 150 Р?Р?С? 25, 2003 17:37:05.750
!MESSAGE Failed Launching CDI Debugger : No symbol "auto" in current
context.
!STACK 0
current context.
Re: Can't start debug:No symbol "auto" in current context. [message #65266 is a reply to message #65222] Wed, 26 March 2003 10:19 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Select the "Cygwin GDB Debugger" option in the "Debugger" tab of the launch
configuration.
"Alexander Ilyin" <a_ilyin@yahoo.com> wrote in message
news:b5rht8$19j$1@rogue.oti.com...
> Compile is OK.
version)
> MigGW ver. 2.0.0.3
> What's wrong?
> Eclipse log:
Re: Can't start debug:No symbol "auto" in current context. [message #65396 is a reply to message #65266] Thu, 27 March 2003 13:43 Go to previous message
Thank you.
It really helps.
But it's strange thing, using MigGW gdb setting Cygwin...
May be magic word Cygwin means Windows environment???
Anyway this works fine.
> launch configuration.
>> OK. Compile is OK.
> version)
>> MigGW ver. 2.0.0.3
>> What's wrong?
Previous Topic:Code Templates
Next Topic:compilation tools
Current Time: Sun Nov 23 02:30:01 EST 2025
Powered by FUDForum. Page generated in 0.04715 seconds
