Home » Language IDEs » C / C++ IDE (CDT) » Warnings in CDT
Warnings in CDT [message #61236] Wed, 05 February 2003 14:20 Go to next message
Originally posted by: spam.eclipse.mooreclan.us
------=_NextPart_000_001A_01C2CD08.A6C20200
Content-Type: text/plain;
charset="iso-8859-1"
I just checked out the HEAD rev of cdt and have gotten it to compile. =
What concerns me is that there are a large number of warnings "The =
static method/field Xxx from the type Yyy should be accessed in a static =
way"
For example, at line 35 in CStructurizer.java, the ReInit method is =
accessed by dereferencing fParser. Shouldn't
fParser.ReInit(lpiStream);
look more like this:
CPPParser.ReInit(lpiStream);
While I'm at it, shouldn't developers that checkin code with compiler =
warnings be threatened with bamboo shoots under their fingernails?
-MM (mark.moore@notlimited.com)
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1126" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I just checked out the HEAD rev of cdt =
and have=20
gotten it to compile.&nbsp; What concerns me is that there are a large =
number of=20
warnings "The static method/field Xxx from the type Yyy should be =
accessed in a=20
static way"</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>For example, at line 35 in =
CStructurizer.java, the=20
ReInit method is accessed by dereferencing fParser.&nbsp; =
Shouldn't</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; <FONT=20
size=3D2>fParser.ReInit(lpiStream);</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>look more like this:</FONT></DIV>
size=3D2>CPPParser.ReInit(lpiStream);</FONT></FONT></DIV >
<DIV><FONT face=3DArial size=3D2>While I'm at it, shouldn't developers =
that checkin=20
code with compiler warnings be threatened with bamboo shoots under their =
fingernails?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-MM=20
(mark.moore@notlimited.com)</FONT></DIV></BODY></HTML>
------=_NextPart_000_001A_01C2CD08.A6C20200--
Re: Warnings in CDT [message #61264 is a reply to message #61236] Thu, 06 February 2003 00:58 Go to previous messageGo to next message
Originally posted by: ed.burnette.no.spam.sas.com
I believe that warning used to be turned off by default in Eclipse 2.0.x
where CDT was originally developed. I had the same problem and "fixed" it by
turning the warning back off. Personally I don't see the problem with
accessing static things in a non-static way - why should I have to care if
the programmer made them static or not?
Don't be suprised if you see a few 'deprecated' warnings too. Unlike the
main body (Platform SDK) of Eclipse, CDT currently has to work with more
than one version of Eclipse so it doesn't have the luxury of upgrading to
new interfaces that might not be there in old versions of Eclipse.
"Mark Moore" <spam.eclipse@mooreclan.us> wrote in message
news:b1rmtv$ri4$1@rogue.oti.com...
> number of warnings "The static method/field Xxx from the type Yyy should
be accessed in a static way"
Re: Warnings in CDT [message #61384 is a reply to message #61264] Thu, 06 February 2003 15:57 Go to previous message
Agree 300 % with this.
Warnings are indicators from the compiler, not end goals.
As the developers move to 2.1, they clean up when necessary.
We did the same drill when doing Eclipse-1.x --> Eclipse-2.0.x
Second point, the bulk of warnings is actually
generated code by JavaCC(think yacc/lex), CPPParser.java.
This code is automatically generated so, you do not want
to mess with it.
Previous Topic:how to install plugin
Next Topic:Code formater
Current Time: Thu Sep 18 14:13:37 EDT 2025
Powered by FUDForum. Page generated in 0.05573 seconds
