Home » Eclipse Projects » GEF » Connection Layer
Connection Layer [message #57540] Thu, 23 January 2003 09:36 Go to next message
As I have a number of figures that I expand and contract I decided to add
the connections to the figure's pane by overriding the method
getLayer(Object layerId). This way I could take advantage of clipping when
the figure is contracted. This works fine no problems until I select a
connection. I suspect that the code that handles bendpoints is referencing
the CONNECTION_LAYER as the bendpoints are all offset from the connections
by the distance of the figure from the origin. Is this likely to be what is
happening? and if my diagnosis is correct is it possible to direct the
bendpoint handling to the figure's pane.
John.
Re: Connection Layer [message #58190 is a reply to message #57540] Sun, 26 January 2003 15:35 Go to previous message
I have this almost working in that I can create bendpoints and update the
current connections, but I am still getting the feedback offset from the
connections. I presume need to translate the coordinates somewhere. I'm
just not sure where. Any ideas?
John.
"John Howard" <john.howard9@btinternet.com> wrote in message
news:b0otmd$7sv$1@rogue.oti.com...
when
referencing
is
> John.
Previous Topic:Emulate Tab Panel in GEF
Next Topic:GEF draw2D Tabbed Pane
Current Time: Sat Nov 08 13:32:18 EST 2025
Powered by FUDForum. Page generated in 0.02770 seconds
