Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Setting Id generator from ecore file
[Teneo] Setting Id generator from ecore file [message #65217] Wed, 20 December 2006 18:08 Go to next message
Originally posted by: g.idema.zonnet.nl
Before I switched to the latest Teneo build, I used the following annotation
on my ID attributes to set the generator in the hibernate mapping:
<eAnnotations source="http://hibernate.elver.org/GeneratedValue">
<details key="strategy" value="AUTO"/>
</eAnnotations>
In the latest build, I don't get the <generator> element in the hibenate
mapping anymore.
Any suggestions as for what I'm doing wrong?
Gertjan Idema
Re: [Teneo] Setting Id generator from ecore file [message #65259 is a reply to message #65217] Wed, 20 December 2006 23:36 Go to previous messageGo to next message
The source of the annotation changed a few months ago:
http://www.elver.org/hibernate/ejb3_format.html
gr. Martin
> </eAnnotations>
> mapping anymore.
> Gertjan Idema
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Setting Id generator from ecore file [message #65362 is a reply to message #65259] Thu, 21 December 2006 10:14 Go to previous messageGo to next message
Hi Martin,
Thanks. I changed the annotation to the following and it work as expected:
<eAnnotations source="teneo.jpa/Id">
<details key="appinfo" value="@GeneratedValue(strategy=&quot;AUTO&quot;)"/ >
</eAnnotations>
However if I attach this annotation to an EDataType and use this for the id
attributes in all of my classes, this only work for the first class in the
package. For example, if I have two classes Foo, Bar in my package, both
with an id attribute of EDataType ID, where ID is annotated as shown above.
Then when I create the hibernate mapping, only class Foo gets the <generator
class="native"/> element.
Switching the order of the classes in the package to Bar, Foo results in
only class Bar having the <generator class="native"/> element instead.
I decided to dig into this issue and found the following:
The GeneratedValue attribute is contained in the HbAnnotatedEDataType Class,
as are the other annotation attributes.
Therefore the first call to "pea.eSet(asf, ped.eGet(esf));" in the
PersistenceMappingBuilder removes the value from the HbAnnotatedEDataType
instance, preventing it from being copied the next time.
I suggest the following fix:
replace "pea.eSet(asf, ped.eGet(esf));" with "pea.eSet(asf,
EcoreUtil.copy(ped.eGet(esf)));"
Gertjan Idema
"Martin Taal" <mtaal@elver.org> wrote in message
news:emd30s$fk9$1@utils.eclipse.org...
> gr. Martin
>> annotation on my ID attributes to set the generator in the hibernate
>> mapping:
>> </eAnnotations>
>> mapping anymore.
>> Gertjan Idema
> The Netherlands
Re: [Teneo] Setting Id generator from ecore file [message #65405 is a reply to message #65362] Thu, 21 December 2006 10:47 Go to previous message
Thanks GertJan for researching the cause of this.
I committed a solution similar to your proposal.
gr. Martin
> Hi Martin,
> </eAnnotations>
> Gertjan Idema
>> gr. Martin
>>> mapping:
>>> </eAnnotations>
>>> mapping anymore.
>>> Gertjan Idema
>> The Netherlands
The Netherlands
Re: [Teneo] Setting Id generator from ecore file [message #597260 is a reply to message #65217] Wed, 20 December 2006 23:36 Go to previous message
gr. Martin
> </eAnnotations>
> mapping anymore.
> Gertjan Idema
The Netherlands
Re: [Teneo] Setting Id generator from ecore file [message #597312 is a reply to message #65259] Thu, 21 December 2006 10:14 Go to previous message
Hi Martin,
</eAnnotations>
Gertjan Idema
> gr. Martin
>> mapping:
>> </eAnnotations>
>> mapping anymore.
>> Gertjan Idema
> The Netherlands
Re: [Teneo] Setting Id generator from ecore file [message #600185 is a reply to message #65362] Thu, 21 December 2006 10:47 Go to previous message
gr. Martin
> Hi Martin,
> </eAnnotations>
> Gertjan Idema
>> gr. Martin
>>> mapping:
>>> </eAnnotations>
>>> mapping anymore.
>>> Gertjan Idema
>> The Netherlands
The Netherlands
Previous Topic:Teneo - I loose my EObject fields
Next Topic:teneo - Performance penalty for larger models in HibernateResource
Current Time: Sat Nov 08 22:51:13 EST 2025
Powered by FUDForum. Page generated in 0.05214 seconds
