Home » Archived » M2M (model-to-model transformation) » antlr/TokenStream error
antlr/TokenStream error [message #63631] Wed, 10 October 2007 03:36 Go to next message
Hello all,
i have this error when i try the Author2Person tutorial of ATL. I have
found mails that say that the reason is antlr.jar is missing in the engine
plugin so i put the (renamed) last antlr.jar in
org.eclipse.m2m.atl.engine_2.0.0 and i have allways the same error
here is the stack trace
java.lang.NoClassDefFoundError: antlr/TokenStream
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:244)
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:201)
org.atl.engine.injectors.ebnf.EBNFInjector2.inject(EBNFInjec tor2.java:78)
org.eclipse.gmt.am3.dsls.km3.KM3Projector.getKM3FromFile(KM3 Projector.java:236)
org.eclipse.gmt.am3.dsls.km3.KM3Projector.getEMFKM3FromFile( KM3Projector.java:216)
at org.eclipse.gmt.am3.dsls.km3.actions.KM32Ecore$1.run(KM32Eco re.java:58)
any ideas ?
Vincent
[ATL] Re: antlr/TokenStream error [message #63654 is a reply to message #63631] Wed, 10 October 2007 04:17 Go to previous messageGo to next message
--------------010405000105020609060204
If your posts only concerns ATL, please remember to prefix the subject
with [ATL].
I think you must put antlr.jar in the
org.eclipse.m2m.atl.engine_2.0.0/lib directory, instead of
org.eclipse.m2m.atl.engine_2.0.0.
William
Vincent Hilaire a
Re: [ATL] Re: antlr/TokenStream error [message #63676 is a reply to message #63654] Wed, 10 October 2007 08:41 Go to previous messageGo to next message
in fact i placed the antlr.jar file in the two directories (just in case)
org.eclipse.m2m.atl.engine_2.0.0/lib and org.eclipse.m2m.atl.engine_2.0.0.
Vincent
Re: [ATL] Re: antlr/TokenStream error [message #63719 is a reply to message #63676] Wed, 10 October 2007 10:32 Go to previous messageGo to next message
--------------000603070901060000060002
OK, so how did you install ATL ?
In the last version (see : http://www.eclipse.org/m2m/atl/download/)
there is no need to manually install antlr.jar because only
antlr-runtime.jar is required, and is included into ATL.
Installing ATL via update-site, or binaries build should work.
Vincent Hilaire a
Re: [ATL] Re: antlr/TokenStream error [message #63785 is a reply to message #63719] Thu, 11 October 2007 05:33 Go to previous messageGo to next message
I have tried both :(
Vincent
> Regards
> Vincent Hilaire a écrit :
>> Hello,
Re: [ATL] Re: antlr/TokenStream error [message #63808 is a reply to message #63785] Thu, 11 October 2007 06:15 Go to previous messageGo to next message
--------------000801020201000401050704
Perhaps is your Eclipse corrupted, or not up to date. Could you try to
launch it with the -clean option ?
Vincent Hilaire a
Re: [ATL] Re: antlr/TokenStream error [message #63829 is a reply to message #63808] Fri, 12 October 2007 04:37 Go to previous messageGo to next message
> Hello,
i just tried this but it change nothing...
Vincent
>> Vincent
>>> Regards
>>>> Hello,
>> Vincent
>>> Regards
>>>> Hello,
Re: [ATL] Re: antlr/TokenStream error [message #63851 is a reply to message #63829] Fri, 12 October 2007 05:49 Go to previous messageGo to next message
--------------030308070206090805070202
It is strange, it works fine for me...
Could you tell please me if you use Eclipse 3.3 and EMF 2.3, and send me
your KM3 file ?
To avoid this error, you can also directly use ecore files instead of
KM3, i.e. create the metamodel using EMF editor.
Vincent Hilaire a
Re: [ATL] Re: antlr/TokenStream error [message #64053 is a reply to message #63851] Mon, 15 October 2007 09:37 Go to previous message
> your KM3 file ?
>>> Hello,
>> Hello,
>> Vincent
>>>> Vincent
>>>>> Regards
>>>>>> Hello,
>>>> Vincent
>>>>> Regards
>>>>>> Hello,
i just try the same conf on a pc windows ad it works (all the precedent
tests were on a MacBook with mac OS X) maybe there is something there ?
Vincent
Previous Topic:[ATL] ecore to ecore transformation
Next Topic:[ATL] Catching TransformationException
Current Time: Sun Nov 09 03:13:07 EST 2025
Powered by FUDForum. Page generated in 0.05376 seconds
