| Grid Header/Footer: Scrolling [message #60990] | Mon, 08 December 2008 07:45  |  |
| Eclipse User  |  |  |  |  | Hi
 I've been trying out the Header/Footer implementation of the Grid and so far
 it looks
 like a really nice feature. However I've found two small problems regarding
 scrolling
 in GridHeaderEditor:
 1) Firstly GridHeaderEditor adds a selectionlistener that calls layout() to
 both the vertical and
 the horizontal scrollbar of the Grid. I can understand the horizontal bar
 but what's the reason behind the
 vertical bar? Since I have a couple of hundred rows and about 20-30
 columns with a
 columheader attached to each, it really slows down the vertical
 scrolling...
 2) There seems to be a small bug when using header/footers together with a
 RowHeader.
 If the column with the header is small enough and you scroll to the
 right the header control ends
 up in the area handled by the TopLeftRenderer.
 Updating the following if statement in the layout() method in the
 GridHeaderEditor:
 if (rect == null || rect.x < 0)
 getEditor().setVisible(false);
 return;
 else
 getEditor().setVisible(true);
 by adding the following else if:
 else
 if(table.getItemHeaderWidth()>0&&table.getItemHeaderWidth() >rect.x)
 return;
 Seems to take care of the problem...
 Best Regards
 /Tommy
| Re: Grid Header/Footer: Scrolling [message #61087 is a reply to message #61041] | Tue, 09 December 2008 06:49  |  |
| Eclipse User  |  |  |  |  | Hi again
 I noticed another thing regarding the same issue. In my application I'm
 using a combo boxes in the header controls to handle filtering of the rows.
 The filtering is activated either through selecting a value or by typing
 (i.e keylistener). The selection listener works OK but if I'm using the
 down/up arrows to cycle through the the items in the combobox the row header
 length will adjust itself  (I'm calling viewer.refresh in the keylistener)
 to the longest header text currently shown. This will make the header
 controls bounds fall out of order compared to the columns.
 I've handled this by adding a keylistener to the GridHeaderEditor for the
 control which calls the layout() method and that seems to be working. But a
 better approach might be if this is handled by the GridViewer instead,
 making it set the RowHeader width to the longest text for all elements in
 the GridViewer and not only the ones that are currently displayed. Then the
 RowHeader length will stay fixed as long as the elements don't change.
 BR
 Tommy
 "Tommy" <gusten__79@hotmail.com> wrote in message
 news:ghjbfg$97a$1@build.eclipse.org...
 > https://bugs.eclipse.org/bugs/show_bug.cgi?id=257923
 > "Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
 > news:ghj59p$rd1$1@build.eclipse.org...
 > > Hi Tommy,
 > > Could you file a bug and CC me on it. I've just finished to get a
 > > nightly build up for the HEAD-branch of Grid. Once this is finished I'll
 > > freeze HEAD and make header_footer the HEAD.
 > > Tom
 > > Tommy schrieb:
 > > > Hi
 so
 > far
 > > > it looks
 > regarding
 > > > scrolling
 layout()
 > to
 horizontal
 > bar
 20-30
 > > > columns with a
 > > > scrolling...
 with
 > a
 > > > RowHeader.
 the
 > > > GridHeaderEditor:
 > > >       return;
 > > >     else
 > > >      else
 > > >       return;
 > > > Best Regards
 > > > /Tommy
 > > B e s t S o l u t i o n . at
 > > Tom Schindl                                          JFace-Committer
| Re: Grid Header/Footer: Scrolling [message #592865 is a reply to message #60990] | Mon, 08 December 2008 07:52  |  |
| Eclipse User  |  |  |  |  | Hi Tommy,
 Tom
 Tommy schrieb:
 > Hi
 > it looks
 > scrolling
 > columns with a
 > scrolling...
 > RowHeader.
 > GridHeaderEditor:
 >       return;
 >     else
 >      else
 >       return;
 > Best Regards
 > /Tommy
| Re: Grid Header/Footer: Scrolling [message #592880 is a reply to message #61018] | Mon, 08 December 2008 09:37  |  |
| Eclipse User  |  |  |  |  | https://bugs.eclipse.org/bugs/show_bug.cgi?id=257923
 > Hi Tommy,
 > Tom
 > Tommy schrieb:
 > > Hi
 far
 > > it looks
 regarding
 > > scrolling
 to
 bar
 > > columns with a
 > > scrolling...
 a
 > > RowHeader.
 > > GridHeaderEditor:
 > >       return;
 > >     else
 > >      else
 > >       return;
 > > Best Regards
 > > /Tommy
| Re: Grid Header/Footer: Scrolling [message #592904 is a reply to message #61041] | Tue, 09 December 2008 06:49  |  |
 BR
 Tommy
 > > Hi Tommy,
 > > Tom
 > > Tommy schrieb:
 > > > Hi
 so
 > far
 > > > it looks
 > regarding
 > > > scrolling
 layout()
 > to
 horizontal
 > bar
 20-30
 > > > columns with a
 > > > scrolling...
 with
 > a
 > > > RowHeader.
 the
 > > > GridHeaderEditor:
 > > >       return;
 > > >     else
 > > >      else
 > > >       return;
 > > > Best Regards
 > > > /Tommy
FUDForum. Page generated in 0.08321 seconds
