Home » Archived » XML Schema Definition (XSD) » Schema Validation problem with Geronimo Schemas
| Schema Validation problem with Geronimo Schemas [message #65044] |
Tue, 29 November 2005 11:43  |
Originally posted by: brian.bonner.nospam.paraware.com
I've loaded up the SVN version of Geronimo, but I'm getting validation
errors on the schema. I've included the errors below. My instance
documents are also failing (I believe based on this). I saw this post:
http://www.eclipse.org/newsportal/article.php?id=1429&gr oup=eclipse.technology.xsd#1429
and thought it might be related as I was using SVN. However, I've
since disabled it, created a new workspace with the schemas from
Geronimo (latest SVN), but I'm still getting the errors.
I'm running:
Eclipse FTP and WebDAV Support 3.1.0
Eclipse Project SDK 3.1.1
Eclipse SDK Examples 3.1.1
EMF SDK 2.1.1
Graphical Editing Framework SDK 3.1.1
JST WST 0.70 (Disabled)
JST WST 0.71 (Disabled)
JST WST 1.0 (1.0M9)
Subclipse 0.9.34 (Disabled)
UML2 1.1.1
UML2 Docs 1.1.1
UML2 Ex 1.1.1
UML2 Source 1.1.1
Version Control with Subversion 1.1.1 (Disabled)
Visual Editor SDK 1.1.0.1
WST Feature SDK 1.0.0
Severity Description Resource In Folder Location Creation Time Id
2 s4s-elt-invalid-content.1: The content of 'descriptionType' is
invalid. Element 'attribute' is invalid, misplaced, or occurs too
often. geronimo-connector-1.0.xsd testschema/schema line 391 November
29, 2005 11:34:56 AM 1
2 src-resolve.4.2: Error resolving component 'xml:lang'. It was detected
that 'xml:lang' is in namespace 'http://www.w3.org/XML/1998/namespace',
but components from this namespace are not referenceable from schema
document
' file:///C:/workspace_test/testschema/schema/geronimo-connect or-1.0.xsd'.
If this is the incorrect namespace, perhaps the prefix of 'xml:lang'
needs to be changed. If this is the correct namespace, then an
appropriate 'import' tag should be added to
geronimo-connector-1.0.xsd testschema/schema line 391 November 29, 2005
11:34:56 AM 0
| Re: Schema Validation problem with Geronimo Schemas [message #65077 is a reply to message #65044] |
Tue, 29 November 2005 11:49   |
--------------040109050007040008040206
Brian,
These messages aren't coming from the XSD model. They look like they
are probably coming directly from Xerces. The most likely cause is
using xml:lang but forgetting to import the schema for the XML namespace.
<xs:import namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/xml.xsd"/>
> I'm running:
> EMF SDK 2.1.1
> JST WST 1.0 (1.0M9)
> UML2 1.1.1
> UML2 Docs 1.1.1
> UML2 Ex 1.1.1
> UML2 Source 1.1.1
> Creation Time Id
> 391 November 29, 2005 11:34:56 AM 1
> detected that 'xml:lang' is in namespace
> 'http://www.w3.org/XML/1998/namespace', but components from this
> namespace are not referenceable from schema document
> November 29, 2005 11:34:56 AM 0
<html>
<head>
</head>
Brian,<br>
<br>
using <a class="moz-txt-link-freetext" href="xml:lang">xml:lang</a> but forgetting to import the schema for the XML
namespace.<br>
<blockquote><xs:import
namespace=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/XML/1998/namespace">"http://www.w3.org/XML/1998/namespace"</a>
schemaLocation=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/xml.xsd">"http://www.w3.org/2001/xml.xsd"</a>/><br>
</blockquote>
<br>
Brian Bonner wrote:
<blockquote cite="middmi0g7$e36$1@news.eclipse.org" type="cite">I've
<br>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/newsportal/article.php?id=1429&gr oup=eclipse.technology.xsd#1429"> http://www.eclipse.org/newsportal/article.php?id=1429&am p;group=eclipse.technology.xsd#1429</a>
<br>
<br>
I'm running:
<br>
<br>
<br>
<br>
EMF SDK 2.1.1
<br>
<br>
<br>
<br>
JST WST 1.0 (1.0M9)
<br>
<br>
UML2 1.1.1
<br>
UML2 Docs 1.1.1
<br>
UML2 Ex 1.1.1
<br>
UML2 Source 1.1.1
<br>
<br>
<br>
<br>
<br>
Creation Time Id
<br>
<br>
2 src-resolve.4.2: Error resolving component '<a class="moz-txt-link-freetext" href="xml:lang">xml:lang</a>'. It was
detected that '<a class="moz-txt-link-freetext" href="xml:lang">xml:lang</a>' is in namespace
'<a class="moz-txt-link-freetext" href="http://www.w3.org/XML/1998/namespace">http://www.w3.org/XML/1998/namespace</a>', but components from this
'<a class="moz-txt-link-freetext" href=" file:///C:/workspace_test/testschema/schema/geronimo-connect or-1.0.xsd"> file:///C:/workspace_test/testschema/schema/geronimo-connect or-1.0.xsd</a>'.
If this is the incorrect namespace, perhaps the prefix of '<a class="moz-txt-link-freetext" href="xml:lang">xml:lang</a>'
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------040109050007040008040206--
| Re: Schema Validation problem with Geronimo Schemas [message #65147 is a reply to message #65077] |
Tue, 29 November 2005 15:11   |
Ed, thanks. I added it, revalidated and all is well with the world again :)
Brian
Ed Merks wrote:
> Brian,
>> I'm running:
>> EMF SDK 2.1.1
>> JST WST 1.0 (1.0M9)
>> UML2 1.1.1
>> UML2 Docs 1.1.1
>> UML2 Ex 1.1.1
>> UML2 Source 1.1.1
>> Creation Time Id
| Re: Schema Validation problem with Geronimo Schemas [message #65169 is a reply to message #65147] |
Tue, 29 November 2005 16:02  |
Ed,
I tried changing the schemaLocation to the local one used by Geronimo
and was getting failures. I pulled them down and at first blush they
were the same, but doing a compare, I realized there was a slight
difference between the two. After replacing the local xml.xsd with the
one from the web, this now works. Woot!
schemaLocation="xml.xsd"/>
Thanks again.
When I was using the local document (before the download) I was getting
this error msg:
1 schema_reference.4: Failed to read schema document
'file:///C:/workspace_paraware/testschema/schema/xml.xsd', because 1)
could not find the document; 2) the document could not be read; 3) the
root element of the document is not <xsd:schema>.
geronimo-security-1.1.xsd testschema/schema line 30 November 29, 2005
3:55:27 PM 2916
Brian
> again :)
> Brian
> Ed Merks wrote:
>> Brian,
>>> validation errors on the schema. I've included the errors below. My
>>> instance documents are also failing (I believe based on this). I saw
>>> this post:
>>> I'm running:
>>> EMF SDK 2.1.1
>>> JST WST 1.0 (1.0M9)
>>> UML2 1.1.1
>>> UML2 Docs 1.1.1
>>> UML2 Ex 1.1.1
>>> UML2 Source 1.1.1
>>> Creation Time Id
| Re: Schema Validation problem with Geronimo Schemas [message #597225 is a reply to message #65044] |
Brian,
> I'm running:
> EMF SDK 2.1.1
> JST WST 1.0 (1.0M9)
> UML2 1.1.1
> UML2 Docs 1.1.1
> UML2 Ex 1.1.1
> UML2 Source 1.1.1
> Creation Time Id
<html>
<head>
</head>
Brian,<br>
<br>
namespace.<br>
</blockquote>
<br>
<br>
<br>
<br>
I'm running:
<br>
<br>
<br>
<br>
EMF SDK 2.1.1
<br>
<br>
<br>
<br>
JST WST 1.0 (1.0M9)
<br>
<br>
UML2 1.1.1
<br>
UML2 Docs 1.1.1
<br>
UML2 Ex 1.1.1
<br>
UML2 Source 1.1.1
<br>
<br>
<br>
<br>
<br>
Creation Time Id
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
| Re: Schema Validation problem with Geronimo Schemas [message #597258 is a reply to message #65077] |
Brian
Ed Merks wrote:
> Brian,
>> I'm running:
>> EMF SDK 2.1.1
>> JST WST 1.0 (1.0M9)
>> UML2 1.1.1
>> UML2 Docs 1.1.1
>> UML2 Ex 1.1.1
>> UML2 Source 1.1.1
>> Creation Time Id
| Re: Schema Validation problem with Geronimo Schemas [message #597263 is a reply to message #65147] |
Ed,
Thanks again.
this error msg:
3:55:27 PM 2916
Brian
> again :)
> Brian
> Ed Merks wrote:
>> Brian,
>>> this post:
>>> I'm running:
>>> EMF SDK 2.1.1
>>> JST WST 1.0 (1.0M9)
>>> UML2 1.1.1
>>> UML2 Docs 1.1.1
>>> UML2 Ex 1.1.1
>>> UML2 Source 1.1.1
>>> Creation Time Id
Current Time: Wed Nov 05 15:37:09 EST 2025
Powered by FUDForum. Page generated in 0.04799 seconds
