Home » Eclipse Projects » Mylyn » Unable to update Bugzilla
Unable to update Bugzilla [message #61983] Thu, 20 November 2008 05:40 Go to next message
chakribobby  is currently offline chakribobby
While running the below code I got this error message
org.eclipse.core.runtime.CoreException: Mid-air collision occurred while
submitting to http://bugzilla-link/.
Synchronize task and re-submit changes.
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.pars eHtmlError(BugzillaClient.java:1221)
org.eclipse.mylyn.internal.bugzilla.core.BugzillaClient.post TaskData(BugzillaClient.java:868)
org.eclipse.mylyn.internal.bugzilla.core.BugzillaTaskDataHan dler.postTaskData(BugzillaTaskDataHandler.java:254)
at test.main(test.java:47)
test code is
import org.eclipse.core.runtime.CoreException;
import org.eclipse.mylyn.commons.net.AuthenticationCredentials;
import org.eclipse.mylyn.commons.net.AuthenticationType;
import org.eclipse.mylyn.internal.bugzilla.core.BugzillaAttribute;
import org.eclipse.mylyn.internal.bugzilla.core.BugzillaCorePlugin;
import
org.eclipse.mylyn.internal.bugzilla.core.BugzillaRepositoryC onnector;
import org.eclipse.mylyn.internal.commons.net.CommonsNetPlugin;
import org.eclipse.mylyn.tasks.core.ITaskMapping;
import org.eclipse.mylyn.tasks.core.TaskRepository;
import org.eclipse.mylyn.tasks.core.data.TaskAttribute;
import org.eclipse.mylyn.tasks.core.data.TaskData;
public class test {
private static final String URL = "http://bugzilla-link/";
private static final String BUG_ID = "4534";
public static void main(String[] args){
System.out.println("flkds");
TaskRepository repository = new
TaskRepository(BugzillaCorePlugin.CONNECTOR_KIND, URL);
AuthenticationCredentials credentials = new
AuthenticationCredentials("xyz", "xyz");
repository.setCredentials(AuthenticationType.REPOSITORY, credentials,
false);
BugzillaRepositoryConnector connector = new BugzillaRepositoryConnector();
try {
// get a report from repository
TaskData taskData = connector.getTaskData(repository, BUG_ID, null);
// access task information
ITaskMapping taskMapping = connector.getTaskMapping(taskData);
System.out.println("Summary: " + taskMapping.getSummary());
System.out.println("Priority: " + taskMapping.getPriority());
System.out.println("status " + taskMapping.getStatus());
TaskAttribute descriptionAttribute =
taskData.getRoot().getMappedAttribute(TaskAttribute.COMPONEN T);
System.out.println("Component: " + descriptionAttribute.getValue());
// ...or by Bugzilla keys
TaskAttribute severityAttribute =
taskData.getRoot().getAttribute(BugzillaAttribute.BUG_SEVERI TY.getKey());
System.out.println("Severity: " + severityAttribute.getValue());
// Post modified report to repository
System.out.print("\nPosting a new comment... ");
TaskAttribute newCommentAttribute =
taskData.getRoot().getMappedAttribute(TaskAttribute.COMMENT_ NEW);
newCommentAttribute.setValue("Hello world.");
connector.getTaskDataHandler().postTaskData(repository, taskData, null,
null);
System.out.println("done");
catch (Exception e) {
e.printStackTrace();
} finally {
CommonsNetPlugin.getExecutorService().shutdown();
Output of the code is
Summary: test
Priority: P2
status NEW
Component: tasks
Severity: normal
Posting a new comment... org.eclipse.core.runtime.CoreException: Mid-air
collision occurred while submitting to http://bugzilla-link/.
can any one help me
thanks in advance
Re: Unable to update Bugzilla [message #62152 is a reply to message #61983] Mon, 24 November 2008 19:48 Go to previous messageGo to next message
Eclipse User
Originally posted by: rob.elves.eclipse.org
I just ran your code here without failure. What Bugzilla repository are
you testing against?
-Rob
chakribobby wrote:
> Hi
> at
> at
> at
> test code is
> import
> public class test {
> false);
> try {
> null);
> } finally {
> Summary: test
> Priority: P2
> status NEW
> Component: tasks
> Severity: normal
> at
> at
> at
> can any one help me
> thanks in advance
Re: Unable to update Bugzilla [message #594972 is a reply to message #61983] Mon, 24 November 2008 19:48 Go to previous messageGo to next message
Robert Elves is currently offline Robert Elves
Member
-Rob
chakribobby wrote:
> Hi
> at
> at
> at
> test code is
> import
> public class test {
> false);
> try {
> null);
> } finally {
> Summary: test
> Priority: P2
> status NEW
> Component: tasks
> Severity: normal
> at
> at
> at
> can any one help me
> thanks in advance
Re: Unable to update Bugzilla [message #896839 is a reply to message #61983] Fri, 20 July 2012 01:41 Go to previous message
martin mariska is currently offline martin mariska
Hello, i have the same problem. I am using bugzilla "Virtual Bugzilla Server 3.4 brought to you by ALM Works | 2009-12-13"
Thx
Previous Topic:Mylyn 3.8 is now available
Next Topic:Error on New Bugzilla Repository in Juno
Current Time: Mon May 20 01:27:26 EDT 2013
Powered by FUDForum. Page generated in 0.01582 seconds
