Home » Modeling » GMF (Graphical Modeling Framework) » how to create several elements and connections in between in single a Command
how to create several elements and connections in between in single a Command [message #58472] Mon, 02 October 2006 22:36 Go to next message
Originally posted by: vcciubot.uwaterloo.ca
Hi all,
In my model, if a connection traverses structural hierarchies then it must
be broken down into sub-segments that begin and end on the frontiers of
the spanned elements.
One solution would be to configure the created connection to create the
intermediary elements and subsegments, but in this case an inconsistent
connection will still get created.
I need another approach, but I don't know how to create connections
between non existing edit parts. Is there some example code I should look
at?
thank you
Vlad
Re: how to create several elements and connections in between in single a Command [message #59010 is a reply to message #58472] Tue, 03 October 2006 19:36 Go to previous message
Solved my problem by modifying GraphicalNodeEditPolicy to use the model
only and rely on CanonicalConnectionEditPolicy to create the view elements.
On Mon, 02 Oct 2006 22:36:17 -0400, Vlad Ciubotariu wrote:
> Hi all,
> at?
> thank you
> Vlad
Previous Topic:Figures in diagram popup menu
Next Topic:Re: Multiple diagrams for the same EMF model
Current Time: Tue Oct 21 20:44:25 EDT 2025
Powered by FUDForum. Page generated in 0.05550 seconds
