| Wrong time in CDateTime [message #60320] | Wed, 05 November 2008 09:06 |  |
| Eclipse User  |  |  |  |  | Originally posted by: cold.phusion.gmail.com
 I don't know if this is a known issue, because I couldn't find a similar
 bug in the tracker. I am using the widget in the standard usecase -
 initialize the widget, set pattern, load a proper Date object. The code
 looks like this:
 widget = new CDateTime(composite, CDT.BORDER | CDT.DROP_DOWN
 | CDT.COMPACT);
 widget.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
 widget.setPattern("MM.dd.yyyy h:mm a");
 widget.setSelection(newDate);
 Let's say the newDate is 25.12.2008 17:45. After loading the widget, the
 text fields is set to 25.12.2008 14:58 (correct date, but with the
 current time). I tried to debug the CDateTime itself and it does appear
 to be a bug of some kind:
 ===CDateTime:366 ===
 calendar.setTime(getPickerSelection());
 In this case the calendar has already acquired the correct date and
 time, but reloading them from the picker fails (correct date, wrong time).
 I am using nebula_cdatetime_0.9.0 on MacOS (Leopard) running Ganymede.
 Any comments/suggestions will be appreciated :)
 Alex
FUDForum. Page generated in 0.05616 seconds
