Home » Eclipse Projects » Eclipse Platform » Calling refresh when a java program ends
Calling refresh when a java program ends [message #57723] Sat, 31 May 2003 17:43 Go to next message
Originally posted by: elik.backweb.com
I have a launched program that, when done, adds files to the my project.
This program is a java program so I used
"AbstractJavaLaunchConfigurationDelegate".
My Q is: how do I know when the program is finished. Can i register to an
event on the launch object?
elik
Re: Calling refresh when a java program ends [message #57799 is a reply to message #57723] Sat, 31 May 2003 21:29 Go to previous message
Originally posted by: darin_swanson.oti.com
Register as an IDebugEventSetListener with the debug plugin.
You can perform the refresh when you get the DebugEvent.TERMINATE for the
IProcess(es)associated with your ILaunch object.
See the interface(s) for more details.
HTH
Darins
"Elik" <elik@backweb.com> wrote in message
news:bbb7m4$ukm$1@rogue.oti.com...
> Thanks
> elik
Previous Topic:VerifyEvent and keycode MacOSX
Next Topic:Eclipse survival
Current Time: Fri Nov 07 21:37:58 EST 2025
Powered by FUDForum. Page generated in 0.03414 seconds
