Home » Modeling » TMF (Xtext) » How to import existing metamodel (UML)?
| How to import existing metamodel (UML)? [message #58542] |
Tue, 14 July 2009 10:33  |
- Created a new Xtext Project.
- Modified the grammar:
grammar org.xtext.example.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/uml2/3.0.0/UML" as umlMM
generate myDsl "http://www.xtext.org/example/MyDsl"
Model :
(imports+=Import)*
(elements+=MyClassRef)*;
Import :
'import' importURI=STRING;
MyClassRef:
'classRef' referencedClass=[umlMM::Class];
- Copied Ecore.ecore, UML.ecore and UML.genmodel to
.../src/org/xtext/example
- Modified the workflow file:
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value="${runtimeProject}/.." />
<registerGeneratedEPackage value="org.eclipse.uml2.uml.UMLPackage"/>
</bean>
<fragment class="org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment ">
<genModels
value=" platform:/resource/org.xtext.example.mydsl/src/org/xtext/exa mple/UML.genmodel "
</fragment>
- added following dependency to mydsl project: org.eclipse.uml2.uml
- running the workflow is successful!
Are there additional steps to define cross references to UML metamodel
elements? Eclipse reports following errors:
- src-gen/org/xtext/example/myDsl/MyClassRef.java
uml.Class getReferencedClass(); --> uml cannot be resolved to a
type
- src-gen/org/xtext/example/myDsl/impl/MyClassRefImpl.java
- The type MyClassRefImpl must implement the inherited abstract method
MyClassRef.setReferencedClass(Class)
MyClassRef.getReferencedClass()
- src-gen/org/xtext/example/myDsl/impl/MyDslPackageImpl.java
The import uml.UmlPackage cannot be resolved
Ilyas
| Re: How to import existing metamodel (UML)? [message #59100 is a reply to message #59075] |
Wed, 15 July 2009 08:01   |
Hi Sebastian,
thanks for your help.
Here, my workflow:
<workflow>
<property file="org/xtext/example/GenerateMyDsl.properties"/>
<property name="runtimeProject" value="../${projectName}"/>
platformUri="${runtimeProject}/..">
<uriMap from="platform:/plugin/org.eclipse.uml2.uml/model/UML.genmodel "
to=" platform:/resource/org.xtext.example.mydsl/src/org/xtext/exa mple/UML.genmodel "/>
<uriMap from="platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore "
to=" platform:/resource/org.xtext.example.mydsl/src/org/xtext/exa mple/UML.ecore "/>
value="org.eclipse.uml2.codegen.ecore.genmodel.GenModelPackage "/>
<uriMap
from="platform:/plugin/org.eclipse.emf.ecore/model/Ecore.genmodel "
to=" platform:/resource/org.xtext.example.mydsl/src/org/xtext/exa mple/Ecore.genmodel "/>
<uriMap from="platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore "
to=" platform:/resource/org.xtext.example.mydsl/src/org/xtext/exa mple/Ecore.ecore "/>
</bean>
<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner"
directory="${runtimeProject}/src-gen"/>
directory="${runtimeProject}.ui/src-gen"/>
<component class="org.eclipse.xtext.generator.Generator">
<pathRtProject value="${runtimeProject}"/>
<pathUiProject value="${runtimeProject}.ui"/>
<projectNameRt value="${projectName}"/>
<projectNameUi value="${projectName}.ui"/>
<language uri="${grammarURI}" fileExtensions="${file.extensions}">
<!-- Java API to access grammar elements (required by several other
fragments) -->
<fragment
class=" org.eclipse.xtext.generator.grammarAccess.GrammarAccessFragm ent "/>
<!-- generates Java API for the generated EPackages -->
<fragment
<genModels
</fragment>
<!-- the serialization component -->
<fragment
class=" org.eclipse.xtext.generator.parseTreeConstructor.ParseTreeCo nstructorFragment "/>
<!-- a custom ResourceFactory for use with EMF -->
<fragment
class=" org.eclipse.xtext.generator.resourceFactory.ResourceFactoryF ragment "
fileExtensions="${file.extensions}"/>
<!-- the following fragment tries to use the Antlr Generator fragment
which can be installed via update manager from
http://download.itemis.com/updates -->
<fragment class="org.eclipse.xtext.generator.AntlrDelegatingFragment" />
<!-- If you don't want to use the Antlr fragment for some reason,
remove the antlr fragment and uncomment the packrat parser fragment below.
<fragment
class="org.eclipse.xtext.generator.parser.PackratParserFragment "/>
<!-- java-based API for validation -->
<fragment
class=" org.eclipse.xtext.generator.validation.JavaValidatorFragment ">
<composedCheck
value="org.eclipse.xtext.validation.ImportUriValidator"/>
</fragment>
<!-- scoping API -->
<fragment
class="org.eclipse.xtext.generator.scoping.JavaScopingFragment "/>
<!-- formatter API -->
<fragment
class="org.eclipse.xtext.generator.formatting.FormatterFragment "/>
<!-- labeling API -->
<fragment
class=" org.eclipse.xtext.ui.generator.labeling.LabelProviderFragmen t "/>
<!-- outline API -->
<fragment
class="org.eclipse.xtext.ui.generator.outline.TransformerFragment "/>
<fragment
class=" org.eclipse.xtext.ui.generator.outline.OutlineNodeAdapterFac toryFragment "/>
<!-- java-based API for content assistance -->
<fragment
class=" org.eclipse.xtext.ui.generator.contentAssist.JavaBasedConten tAssistFragment "/>
<!-- the following fragment tries to use the Antlr based content assist
fragment which can be downloaded from http://www.itemis.com
and will be ignored if it's not available. -->
<fragment
class="org.eclipse.xtext.generator.DelegatingGeneratorFragment "
delegate="de.itemis.xtext.antlr.XtextAntlrUiGeneratorFragment "
message="You are generating without ANTLR. It is highly recommended to
download and use the plugin 'de.itemis.xtext.antlr' \n\t using the update
site http://download.itemis.com/updates/milestones.">
</fragment>
<!-- <fragment
class="de.itemis.xtext.antlr.XtextAntlrUiGeneratorFragment"/ > -->
</language>
</component>
</workflow>
Manifest of org.xtext.example.mydsl
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: org.xtext.example.mydsl
Bundle-Vendor: My Company
Bundle-Version: 1.0.0
Bundle-SymbolicName: org.xtext.example.mydsl; singleton:=true
Eclipse-RegisterBuddy: org.eclipse.xtext.log4j
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.xtext,
org.eclipse.xtext.generator;resolution:=optional,
de.itemis.xtext.antlr;resolution:=optional,
org.apache.commons.logging;resolution:=optional,
org.eclipse.emf.codegen.ecore;resolution:=optional,
org.eclipse.xtext.log4j;resolution:=optional,
org.eclipse.emf.mwe.utils;resolution:=optional,
org.eclipse.emf.mwe.core;resolution:=optional,
com.ibm.icu;resolution:=optional,
org.eclipse.xtext.xtend;resolution:=optional,
org.eclipse.uml2.uml;bundle-version="3.0.0",
org.eclipse.uml2;bundle-version="3.0.0",
org.eclipse.xtext.util,
org.eclipse.emf.ecore,
org.eclipse.emf.common,
org.antlr.runtime,
org.eclipse.uml2.codegen.ecore;bundle-version="1.5.0"
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Export-Package: org.xtext.example,
org.xtext.example.services,
org.xtext.example.myDsl,
org.xtext.example.myDsl.impl,
org.xtext.example.myDsl.util,
org.xtext.example.parseTreeConstruction,
org.xtext.example.parser.antlr,
org.xtext.example.validation
| Re: How to import existing metamodel (UML)? [message #59150 is a reply to message #59100] |
Wed, 15 July 2009 08:26   |
Hi Ilyas,
mwe and Manifest look fine, but the content of UML.ecore and
UML.genmodel seem to differ from mine.
I've taken the files from:
eclipse/plugins/org.eclipse.uml2.uml_3.0.0.v200905151700.jar
If you replace your somehow corrupt files with the ones from the jar,
everything should work like a charm.
Sebastian
Am 15.07.2009 14:01 Uhr, schrieb Ilyas Keser:
> Hi Sebastian,
> Here, my workflow:
> <workflow>
> <uriMap
> </bean>
> fragments) -->
> <fragment
> <genModels
> </fragment>
> <fragment
> <fragment
> <!-- If you don't want to use the Antlr fragment for some reason, remove
> <fragment
> <fragment
> <composedCheck value="org.eclipse.xtext.validation.ImportUriValidator"/>
> </fragment>
> <fragment class="org.eclipse.xtext.generator.scoping.JavaScopingFragment "/>
> <fragment
> <fragment
> <fragment
> <fragment
> <fragment
> fragment which can be downloaded from http://www.itemis.com and will be
> <fragment
> update site http://download.itemis.com/updates/milestones.">
> </fragment>
> <!-- <fragment
> </language>
> </component>
> </workflow>
> org.antlr.runtime,
| Re: How to import existing metamodel (UML)? [message #59670 is a reply to message #59567] |
Thu, 16 July 2009 16:25   |
Hi Miles,
please find my answer below.
Am 16.07.2009 20:31 Uhr, schrieb Miles Parker:
> On 2009-07-15 01:25:44 -0700, Sebastian Zarnekow
> <Sebastian.Zarnekow@itemis.de> said:
>> Please try something like this intead:
>> <uriMap
> <uriMap
> </bean>
> Sebastian,
> Can
> you explain what is accomplished by the last two lines? Is this an issue
> for UML only? I haven't found any problem w/ not using them for my ecore
> imports (but perhaps that explains some linking issues I've been having)
> and the workflow builds just fine.
The UML genmodel refers to other models via platform:/plugin uris. These
cannot be resolved in plain vanilla java runtimes, as they rely on OSGi
und extension point mechanisms. EMF allows to map arbitrary uri to other
uris. This is what this two lines do. When ommitted, you may end up with
obscure NPEs due to unresolved EMF proxies.
> As you mention below, I can't think of why you would want or need to
> keep the imported ecore models in your calling project...?
That's right. I'ld prefer archive uris and refer to the contents of the
uml jars directly. However, I do not know the root directory of your
Eclipse installation and therefore cannot provide a valid mwe setup. To
make it as easy as possible, I suggested to copy the existing model
files into the project and refer to them via platform:/resource uri.
If anything remains unclear please don't hesitate to ask further questions.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
| Re: How to import existing metamodel (UML)? [message #636247 is a reply to message #59789] |
Fri, 29 October 2010 16:34   |
Hi guys,
I'm trying to import UML models use this same approach. I also found some related articles:
http://chilifreak.wordpress.com/2009/11/06/xtext-using-uml-m odels/
http://www.virage-it.be/2010/05/the-definition-and-the-imple mentation-of-the-software-analysis-dsl-using-xtext/
But the reference to the model doesn't seem to be working.
I'm using the UML.ecore and UML.genmodel from the "org.eclipse.uml2.uml_3.1.0.v201006071150.jar". And using the Ecore.ecore and Ecore.genmodel from the "org.eclipse.emf.ecore_2.6.0.v20100614-1136.jar".
I'm also using the Eclipse (Helios) distribution with Xtext 1.0.1, from itemis.
My workflow.
module org.xtext.example.mydsl.MyDsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/example/mydsl/MyDsl.xtext"
var file.extensions = "mydsl"
var projectName = "org.xtext.example.mydsl"
var runtimeProject = "../${projectName}"
Workflow {
bean = StandaloneSetup {
platformUri = "${runtimeProject}/.."
registerGeneratedEPackage = "org.eclipse.uml2.uml.UMLPackage"
registerGeneratedEPackage = "org.eclipse.uml2.codegen.ecore.genmodel.GenModelPackage"
uriMap = {
from = "platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore"
to = "platform:/resource/org.xtext.example.mydsl/model/Ecore.ecore"
uriMap = {
from = "platform:/plugin/org.eclipse.emf.ecore/model/Ecore.genmodel"
to = "platform:/resource/org.xtext.example.mydsl/model/Ecore.genmodel"
component = DirectoryCleaner {
directory = "${runtimeProject}/src-gen"
directory = "${runtimeProject}.ui/src-gen"
component = Generator {
pathRtProject = runtimeProject
pathUiProject = "${runtimeProject}.ui"
projectNameRt = projectName
projectNameUi = "${projectName}.ui"
language = {
uri = grammarURI
fileExtensions = file.extensions
// Java API to access grammar elements (required by several other fragments)
fragment = grammarAccess.GrammarAccessFragment {}
// generates Java API for the generated EPackages
fragment = ecore.EcoreGeneratorFragment {
// referencedGenModels = "uri to genmodel, uri to next genmodel"
genModels = "platform:/resource/org.xtext.example.mydsl/model/UML.genmodel"
// the serialization component
fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
// a custom ResourceFactory for use with EMF
fragment = resourceFactory.ResourceFactoryFragment {
// The antlr parser generator fragment.
fragment = parser.antlr.XtextAntlrGeneratorFragment {
// options = {
// backtrack = true
// java-based API for validation
fragment = validation.JavaValidatorFragment {
composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// registerForImportedPackages = true
// scoping and exporting API
// fragment = scoping.ImportURIScopingFragment {}
// fragment = exporting.SimpleNamesFragment {}
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
// formatter API
fragment = formatting.FormatterFragment {}
// labeling API
fragment = labeling.LabelProviderFragment {}
// outline API
fragment = outline.TransformerFragment {}
fragment = outline.OutlineNodeAdapterFactoryFragment {}
fragment = outline.QuickOutlineFragment {}
// quickfix API
fragment = quickfix.QuickfixProviderFragment {}
// content assist API
fragment = contentAssist.JavaBasedContentAssistFragment {}
// generates a more lightweight Antlr parser and lexer tailored for content assist
fragment = parser.antlr.XtextAntlrUiGeneratorFragment {}
// project wizard (optional)
// fragment = projectWizard.SimpleProjectWizardFragment {
// generatorProjectName = "${projectName}.generator"
// modelFileExtension = file.extensions
My manifest.
org.eclipse.emf.mwe2.launch;resolution:=optional,
org.antlr.runtime,
org.eclipse.uml2.codegen.ecore;bundle-version="1.6.0",
org.eclipse.uml2.uml;bundle-version="3.1.0"
Import-Package: org.apache.log4j
Export-Package: org.xtext.example.mydsl,
org.xtext.example.mydsl.services,
org.xtext.example.mydsl.myDsl,
org.xtext.example.mydsl.myDsl.impl,
org.xtext.example.mydsl.myDsl.util,
org.xtext.example.mydsl.parseTreeConstruction,
org.xtext.example.mydsl.parser.antlr,
org.xtext.example.mydsl.parser.antlr.internal,
org.xtext.example.mydsl.validation
My grammar.
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
import 'http://www.eclipse.org/uml2/3.0.0/UML' as umlMM
Model :
(imports+=Import)*
(rules+=Rule)*;
Import :
Rule:
'references' umlClass=[umlMM::Class];
Thanks for any help.
Current Time: Wed Oct 29 20:44:10 EDT 2025
Powered by FUDForum. Page generated in 0.07174 seconds
