| [ATL] Compiling outside eclipse (part II) [message #63090] |
Thu, 27 September 2007 20:06  |
Originally posted by: irbull.cs.uvic.ca
I have used ATL to compile outside eclipse successfully, by compiling a
transformation to an ASM file, and then using that file in my
transformation. I was wondering why files are used instead of byte
streams. I know it is possible to pass a byte stream into the ATL
compiler, but why can't I get a byte stream back out (the byte stream
would represent the successfully compiled ATL transformation). Then I
could pass this byte stream to the transformation?
Ian
| Re: [ATL] Compiling outside eclipse (part II) [message #63211 is a reply to message #63162] |
Sat, 29 September 2007 00:54  |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204974
I'll see if I can help with a patch :)
cheers,
ian
Frédéric Jouault wrote:
> Hi Ian,
> You have a good point here.
> Why don't you open a bugzilla entry for this?
> Of course, it would be even better if you could also submit a patch ;-).
> Best regards,
> Frédéric Jouault
FUDForum. Page generated in 0.09321 seconds
