Home » Archived » BIRT » Exporting to PDF and Word
Exporting to PDF and Word [message #58794] Fri, 15 July 2005 05:22 Go to next message
Originally posted by: shajee.gmail.com
I have seen that a report generated by BIRT is viewed in the BIRT Viewer
however i want to directly export the generated report to PDF, Word.?
Is it possible to export to MS Word format using BIRT or any alternative
available?
Also if i donot want to use the designer at all and do all the process
programatically then what should be done.?
Thanks in Advance
Re: Exporting to PDF and Word [message #59245 is a reply to message #58794] Fri, 15 July 2005 22:16 Go to previous messageGo to next message
Greeting,
BIRT Release 1.0 supports 2 formats, HTML output as a single HTML page and
paginated output using XML-FO via the Apache FOP project.
You could create the report all the process programatically instead of
using designer. Please take a look at my previous reply to another
question "BIRT API".
Cheers.
Nina Li
Actuate Corporation
Re: Exporting to PDF and Word [message #59294 is a reply to message #59245] Sat, 16 July 2005 06:24 Go to previous message
hi
thanks Nina for the help and the pointer
one of my question which remains unanswered is if i can also export the
generated report to pdf/html without involving the report viewer at all or
if i donot want to save as .rptdesign extension and directly save the
generated as .pdf
regards
Previous Topic:importPackage does not work
Next Topic:Journalist seeking views on BIRT
Current Time: Sun Nov 09 02:13:56 EST 2025
Powered by FUDForum. Page generated in 0.03544 seconds
