Home » Language IDEs » ServerTools (WTP) » Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML
Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML [message #60136] Tue, 04 January 2005 12:09 Go to next message
Hi everybody,
I am just trying to integrate the wst XML Editor into my project, but I
have some struggling problems.
As lamer solution I just added the class
org.eclipse.wst.xml.ui.StructuredTextEditorXML as contributor class to
the plugins.xml file of my plugin.
Normally this works (tried it with my other plugins), but the
org.eclipse.wst.xml.ui.StructuredTextEditorXML only displays a modal
error message box: "Problems opening Editor - Editor could not be
initialized".
Is this issue known to you? And how do I get clearer debug information
(on the console is nothing - and as well no errors).
Thanks a lot!
...and a happy new year,
Raphael
--snipp--
my tiny test plugins.xml:
<requires>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.jface.text"/>
<import plugin="org.eclipse.ui.editors"/>
<import plugin="org.eclipse.ui.workbench.texteditor"/>
<import plugin="org.eclipse.wst.xml.ui"/>
</requires>
<extension
point="org.eclipse.ui.editors">
<editor
name="Sample XML Editor"
extensions="grenouille"
icon="icons/sample.gif"
contributorClass="org.eclipse.ui.texteditor.BasicTextEditorActionContributor "
class="ra.scs.texteditor_test.editors.XMLEditor"
id="ra.scs.texteditor_test.editors.XMLEditor">
</editor>
<editor
name="TestName"
extensions="g_t"
contributorClass="org.eclipse.wst.xml.ui.actions.ActionContributorXML "
class="org.eclipse.wst.xml.ui.StructuredTextEditorXML"
id="org.eclipse.wst.xml.ui.StructuredTextEditorXML2">
</editor>
--snapp--
Re: Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML [message #60285 is a reply to message #60136] Tue, 04 January 2005 13:37 Go to previous messageGo to next message
On Tue, 04 Jan 2005 18:09:21 +0100, Raphael A. Bauer <raphael.bauer@temis-group.com> wrote:
> And how do I get clearer debug information (on the console is nothing - and as well no errors).
I've opened an enhancement request against the base, long long ago, to not swallow those exceptions,
see (and vote on?) https://bugs.eclipse.org/bugs/show_bug.cgi?id=52081
I've found it useful to set up the debugger to stop on CoreException in such cases and usually can help provide a starting point ... to know where else to set breakpoints, etc.
(Sorry, not sure what the underlying problem might be, off the top of my head).
Re: Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML [message #60306 is a reply to message #60136] Tue, 04 January 2005 14:01 Go to previous messageGo to next message
Raphael,
The first thing to check is if your test files open with the XML
Source Page Editor. The SSE editors require the SSE IDocument
implementation and throw assertion failures if that's not what
they're given for an input. This is one of the big causes for bugs
78340 and 81710.
If it really is XML and just an unrecognized filename extension, you
can try teaching Eclipse that it is XML with this _as a workaround_:
<extension
point="org.eclipse.core.runtime.contentTypes">
<file-association
content-type="org.eclipse.core.runtime.xml"
file-extensions="g_t,grenouille,xmlfoo2"/>
</extension>
Nitin
Re: Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML [message #60964 is a reply to message #60306] Wed, 05 January 2005 04:30 Go to previous messageGo to next message
Nitin Dahyabhai wrote:
> The first thing to check is if your test files open with the XML Source
> Page Editor. The SSE editors require the SSE IDocument implementation
> and throw assertion failures if that's not what they're given for an
> input. This is one of the big causes for bugs 78340 and 81710.
> If it really is XML and just an unrecognized filename extension, you can
> <extension
> <file-association
> </extension>
thanks Nitin, I just tried your workaround and it works perfectly.
Hmm. Although I do not realise what the problem really is.
What I do not understand is, when I use the basic XML Editor delivered
in eclipse as an example (titled Plug-In with an editor) it works fine
with just a "reference" to this editor in the plugins.xml of my other
plugin. But when I use the same mechanism with the
StructuredTextEdtiorXML it does not work (error I described above). With
your workaround it works... I do not get the point.
But many thanks for all replies - good to have a helping community...!
Raphael
Re: Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML [message #61035 is a reply to message #60285] Wed, 05 January 2005 05:46 Go to previous messageGo to next message
I've tracked the problem down, updated the bug report and moved it to
the right component.
Dani
> my head).
Re: Problems using the org.eclipse.wst.xml.ui.StructuredTextEditorXML [message #61133 is a reply to message #60964] Wed, 05 January 2005 07:01 Go to previous message
The symptom really is that the SSE editors *require* the SSE
IDocument implementation and that that implementation is not the
default for your filename extensions. SSE makes it's implementation
the default for common XML file extensions that we know about in
advance, but for unknown extensions like g_t and grenouille the
default remains the Eclipse platform's default.
Keep an eye on bug 78340,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=78340
- Nitin
Previous Topic:Updating JSP Index error
Next Topic:how to deploy a project with multiple depencent projects?
Current Time: Wed Nov 05 12:30:57 EST 2025
Powered by FUDForum. Page generated in 0.04028 seconds
