Home » Eclipse Projects » Plugin Development Environment (PDE) » Default location of the runtime configuration
Default location of the runtime configuration [message #63204] Mon, 25 May 2009 20:44 Go to next message
If you run a new RCP application or if you create a new runtime
configuration for a plug-in the runtime configuration is populated with
some values.
I would like to change the default value for the location of the runtime
configuration.
Currently the location in which the Eclipse application is started
defaults to:
${workspace_loc}/../runtime-NAMEOFPROJECT.application
I would like to change the default ${workspace_loc}/.. to another place,
e.g. c:\temp\
Is this possible?
Best regards, Lars
Re: Default location of the runtime configuration [message #63227 is a reply to message #63204] Tue, 26 May 2009 04:39 Go to previous messageGo to next message
> e.g. c:\temp\
> Is this possible?
I believe you are talking about running your RCP app from an
Eclipse. If that is the case you can edit the Launch Configuration and
point to a location you want.
- Prakash
http://blog.eclipse-tips.com
Re: Default location of the runtime configuration [message #63274 is a reply to message #63227] Tue, 26 May 2009 11:23 Go to previous messageGo to next message
thanks for the reply, but unfortunately this was not my question.
I would like to know if the default workspace location in a new runtime
configuration can be changed.
Of course I can change the default workspace location every time manually
but it would like to change it once for all future runtime configurations.
Best regards, Lars
Re: Default location of the runtime configuration [message #63298 is a reply to message #63274] Tue, 26 May 2009 13:00 Go to previous messageGo to next message
I don't think its configurable.
- Prakash
Re: Default location of the runtime configuration [message #63344 is a reply to message #63204] Tue, 26 May 2009 15:15 Go to previous messageGo to next message
Lars Vogel wrote:
> some values.
> configuration.
> defaults to:
> e.g. c:\temp\
> Is this possible?
> Best regards, Lars
There is a trick.
Go to Window -> Preferences -> Run/Debug -> String Substitution
Add a new variable by the name workspace_loc and give a value C:\temp\dummy (this way
${workspace_loc}/.. will resolve to c:\temp)
However, in case you have used this variable in launch arguments, that will be impacted too. So be
careful.
hth,
Ankur..
Re: Default location of the runtime configuration [message #63367 is a reply to message #63344] Wed, 27 May 2009 01:19 Go to previous message
Hi Ankur,
thanks you, works perfectly. Best regards, Lars
Ankur Sharma wrote:
> Lars Vogel wrote:
>> with some values.
>> runtime configuration.
>> defaults to:
>> place, e.g. c:\temp\
>> Is this possible?
>> Best regards, Lars
> There is a trick.
> C:\temp\dummy (this way ${workspace_loc}/.. will resolve to c:\temp)
> will be impacted too. So be careful.
Re: Default location of the runtime configuration [message #597855 is a reply to message #63204] Tue, 26 May 2009 04:39 Go to previous message
> e.g. c:\temp\
> Is this possible?
- Prakash
Re: Default location of the runtime configuration [message #597865 is a reply to message #63227] Tue, 26 May 2009 11:23 Go to previous message
Best regards, Lars
Re: Default location of the runtime configuration [message #597870 is a reply to message #63274] Tue, 26 May 2009 13:00 Go to previous message
- Prakash
Re: Default location of the runtime configuration [message #597881 is a reply to message #63204] Tue, 26 May 2009 15:15 Go to previous message
Lars Vogel wrote:
> some values.
> configuration.
> defaults to:
> e.g. c:\temp\
> Is this possible?
> Best regards, Lars
There is a trick.
careful.
hth,
Ankur..
Re: Default location of the runtime configuration [message #597885 is a reply to message #63344] Wed, 27 May 2009 01:19 Go to previous message
Hi Ankur,
Ankur Sharma wrote:
> Lars Vogel wrote:
>> with some values.
>> defaults to:
>> Is this possible?
>> Best regards, Lars
> There is a trick.
Previous Topic:Default location of the runtime configuration
Next Topic:Parameterized product builds
Current Time: Tue May 13 04:26:28 EDT 2025
Powered by FUDForum. Page generated in 4.20214 seconds
