| Home » Eclipse Projects » Nebula » Questions on Nebula Grid
 Goto Forum:|
| Questions on Nebula Grid [message #64956] | Mon, 22 June 2009 08:27  |  |
| Eclipse User  |  |  |  |  | Originally posted by: m.kasid.gmail.com
 I have some queries on Grid:
 1. Is it possible to change the color of cells in Row headers? How ?
 2. Is it possible to change the width of Row headers or make the row header
 resizable?
 Mustufa
| Re: Questions on Nebula Grid [message #64991 is a reply to message #64980] | Fri, 26 June 2009 00:58   |  |
 Thanks.
 I think grid.getColumn(0).setHeaderRenderer(customHeaderRenderer); will be
 useful for having custom column headers, I want to know how can i modify the
 Row headers. Also, I just want to have a facility of changing the color of
 Row headers, so can i extend some class for this and provide colors that i
 need?
 Mustufa
 "Stanislav Vodetskyi" <blutkind99@gmail.com> wrote in message
 news:3f17500f00271a8c32c3f270d53966a7$1@www.eclipse.org...
 > Mustufa Kasidwala wrote:
 >> header resizable?
 > 1. It is possible to set your own custom header renderer and draw anything
 > you need in the header cell:
 > There may be a possibility to use a label provider for this, but I don't
 > know for sure, if it exists.
 > 2. Width of row headers is definitely adjustable, but I'm not sure of the
 > API to do that, sorry.
 > Stanislav
| Re: Questions on Nebula Grid [message #65000 is a reply to message #64991] | Fri, 26 June 2009 03:35   |  |
| Eclipse User  |  |  |  |  | Hi,
 The method to set the width of the row header is called
 Grid#setItemHeaderWidth. We currently miss the implementation to the set
 the background/foreground color for the row-header but this should be
 easy to implement.
 So if you need this feature please file a bug and if possible create a
 patch I can integrate into the code base. This way the feature will be
 available to whole Grid community.
 Tom
 Mustufa Kasidwala schrieb:
 > Thanks.
 > need?
 > Mustufa
 >>> Hi,
 >>> header resizable?
 >> Regards,
 >> Stanislav
| Re: Questions on Nebula Grid [message #65040 is a reply to message #65000] | Fri, 26 June 2009 06:31   |  |
 Thanks Tom,
 I downloaded the code from CVS and i can see the method 'setItemHeaderWidth'
 added in Grid.java. It wasn't visible in the binary that i was using. I may
 be using an old one.
 For setting background/foreground colors in row headers, i tried it out and
 was able to set it by making some changes in GridItem and
 DefaultRowHeaderRenderer.
 How to raise a bug for this? and how can i contribute? can I send/post the
 code and you can update it?
 Mustufa
 "Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
 news:h21tnl$2kq$1@build.eclipse.org...
 > easy to implement.
 > Tom
 >> Thanks.
 >> be
 >> the
 >> of
 >> i
 >> need?
 >> Thanks,
 >> Mustufa
 >>>> Hi,
 >>>> header resizable?
 >>> Hi,
 >>> anything
 >>> the
 >>> Regards,
 >>> Stanislav
| Re: Questions on Nebula Grid [message #65050 is a reply to message #65040] | Fri, 26 June 2009 06:35   |  |
 Please file a bug against Nebula > Grid through
 https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Nebula and attach a
 patch which you can create within eclipse.
 Please cc me on the bug and post the bug id here.
 Tom
 > Thanks Tom,
 > Mustufa
 >> easy to implement.
 >> Tom
 >>> Thanks.
 >>> be
 >>> the
 >>> of
 >>> i
 >>> need?
 >>> Thanks,
 >>> Mustufa
 >>>>> Hi,
 >>>>> header resizable?
 >>>> Hi,
 >>>> anything
 >>>> the
 >>>> Regards,
 >>>> Stanislav
| Re: Questions on Nebula Grid [message #65066 is a reply to message #65050] | Fri, 26 June 2009 06:46   |  |
 "attach a patch which you can create within eclipse."
 can you explain what steps i need to do for this? i made changes in two
 files, should i attach these two files?
 Sorry if this sounds like a stupid question...
 Mustufa
 news:h2288o$91a$1@build.eclipse.org...
 > Tom
 >> Thanks Tom,
 >> may
 >> and
 >> the
 >> Thanks,
 >> Mustufa
 >>> Hi,
 >>> easy to implement.
 >>> Tom
 >>>> Thanks.
 >>>> be
 >>>> modify
 >>>> the
 >>>> of
 >>>> that
 >>>> i
 >>>> need?
 >>>> Thanks,
 >>>> Mustufa
 >>>>>> Hi,
 >>>>>> header resizable?
 >>>>> Hi,
 >>>>> anything
 >>>>> don't
 >>>>> the
 >>>>> Regards,
 >>>>> Stanislav
| Re: Questions on Nebula Grid [message #65091 is a reply to message #65066] | Fri, 26 June 2009 06:58   |  |
| Eclipse User  |  |  |  |  | 1. Right Click on the project 2. Team > Create Patch
 3. Save to file system
 4. Attach to bug
 > Mustufa
 >> Tom
 >>> Thanks Tom,
 >>> may
 >>> and
 >>> the
 >>> Thanks,
 >>> Mustufa
 >>>> Hi,
 >>>> easy to implement.
 >>>> Tom
 >>>>> Thanks.
 >>>>> be
 >>>>> modify
 >>>>> the
 >>>>> of
 >>>>> that
 >>>>> i
 >>>>> need?
 >>>>> Thanks,
 >>>>> Mustufa
 >>>>>>> Hi,
 >>>>>>> header resizable?
 >>>>>> Hi,
 >>>>>> anything
 >>>>>> don't
 >>>>>> the
 >>>>>> Regards,
 >>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65113 is a reply to message #65091] | Fri, 26 June 2009 07:17   |  |
 Bug 281644 submitted for this and a patch is attached.
 Mustufa
 news:h229l8$3np$1@build.eclipse.org...
 > 4. Attach to bug
 >> Thanks,
 >> Mustufa
 >>> Hi,
 >>> Tom
 >>>> Thanks Tom,
 >>>> may
 >>>> and
 >>>> the
 >>>> Thanks,
 >>>> Mustufa
 >>>>> Hi,
 >>>>> set
 >>>>> easy to implement.
 >>>>> Tom
 >>>>>> Thanks.
 >>>>>> will
 >>>>>> be
 >>>>>> modify
 >>>>>> the
 >>>>>> color
 >>>>>> of
 >>>>>> that
 >>>>>> i
 >>>>>> need?
 >>>>>> Thanks,
 >>>>>> Mustufa
 >>>>>>>> Hi,
 >>>>>>>> row
 >>>>>>>> header resizable?
 >>>>>>> Hi,
 >>>>>>> anything
 >>>>>>> don't
 >>>>>>> of
 >>>>>>> the
 >>>>>>> Regards,
 >>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65260 is a reply to message #65113] | Fri, 03 July 2009 06:01   |  |
 Any idea when this will be fixed? Actually we are planning to use Nebula
 Grid for our project and fixing this bug is important to us.
 Mustufa
 "Mustufa Kasidwala" <m.kasid@gmail.com> wrote in message
 news:h22ank$i9q$1@build.eclipse.org...
 > Mustufa
 >> 4. Attach to bug
 >>> Hi,
 >>> Thanks,
 >>> Mustufa
 >>>> Hi,
 >>>> Tom
 >>>>> Thanks Tom,
 >>>>> I
 >>>>> may
 >>>>> out
 >>>>> and
 >>>>> the
 >>>>> Thanks,
 >>>>> Mustufa
 >>>>>> Hi,
 >>>>>> set
 >>>>>> easy to implement.
 >>>>>> a
 >>>>>> be
 >>>>>> Tom
 >>>>>>> Thanks.
 >>>>>>> will
 >>>>>>> be
 >>>>>>> modify
 >>>>>>> the
 >>>>>>> color
 >>>>>>> of
 >>>>>>> that
 >>>>>>> i
 >>>>>>> need?
 >>>>>>> Thanks,
 >>>>>>> Mustufa
 >>>>>>>>> Hi,
 >>>>>>>>> row
 >>>>>>>>> header resizable?
 >>>>>>>> Hi,
 >>>>>>>> anything
 >>>>>>>> don't
 >>>>>>>> of
 >>>>>>>> the
 >>>>>>>> Regards,
 >>>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #65454 is a reply to message #65281] | Fri, 10 July 2009 04:42  |  |
 Thanks Tom,
 I can see this is fixed now.
 Mustufa
 news:h2klf5$sci$1@build.eclipse.org...
 > I'll try (but can't promise) to revist it on the weekend.
 > Tom
| Re: Questions on Nebula Grid [message #595372 is a reply to message #64956] | Wed, 24 June 2009 08:21  |  |
| Eclipse User  |  |  |  |  | Mustufa Kasidwala wrote:
 > resizable?
 Stanislav
| Re: Questions on Nebula Grid [message #595381 is a reply to message #64980] | Fri, 26 June 2009 00:58  |  |
| Eclipse User  |  |  |  |  | Thanks.
 need?
 Mustufa
 >> header resizable?
 > Stanislav
| Re: Questions on Nebula Grid [message #595392 is a reply to message #64991] | Fri, 26 June 2009 03:35  |  |
 easy to implement.
 Tom
 > Thanks.
 > need?
 > Mustufa
 >>> Hi,
 >>> header resizable?
 >> Regards,
 >> Stanislav
| Re: Questions on Nebula Grid [message #595409 is a reply to message #65000] | Fri, 26 June 2009 06:31  |  |
| Eclipse User  |  |  |  |  | Thanks Tom,
 Mustufa
 > easy to implement.
 > Tom
 >> Thanks.
 >> be
 >> the
 >> of
 >> i
 >> need?
 >> Thanks,
 >> Mustufa
 >>>> Hi,
 >>>> header resizable?
 >>> Hi,
 >>> anything
 >>> the
 >>> Regards,
 >>> Stanislav
| Re: Questions on Nebula Grid [message #595416 is a reply to message #65040] | Fri, 26 June 2009 06:35  |  |
 Tom
 > Thanks Tom,
 > Mustufa
 >> easy to implement.
 >> Tom
 >>> Thanks.
 >>> be
 >>> the
 >>> of
 >>> i
 >>> need?
 >>> Thanks,
 >>> Mustufa
 >>>>> Hi,
 >>>>> header resizable?
 >>>> Hi,
 >>>> anything
 >>>> the
 >>>> Regards,
 >>>> Stanislav
| Re: Questions on Nebula Grid [message #595430 is a reply to message #65050] | Fri, 26 June 2009 06:46  |  |
 Mustufa
 > Tom
 >> Thanks Tom,
 >> may
 >> and
 >> the
 >> Thanks,
 >> Mustufa
 >>> Hi,
 >>> easy to implement.
 >>> Tom
 >>>> Thanks.
 >>>> be
 >>>> modify
 >>>> the
 >>>> of
 >>>> that
 >>>> i
 >>>> need?
 >>>> Thanks,
 >>>> Mustufa
 >>>>>> Hi,
 >>>>>> header resizable?
 >>>>> Hi,
 >>>>> anything
 >>>>> don't
 >>>>> the
 >>>>> Regards,
 >>>>> Stanislav
| Re: Questions on Nebula Grid [message #595441 is a reply to message #65066] | Fri, 26 June 2009 06:58  |  |
 4. Attach to bug
 > Mustufa
 >> Tom
 >>> Thanks Tom,
 >>> may
 >>> and
 >>> the
 >>> Thanks,
 >>> Mustufa
 >>>> Hi,
 >>>> easy to implement.
 >>>> Tom
 >>>>> Thanks.
 >>>>> be
 >>>>> modify
 >>>>> the
 >>>>> of
 >>>>> that
 >>>>> i
 >>>>> need?
 >>>>> Thanks,
 >>>>> Mustufa
 >>>>>>> Hi,
 >>>>>>> header resizable?
 >>>>>> Hi,
 >>>>>> anything
 >>>>>> don't
 >>>>>> the
 >>>>>> Regards,
 >>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595445 is a reply to message #65091] | Fri, 26 June 2009 07:17  |  |
| Eclipse User  |  |  |  |  | Bug 281644 submitted for this and a patch is attached.
 Mustufa
 > 4. Attach to bug
 >> Thanks,
 >> Mustufa
 >>> Hi,
 >>> Tom
 >>>> Thanks Tom,
 >>>> may
 >>>> and
 >>>> the
 >>>> Thanks,
 >>>> Mustufa
 >>>>> Hi,
 >>>>> set
 >>>>> easy to implement.
 >>>>> Tom
 >>>>>> Thanks.
 >>>>>> will
 >>>>>> be
 >>>>>> modify
 >>>>>> the
 >>>>>> color
 >>>>>> of
 >>>>>> that
 >>>>>> i
 >>>>>> need?
 >>>>>> Thanks,
 >>>>>> Mustufa
 >>>>>>>> Hi,
 >>>>>>>> row
 >>>>>>>> header resizable?
 >>>>>>> Hi,
 >>>>>>> anything
 >>>>>>> don't
 >>>>>>> of
 >>>>>>> the
 >>>>>>> Regards,
 >>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595508 is a reply to message #65113] | Fri, 03 July 2009 06:01  |  |
 Mustufa
 > Mustufa
 >> 4. Attach to bug
 >>> Hi,
 >>> Thanks,
 >>> Mustufa
 >>>> Hi,
 >>>> Tom
 >>>>> Thanks Tom,
 >>>>> I
 >>>>> may
 >>>>> out
 >>>>> and
 >>>>> the
 >>>>> Thanks,
 >>>>> Mustufa
 >>>>>> Hi,
 >>>>>> set
 >>>>>> easy to implement.
 >>>>>> a
 >>>>>> be
 >>>>>> Tom
 >>>>>>> Thanks.
 >>>>>>> will
 >>>>>>> be
 >>>>>>> modify
 >>>>>>> the
 >>>>>>> color
 >>>>>>> of
 >>>>>>> that
 >>>>>>> i
 >>>>>>> need?
 >>>>>>> Thanks,
 >>>>>>> Mustufa
 >>>>>>>>> Hi,
 >>>>>>>>> row
 >>>>>>>>> header resizable?
 >>>>>>>> Hi,
 >>>>>>>> anything
 >>>>>>>> don't
 >>>>>>>> of
 >>>>>>>> the
 >>>>>>>> Regards,
 >>>>>>>> Stanislav
| Re: Questions on Nebula Grid [message #595512 is a reply to message #65260] | Fri, 03 July 2009 06:10  |  |
 Tom
| Re: Questions on Nebula Grid [message #595584 is a reply to message #65281] | Fri, 10 July 2009 04:42  |  |
 Mustufa
 > Tom
 Current Time: Fri Oct 31 17:09:32 EDT 2025
 Powered by FUDForum . Page generated in 0.09795 seconds |
