Home » Modeling » GMF (Graphical Modeling Framework) » permanent synchronizing GMF and EMF-Editor that use the same file as modelfile.
permanent synchronizing GMF and EMF-Editor that use the same file as modelfile. [message #57371] Fri, 29 September 2006 03:04 Go to next message
Hi folks,
I'm not quite sure if this is really a gmf-question, maybe its emf, but
who knows if someone in this forum could provide help.
I've got the EMF-generated editor running to edit instances of my Model.
I've got a GMF-generated graphical editor running that uses the file of
the emf-editor as a modelfile and the instances of the emf-editor to
work with and change.(I use a selection of the emf-editor by doubleclick
to open the graphical editor with exactly this selection, using the root
of the selection as DiagramRoot and the selection's subnodes as nodes
for the diagram to display)
What i want to do now is some kind of autosave or permanent
synchronization, because I've got some viewers linked to the EMF-Editor
and showing the editor-input, that should always be uptodate.
By now synchronization only takes place if I save the current state of
the graphical editor. Is there a way to perform the save-action
programmatically without user interaction?
I'd be pleased for any help
Thanks Alex Haag
Re: permanent synchronizing GMF and EMF-Editor that use the same file as modelfile. [message #58268 is a reply to message #57371] Mon, 02 October 2006 09:45 Go to previous messageGo to next message
Hello Alex,
Please try reading newsgroup archive - this question was discussed a numer
of times in past. For example:
http://www.eclipse.org/search/search.cgi?q=gmf+shared+editin g+domain&cmd=Search%21&form=extended&wf=574a74&a mp;ps=10&m=all&t=5&ul=&wm=wrd&t=News& ;t=Mail
or
http://www.eclipse.org/search/search.cgi?q=gmf+synchronizati on&cmd=Search%21&form=extended&wf=574a74&ps= 10&m=all&t=5&ul=&wm=wrd&t=News&t=Mai l
Alex Shatalin
Re: permanent synchronizing GMF and EMF-Editor that use the same file as modelfile. [message #58313 is a reply to message #57371] Mon, 02 October 2006 09:59 Go to previous message
Originally posted by: vcciubot.uwaterloo.ca
To extend the question, is it possible to share an editing domain between
the GMF editor and the EMF generated editor, create the editing domain on
the GMF side and pass some sort of proxy to the EMF editor?
Basically, if I wrap an EMF Command into an AbstractEMFOperation, can this
command be executed on the GMF editing domain?
thank you
vlad
On Fri, 29 Sep 2006 09:04:21 +0200, Alex Haag wrote:
> Hi folks,
> Thanks Alex Haag
Previous Topic:Pulling attribute from a referenced object
Next Topic:Bug in Ecore Editor, assotiation between Eclass and EEnum
Current Time: Sun Nov 16 01:16:29 EST 2025
Powered by FUDForum. Page generated in 0.05252 seconds
