CDateTime display change? [message #63564] |
Fri, 15 May 2009 21:12  |
Has the CDateTime drop-down graphical display changed? We have an older
version in use where the drop-down is set to show both a calendar (left)
and an analog clock (right) at the same time. The new screenshots seem to
indicate only either the calendar or analog clock with a button to switch
between the two.
We are interested in upgrading to get bugfixes but such a change may
impede that.
Craig Foote
Re: CDateTime display change? [message #63677 is a reply to message #63655] |
Tue, 19 May 2009 19:21   |
OK, I will, thanks Nicolas. Are you planning a release or milestone any
time soon? It'll be hard to convince the powers that be to go to prod
with a nightly trunk build :) (though I will be downloading and trying it
out in the meantime)
Craig
On Tue, 19 May 2009 14:29:26 +0200, Nicolas Richeton wrote:
> It is (updated everyday)
> Just wait 1 full day after the fix is committed before downloading the
> file just to be sure the change is included. If for some reason you
> think that the file is not updated, let us know because we don't get
> alert on failure yet.
> Nicolas
> Craig Foote a écrit :
>> Thanks Jeremy. That's great news. Is the 'Latest nightly build' on the
>> nebula downloads page kept up to date, i.e. updated every day?
>> Craig
>> On Mon, 18 May 2009 07:30:59 -0600, Jeremy Dowdall wrote:
>>> this is now fixed in HEAD: Bug 276699
>>>> older version in use where the drop-down is set to show both a
>>>> calendar (left) and an analog clock (right) at the same time. The new
>>>> screenshots seem to indicate only either the calendar or analog clock
>>>> with a button to switch between the two.
>>>> impede that.
>>>> Thanks,
>>>> Craig Foote
Re: CDateTime display change? [message #63811 is a reply to message #63677] |
Fri, 29 May 2009 18:57  |
Anyone?
> it out in the meantime)
> Craig
>> Nicolas
>>> Craig
>>>>> new screenshots seem to indicate only either the calendar or analog
>>>>> clock with a button to switch between the two.
>>>>> impede that.
>>>>> Thanks,
>>>>> Craig Foote
Re: CDateTime display change? [message #594757 is a reply to message #63564] |
Mon, 18 May 2009 09:30  |
> between the two.
> impede that.
> Craig Foote
Re: CDateTime display change? [message #594762 is a reply to message #63586] |
Mon, 18 May 2009 18:37  |
Craig
>> impede that.
>> Thanks,
>> Craig Foote
Re: CDateTime display change? [message #594782 is a reply to message #63609] |
Tue, 19 May 2009 08:29  |
If for some reason you think that the file is not updated, let us know
because we don't get alert on failure yet.
Nicolas
> Craig
>>> impede that.
>>> Thanks,
>>> Craig Foote
Re: CDateTime display change? [message #594792 is a reply to message #63655] |
Craig
> Nicolas
>> Craig
>>>> impede that.
>>>> Thanks,
>>>> Craig Foote
Re: CDateTime display change? [message #594861 is a reply to message #63677] |
Anyone?
> Craig
>> Nicolas
>>> Craig
>>>>> impede that.
>>>>> Thanks,
>>>>> Craig Foote
FUDForum. Page generated in 0.05320 seconds
