Home » Newcomers » Newcomers » Run program
Run program [message #62036] Mon, 09 May 2005 08:03 Go to next message
Hi all
I want to run and test a java file
So i've right-clicked java file select Run and clicked the arguments tab
My method is a main method that accepts args (public static void main(String
[] args))
How to i set args in the Run configuration Ags tab
Many thanks
Re: Run program [message #62084 is a reply to message #62036] Mon, 09 May 2005 09:32 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
Simply write them to the 'Program Arguments' text field as you write for the
command line.
HTH,
Csaba
plork123 wrote:
> Hi all
> main(String [] args))
> Many thanks
Previous Topic:Is there anybody able to help with a small problem?
Next Topic:Is there a way to "save" the items you're watching during debugging
Current Time: Thu Nov 13 02:27:31 EST 2025
Powered by FUDForum. Page generated in 0.07923 seconds
