Home » Eclipse Projects » GEF » Word-wrap in Label -> TextFlow?
Word-wrap in Label -> TextFlow? [message #62234] Wed, 05 February 2003 14:59 Go to next message
Originally posted by: dinkloh.DELETE_THIS_SPAMBLOCKipd.uni-karlsruhe.de
Hello!
I have a Figure and would like to add some text in it, which should be
word-wrapped so that it fills the Rectangle from getBounds(). First I tried
to add a Label to my Figure, but the text is not wrapped. So I looked in the
Javadoc and found the class TextFlow, which fits my needs "An inline flow
that renders a sting of text across one or more lines.".
Now my problem: Simply instanciating and add()-ing it to my figure, gives me
a NullPointerException, so I guess the warning "It does not provide a
FlowContext" has probably something to do with it.
My code snippet and the full error message is below, does anybody know how
to do this?
Thank you very much in advance,
Martin
public MartinsFigure() {
TextFlow tf = new TextFlow("WRAPME WRAPME WRAPME");
this.add(tf);
org.eclipse.draw2d.text.ParagraphTextLayout.layout(Paragraph TextLayout.java:
56)
org.eclipse.draw2d.text.FlowFigureLayout.layout(FlowFigureLa yout.java:67)
at org.eclipse.draw2d.Figure.layout(Figure.java:862)
at org.eclipse.draw2d.Figure.validate(Figure.java:1523)
at org.eclipse.draw2d.Figure.validate(Figure.java:1525)
org.eclipse.draw2d.FreeformLayeredPane.validate(FreeformLaye redPane.java:68)
org.eclipse.draw2d.FreeformViewport$FreeformViewportLayout.c alculatePreferre
dSize(FreeformViewport.java:20)
org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractL ayout.java:83)
org.eclipse.draw2d.AbstractHintLayout.getPreferredSize(Abstr actHintLayout.ja
va:76)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:604)
at org.eclipse.draw2d.ScrollPaneSolver.solve(ScrollPaneSolver.j ava:44)
at org.eclipse.draw2d.FigureCanvas.layoutViewport(FigureCanvas. java:161)
at org.eclipse.draw2d.FigureCanvas.access$4(FigureCanvas.java:1 59)
org.eclipse.draw2d.FigureCanvas$3.notifyValidating(FigureCan vas.java:124)
at org.eclipse.draw2d.UpdateManager.fireValidating(UpdateManage r.java:63)
org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManag
er.java:156)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager
..java:90)
org.eclipse.gef.ui.parts.GraphicalViewerImpl.flush(Graphical ViewerImpl.java:
105)
org.eclipse.gef.dnd.TemplateTransferDropTargetListener.selec tAddedObject(Tem
plateTransferDropTargetListener.java:95)
org.eclipse.gef.dnd.TemplateTransferDropTargetListener.handl eDrop(TemplateTr
ansferDropTargetListener.java:84)
org.eclipse.gef.dnd.AbstractTransferDropTargetListener.drop( AbstractTransfer
DropTargetListener.java:150)
org.eclipse.gef.dnd.DelegatingDropAdapter$3.run(DelegatingDr opAdapter.java:1
28)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:839)
at org.eclipse.core.runtime.Platform.run(Platform.java:416)
org.eclipse.gef.dnd.DelegatingDropAdapter.drop(DelegatingDro pAdapter.java:12
5)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :61)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 36)
at org.eclipse.swt.dnd.DropTarget.notifyListeners(DropTarget.ja va:548)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:485)
at org.eclipse.swt.dnd.DropTarget.access$7(DropTarget.java:413)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:205 )
org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMOb ject.java:111)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:295)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:276)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :144)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:827)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1529)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1343)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1326)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:831)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:432)
at EclipseRuntimeLauncher.main(EclipseRuntimeLauncher.java:24)
Re: Word-wrap in Label -> TextFlow? [message #62259 is a reply to message #62234] Wed, 05 February 2003 15:54 Go to previous messageGo to next message
From TextFlow's superclass:
* ... An
* <code>InlineFlow</code>'s parent must be either a {@link BlockFlow} or
another
* InlineFlow.
FlowPage is the only figure that does not have the restriction, so place a
TextFlow inside a FlowPage.
"Martin Dinkloh" <dinkloh@DELETE_THIS_SPAMBLOCKipd.uni-karlsruhe.de> wrote
in message news:b1rp4a$ejh$1@rogue.oti.com...
> Hello!
tried
the
me
> to do this?
> Martin
> this.add(tf);
> java.lang.NullPointerException
> at
> 56)
> at
> at
> at
> at
> at
> at
> va:76)
> at
> at
> er.java:156)
> at
> .java:90)
> at
> 105)
> at
> at
> at
> at
> 28)
> at
> :839)
> at
> 5)
> at
> at
> a:831)
Re: Word-wrap in Label -> TextFlow? [message #62380 is a reply to message #62259] Thu, 06 February 2003 05:49 Go to previous messageGo to next message
Thank you for the quick response, this worked out well. But although it is
is showing in one line "WRAPME ", now, it is still not word-wrapping the
text. My new code snippet is below. I checked the bounds Rectangle with the
debugger and it is (height = 36, width = 64) for all three IFigures
(MartinsFigure, tf, fp), so that the text should actually get wrapped.
public MartinsFigure() {}
Thank you, Martin
"Randy Hudson" <none@us.ibm.com> schrieb im Newsbeitrag
news:b1rsan$mfb$1@rogue.oti.com...
> * ... An
> another
> * InlineFlow.
> > Hello!
> tried
> the
flow
gives
> me
how
> > to do this?
> > Martin
> > this.add(tf);
> > at
> > 56)
> > at
> > at
> > at
> > at
> > at
> > at
> > va:76)
> > at
> > at
> > at
> > at
> > er.java:156)
> > at
> > .java:90)
> > at
> > 105)
> > at
> > at
> > at
> > at
> > 28)
> > at
> > :839)
> > at
> > 5)
> > at
> > at
> > a:831)
Re: Word-wrap in Label -> TextFlow? [message #62404 is a reply to message #62380] Thu, 06 February 2003 05:53 Go to previous messageGo to next message
Here the code snippet:
FlowPage fp = new FlowPage();
fp.add(tf);
add(fp);
"Martin Dinkloh" <dinkloh@DELETE_THIS_SPAMBLOCKipd.uni-karlsruhe.de> schrieb
im Newsbeitrag news:b1td86$ist$1@rogue.oti.com...
the
> Thank you, Martin
> > * ... An
> > another
> > * InlineFlow.
a
> > > Hello!
> > tried
in
> > the
> flow
> gives
> > me
> how
> > > to do this?
> > > Martin
> > > this.add(tf);
> > > at
> > > 56)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > va:76)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > er.java:156)
> > > at
> > > .java:90)
> > > at
> > > 105)
> > > at
> > > at
> > > at
> > > at
> > > 28)
> > > at
> > > :839)
> > > at
> > > 5)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > a:831)
Re: Word-wrap in Label -> TextFlow? [message #62559 is a reply to message #62404] Thu, 06 February 2003 09:34 Go to previous messageGo to next message
MartinsFigure is not laying out the FlowPage. Add a StackLayout to
MartinsFigure, then it will size the flowpage to be 64x36 also.
in message news:b1tdg0$j2q$1@rogue.oti.com...
> fp.add(tf);
> add(fp);
is
> the
> > Thank you, Martin
> > > * ... An
or
> > > another
> > > * InlineFlow.
place
> a
> > > > Hello!
be
I
> > > tried
looked
> in
> > > the
> > flow
> > gives
> > > me
a
know
> > how
> > > > to do this?
> > > > Martin
> > > > this.add(tf);
> > > > at
> > > > 56)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > va:76)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > er.java:156)
> > > > at
> > > > .java:90)
> > > > at
> > > > 105)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > 28)
> > > > at
> > > > :839)
> > > > at
> > > > 5)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > a:831)
Re: Word-wrap in Label -> TextFlow? [message #62727 is a reply to message #62559] Thu, 06 February 2003 12:11 Go to previous messageGo to next message
Sorry to be so annoying, but it is still not working. In the debugger the
LayoutManagers show up as follows: MartinsFigure:StackLayout,
fp:PageFlowLayout, tf:ParagraphTextLayout.
setLayoutManager(new StackLayout());
fp.add(tf);
add(fp);
news:b1tqe3$tb4$1@rogue.oti.com...
> > fp.add(tf);
> > add(fp);
it
> is
the
with
> > the
> > > Thank you, Martin
> > > > * ... An
BlockFlow}
> or
> > > > another
> > > > * InlineFlow.
> place
> > a
> > > > > Hello!
should
> be
First
> I
> > > > tried
> looked
> > in
> > > > the
inline
> > > flow
figure,
> > > gives
> > > > me
provide
> a
> know
> > > how
> > > > > to do this?
> > > > > Martin
> > > > > this.add(tf);
> > > > > at
> > > > > 56)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > va:76)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > er.java:156)
> > > > > at
> > > > > .java:90)
> > > > > at
> > > > > 105)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > 28)
> > > > > at
> > > > > :839)
> > > > > at
> > > > > 5)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
Method)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > a:831)
Re: Word-wrap in Label -> TextFlow? [message #183254 is a reply to message #62727] Tue, 31 May 2005 19:48 Go to previous message
Did you ever get this to work? I'm having the same problem...
> fp.add(tf);
> add(fp);
>>> fp.add(tf);
>>> add(fp);
> it
>>is
> the
> with
>>>the
>>>>Thank you, Martin
>>>>>* ... An
> BlockFlow}
>>or
>>>>>another
>>>>>* InlineFlow.
>>place
>>>a
>>>>>>Hello!
> should
>>be
> First
>>I
>>>>>tried
>>looked
>>>in
>>>>>the
> inline
>>>>flow
> figure,
>>>>gives
>>>>>me
> provide
>>a
>>know
>>>>how
>>>>>>to do this?
>>>>>>Martin
>>>>>> this.add(tf);
>>>>>> at
>>>>>>56)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>va:76)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>er.java:156)
>>>>>> at
>>>>>>.java:90)
>>>>>> at
>>>>>>105)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>28)
>>>>>> at
>>>>>>:839)
>>>>>> at
>>>>>>5)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
> Method)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>>a:831)
Previous Topic:How to activate property sheets to gef edit parts
Next Topic:Is it possible to export Plug-ins as stand-alone application
Current Time: Sun Nov 30 23:25:44 EST 2025
Powered by FUDForum. Page generated in 0.04090 seconds
