Home » Eclipse Projects » Mylyn » How to contribute new Generic Web templates
How to contribute new Generic Web templates [message #56855] Wed, 27 August 2008 13:15 Go to next message
The generic web connector provides templates for a few types of
repositories. After spending a few days refining the urls and query
patterns for my repository, I would like to share this with the rest of the
team with something more convenient that copy/paste.
How can I add a new repository template to the generic web connector?
I've been looking for an extension point that I could contribute to, but no
luck.
I've searched the jars looking for an xml config or something, but again no
luck.
I don'm mind writing a plug-in if I have to, but cannot find the extension
point I need to use.
Michael
Re: How to contribute new Generic Web templates [message #57300 is a reply to message #56855] Mon, 08 September 2008 11:40 Go to previous messageGo to next message
I'll be happy to read the manual, but could not find anything related. I
may have overlooked something. Could someone point me to appropriate docs?
Michael
"Michael Giroux" <michael.giroux@bull.com> wrote in message
news:g9422v$9t5$1@build.eclipse.org...
> the team with something more convenient that copy/paste.
> no luck.
> no luck.
> Thanks
> Michael
Re: How to contribute new Generic Web templates [message #57426 is a reply to message #57300] Tue, 09 September 2008 13:28 Go to previous messageGo to next message
Take a look at the plugin.xml of the org.eclipse.mylyn.web.tasks plug-in:
<extension
point="org.eclipse.mylyn.tasks.core.templates">
<repository
repositoryKind="web"
label="Subclipse (IssueZilla)"
urlRepository="http://subclipse.tigris.org/issues"
urlTask="${serverUrl}/show_bug.cgi?id="
urlNewTask="${serverUrl}/enter_bug.cgi?component=subclipse"
urlTaskQuery=" ${serverUrl}/buglist.cgi?issue_status=NEW&amp;issue_stat us=STARTED&amp;issue_status=REOPENED&amp;order=Issue +Number ">
<attribute name="queryPattern"
value="&lt;a href=&quot;show_bug.cgi\?id\=(
+?)&quot;&gt;.+?&lt;span class=&quot;summary&quot;&gt;(.+?)&lt;/span& amp;gt; "/>
</repository>
</extension>
If your plug-in specifies a template that has the repositoryKind set
to "web" it should show up in the repository properties dialog.
Steffen
> docs?
> Michael
>> no luck.
>> no luck.
>> extension point I need to use.
>> Thanks
>> Michael
Re: How to contribute new Generic Web templates [message #57552 is a reply to message #57426] Tue, 09 September 2008 17:14 Go to previous messageGo to next message
Exactly what I needed. I'll dig in.
Michael
"Steffen Pingel" <steffen.pingel@tasktop.com> wrote in message
news:ga6bn0$2gp$5@build.eclipse.org...
> <extension
> <repository
> </repository>
> </extension>
> Steffen
>> docs?
>> Michael
>>> no luck.
>>> no luck.
>>> Thanks
>>> Michael
Re: How to contribute new Generic Web templates [message #57577 is a reply to message #57426] Tue, 09 September 2008 17:47 Go to previous messageGo to next message
Building the plugin was quite simple. Thanks.
Michael
> <extension
> <repository
> </repository>
> </extension>
> Steffen
>> docs?
>> Michael
>>> no luck.
>>> no luck.
>>> Thanks
>>> Michael
Re: How to contribute new Generic Web templates [message #57601 is a reply to message #57577] Tue, 09 September 2008 18:51 Go to previous messageGo to next message
BTW, if you only need to share your settings, you can simply export
task query. It is exported together with the task repository
configuration. So, other users can import it and edit settings if necessary.
regards,
Eugene
> Michael
>> <extension
>> <repository
>> </repository>
>> </extension>
>> Steffen
>>> docs?
>>> Michael
>>>> no luck.
>>>> no luck.
>>>> Thanks
>>>> Michael
Re: How to contribute new Generic Web templates [message #57650 is a reply to message #57601] Wed, 10 September 2008 12:24 Go to previous messageGo to next message
Thanks Eugene. I noticed the export feature after posting the original
question.
Michael
"Eugene Kuleshov" <eu@md.pp.ru> wrote in message
news:ga6ukn$o07$1@build.eclipse.org...
> BTW, if you only need to share your settings, you can simply export task
> query. It is exported together with the task repository configuration. So,
> regards,
> Eugene
Re: How to contribute new Generic Web templates [message #58392 is a reply to message #56855] Thu, 25 September 2008 18:42 Go to previous messageGo to next message
Will you be able to help me out connecting to my repository thru the
My web server use windows authentication. I used
"http://.....com/project/bug" in the "Server"; This is our internal server.
User id, password - I gave my windows userid/password
In the advanced configuration:
Query Url: I used "http://.../project/bug/default.aspx?bug_id=2001"
But when I query, I get the follwoing error:
Failed to parse RSS feed: "Invalid XML: Error on line 7: The element type
"BR" must be terminated by the matching end-tag "</BR>"."
Sunanda
Re: How to contribute new Generic Web templates [message #58412 is a reply to message #58392] Fri, 26 September 2008 01:35 Go to previous messageGo to next message
On 09/26/08 00:42, Menon wrote:
> Hi Will you be able to help me out connecting to my repository thru the
> In the advanced configuration: Query Url: I used
> type "BR" must be terminated by the matching end-tag "</BR>"."
Hi Sunanda,
please check whether the query pattern is empty. In that special case, the result returned from the
web server is tried to be parsed as RSS which fails in your case.
Please check the docs in the wiki how to setup the query pattern. It is used to extract the bug ids
from the web page.
Cheers, Jörg
Re: How to contribute new Generic Web templates [message #58447 is a reply to message #58412] Fri, 26 September 2008 15:54 Go to previous messageGo to next message
Thanks Jorg for your advice. I used the URL below to seach all my bugs
from the browser and it works.BUt when I use the same URL in the "Query
URL" and try to ope, I get a "Network Error (tcp_error) " . When do
synchronize, I do not get any error, but it does not show any records. I
have "Integrated windows authentication" for this, so I provided my
domain\username and password instead of anonymous access. The web server
is in the intranet.
Query URL:
http://.../search/result.aspx?reloadf=2&focus=bug&us r_query_id=224&global_list=&userid_list=srmenon1& ;crofoc=&pgf=&mydiv1tb=&mydiv2tb=1
( I looked at the "view Source" in the browser of the results page- it
shows <a href="/..../default.aspx?bug_id=3772">3772</a> )
So the query pattern I usedis
<a href="/..../bug/default.aspx?bug_id=(.+?)</a>
When I do a "preview" using the above, then it says No matching results
found. Check Query regex
I tried to do "Open" with Query Url in teh advanced configurartion, I get
Sunanda
Re: How to contribute new Generic Web templates [message #58518 is a reply to message #58412] Fri, 26 September 2008 19:09 Go to previous messageGo to next message
I have identified my problem. Our web server is using NTLM authentication,
So it is not able to connect. Is it possible to use generic web connector
if the web server uses NTLM authentication?
Sunanda
Re: How to contribute new Generic Web templates [message #58525 is a reply to message #58518] Fri, 26 September 2008 22:45 Go to previous message
This FAQ entry provides details about support the for NTLM authentication:
http://wiki.eclipse.org/Mylyn/FAQ#NTLM_authentication
Steffen
> Hi
> Thanks
> Sunanda
Re: How to contribute new Generic Web templates [message #593051 is a reply to message #56855] Mon, 08 September 2008 11:40 Go to previous message
Michael
> no luck.
> no luck.
> Thanks
> Michael
Re: How to contribute new Generic Web templates [message #593100 is a reply to message #57300] Tue, 09 September 2008 13:28 Go to previous message
<extension
<repository
</repository>
</extension>
Steffen
> docs?
> Michael
>> no luck.
>> no luck.
>> Thanks
>> Michael
Re: How to contribute new Generic Web templates [message #593141 is a reply to message #57426] Tue, 09 September 2008 17:14 Go to previous message
Michael
> <extension
> <repository
> </repository>
> </extension>
> Steffen
>> docs?
>> Michael
>>> no luck.
>>> no luck.
>>> Thanks
>>> Michael
Re: How to contribute new Generic Web templates [message #593152 is a reply to message #57426] Tue, 09 September 2008 17:47 Go to previous message
Michael
> <extension
> <repository
> </repository>
> </extension>
> Steffen
>> docs?
>> Michael
>>> no luck.
>>> no luck.
>>> Thanks
>>> Michael
Re: How to contribute new Generic Web templates [message #593165 is a reply to message #57577] Tue, 09 September 2008 18:51 Go to previous message
regards,
Eugene
> Michael
>> <extension
>> <repository
>> </repository>
>> </extension>
>> Steffen
>>> docs?
>>> Michael
>>>> no luck.
>>>> no luck.
>>>> Thanks
>>>> Michael
Re: How to contribute new Generic Web templates [message #593188 is a reply to message #57601] Wed, 10 September 2008 12:24 Go to previous message
question.
Michael
> regards,
> Eugene
Re: How to contribute new Generic Web templates [message #593498 is a reply to message #56855] Thu, 25 September 2008 18:42 Go to previous message
Sunanda
Re: How to contribute new Generic Web templates [message #593506 is a reply to message #58392] Fri, 26 September 2008 01:35 Go to previous message
Hi Sunanda,
from the web page.
Cheers, Jörg
Re: How to contribute new Generic Web templates [message #593526 is a reply to message #58412] Fri, 26 September 2008 15:54 Go to previous message
is in the intranet.
Query URL:
Sunanda
Re: How to contribute new Generic Web templates [message #593546 is a reply to message #58412] Fri, 26 September 2008 19:09 Go to previous message
Sunanda
Re: How to contribute new Generic Web templates [message #593551 is a reply to message #58518] Fri, 26 September 2008 22:45 Go to previous message
Steffen
> Hi
> Thanks
> Sunanda
Previous Topic:Gerneric Connector
Next Topic:web connector - how to specify common patterns as parameters
Current Time: Wed Nov 19 07:27:10 EST 2025
Powered by FUDForum. Page generated in 0.08215 seconds
