Home » Language IDEs » PHP Development Tools (PDT) » PDT - (x)debug local PHP script
PDT - (x)debug local PHP script [message #61695] Tue, 27 November 2007 15:17 Go to next message
Hello all
I'm trying to debug a local php script. PDT, PHP, xdebug etc are all
installed and I can use xdebug to do remote debugging of websites. But now
I try to debug a local script with XDebug.
When I add a script for debugging, the debugger doesn't stop and just runs
the script.
What I did was:
* Open Debug Dialog
* double clicked on PHP script
* Entered a name
* Choose Xdebug as debugger (PHP executable is set correctly)
* Selected the PHP file
* Tried with and without break at first line
Is there something special you need to do to debug a local script with
XDebug?
Thanks in advance
Johan Vandeweerd
XDebug 2.0.2
PHP 5.2.4
PDT 1.0 20070910
Mac OsX Leopard/WinXP
Apache 2.2.6
Re: PDT - (x)debug local PHP script [message #61812 is a reply to message #61695] Wed, 28 November 2007 12:47 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Hi Johan, The first thing to check is whether xdebug is actually
configured. try running phpinfo in your script and checking the output.
The ini file it says that it is using will be in some temporary
directory which is a modified copy of the one found in the same
directory as the php executable.
Dave Kelsey
Johan Vandeweerd wrote:
> Hello all
> now I try to debug a local script with XDebug.
> runs the script.
> What I did was:
> * Open Debug Dialog
> * Entered a name
> XDebug?
> Thanks in advance
> Johan Vandeweerd
> XDebug 2.0.2
> PHP 5.2.4
> PDT 1.0 20070910
> Apache 2.2.6
Re: PDT - (x)debug local PHP script [message #61881 is a reply to message #61812] Thu, 29 November 2007 16:00 Go to previous messageGo to next message
Thanks for the reply.
When I create a php script with the following:
<?php
phpinfo();
and right click on it, select run as and select php script, it shows
Configuration File (php.ini) Path => /usr/local/php5/lib
which is the same as the apache uses. I can't find anyt temporary php.ini.
When I run php -m from the commandline, xdebug is shown in the section of
the Zend Modules.
Any suggestion or anything I can try or do?
Thank in advance
Johan Vandeweerd
Re: PDT - (x)debug local PHP script [message #61904 is a reply to message #61881] Fri, 30 November 2007 07:55 Go to previous messageGo to next message
try copying the php.ini file to where the php executable is and see if it works.
Also run your phpinfo under debug and check that xdebug is listed in the output.
Dave Kelsey
> <?php
> phpinfo();
> of the Zend Modules.
> Thank in advance
> Johan Vandeweerd
Re: PDT - (x)debug local PHP script [message #61927 is a reply to message #61904] Sun, 02 December 2007 07:13 Go to previous message
Thanks Dave, symlinking the php.ini to the same directory did the trick.
Johan Vandeweerd
Previous Topic:web page debug: source code view from wrong dir
Next Topic:Re: Disabling "Building workspace"
Current Time: Sat Nov 29 08:57:35 EST 2025
Powered by FUDForum. Page generated in 0.09742 seconds
