| How can install the example project of GEF? [message #59904] |
Wed, 29 January 2003 15:15  |
Originally posted by: santtun.jippii.fi
Hi!
I just installed Eclipse and GEF. First problem was this one:
"The wizard can be found at File->New->Other (Control+N), under the
Examples heading". I made a new simple project and I tried to follow the
instructions, but under the "other" I haven't Examples-heading. So what's
wrong and have you any good links, tutorials etc so that I can start with
Eclipse and especially GEF.
Thanks!
Santtu
| Re: How can install the example project of GEF? [message #60162 is a reply to message #60022] |
Thu, 30 January 2003 11:31  |
Originally posted by: santtun_invalid.jippii.fi
I have already installed the separate example project. I unzipped the zip to
eclipse folder, BUT I sitll can't see the example heading. I installed
everything at the same time, Eclipse, GEF, example and runtime environment.
Thanks!
Sami
"Jim Azeltine" <jim.azeltine@indus.com> wrote in message
news:b19sgs$pdo$1@rogue.oti.com...
> You need to also install the separate GEF examples, and restart Eclipse.
> Then when you choose File >> New >> Other you should see the Examples
> wizard, select GEF and you should see Logic Diagram in the right hand
pane.
> Santtu wrote:
> > Hi!
> > Examples heading. I made a new simple project and I tried to follow the
> > instructions, but under the other I Examples-heading. So whats
with
> > Thanks!
> > Santtu
FUDForum. Page generated in 0.04203 seconds
