Home » Language IDEs » C / C++ IDE (CDT) » Problems with cdt installation
| Problems with cdt installation [message #58825] |
Mon, 20 January 2003 09:28  |
Originally posted by: real_james_bond.hotmail.com
I have a problem installing / using (understanding?) a CDT plugin for
Eclipse (ver.: 2.0.2 build id: 200211071448).
I dowlnoaded CDT plugin (stable build: 2003/01/08, for use with R2.0.2,
1.0.1 F2 - Windows), filename:
org.eclipse.cdt-200301080308-win32_1.0.1.bin.dist.zip and unzipped it into
Eclipse directory. Started Eclipse, and I can see CDT plugin listed under
Current Configuration in Update Manager). There is, however, an x sign over
it's icon and the status details reveal, that:
Plugin "org.eclipse.cdt.win32" version "1.0.1" referenced by this feature is
missing
Included feature "org.eclipse.cdt_1.0.1" is missing.
So I cannot build C. What do I have to do to enable it?
| Re: Problems with cdt installation [message #59686 is a reply to message #58825] |
Thu, 23 January 2003 17:38   |
> missing
I had the same problem on WinNT.
I couldn't solve it.
Simply downloaded the extension, and copied files in features and plugins.
It seems the feature is causing problems, plugins installed correctly.
| Re: Problems with cdt installation [message #60154 is a reply to message #59686] |
Wed, 29 January 2003 08:04   |
try some more, it does work.
change the build, and/or do not install the feature/ subdir., only the
plugin.
Radu-Adrian Popescu
CSA, DBA, Developer
Aldratech Ltd.
"Numero 6" <ermannov@despammed.com> wrote in message
news:b0pqu3$ms$1@rogue.oti.com...
into
under
over
feature is
> > missing
| Re: Problems with cdt installation [message #60433 is a reply to message #60154] |
Sat, 01 February 2003 06:58   |
Originally posted by: gjxl.pbtest.myhostdns.org
I have the same problem; also using Eclipse 2.0.2 build 200211071448,
and CDT 1.0.1 GA - Windows. Has anybody made a bug report of this already?
> plugin.
> Radu-Adrian Popescu
> CSA, DBA, Developer
> Aldratech Ltd.
> into
> under
> over
> feature is
>>>missing
| Re: Problems with cdt installation [message #60472 is a reply to message #60433] |
Sat, 01 February 2003 11:56   |
Originally posted by: peterdnight._nospam_yahoo.com
Same problem using M4. But I just ignored it... and everything is still
usable (see my post)...
....peter
"gjxl" <gjxl@pbtest.myhostdns.org> wrote in message
news:b1gbgc$tos$1@rogue.oti.com...
> > plugin.
> > Radu-Adrian Popescu
> > CSA, DBA, Developer
> > Aldratech Ltd.
> > into
> > under
> > over
> > feature is
> >>>missing
plugins.
Current Time: Thu Nov 20 09:19:19 EST 2025
Powered by FUDForum. Page generated in 0.05782 seconds
