Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless signing just our JARs
Headless signing just our JARs [message #56826] Fri, 17 April 2009 15:46 Go to next message
We have an RCP Product based on 3.5M6 SDK that we build headlessly. I can
turn on JAR signing with the following build.properties:
jarProcessor.unsign = true
signJars=true
sign.alias=<alias>
sign.keystore=<path to keystore>
sign.storepass=<storepass>
sign.keypass=<keypass>
This builds our product (and incidentally its P2 repository) but results
in replacement of most Eclipse signatures with our own. I would rather
leave Eclipse signatures alone, as they are trusted and replacing them
takes time. Is there a straightforward way to have PDE just sign our JARs,
resulting in a signed Product and its repository?
Mike
Re: Headless signing just our JARs [message #57066 is a reply to message #56826] Mon, 20 April 2009 04:20 Go to previous messageGo to next message
Originally posted by: mickael.istria.openwide.fr
> can turn on JAR signing with the following build.properties:
> signJars=true
> sign.alias=<alias>
> JARs, resulting in a signed Product and its repository?
> Mike
Hello Mike,
Maybe this page can help you to exclude Eclipse jars from signing:
http://wiki.eclipse.org/JarProcessor_Options using "sign.excludes" option.
Hope that helps
Mickael
Re: Headless signing just our JARs [message #66560 is a reply to message #57066] Thu, 02 July 2009 14:14 Go to previous messageGo to next message
I'm interested in the same thing. sign.excludes looks promising, only I
don't want to have to write a property entry that has a comma delimited
list of every JAR that is not ours. Especially when that list might
change if I add another Eclipse dependency in a feature somewhere. It
doesn't look like wildcards are supported. Is there any other magic I
can use here?
Ben
>> signJars=true
>> sign.alias=<alias>
>> results in replacement of most Eclipse signatures with our own. I
>> would rather leave Eclipse signatures alone, as they are trusted and
>> replacing them takes time. Is there a straightforward way to have PDE
>> just sign our JARs, resulting in a signed Product and its repository?
>> Thanks,
>> Mike
> Hello Mike,
> Hope that helps
> Mickael
Re: Headless signing just our JARs [message #66752 is a reply to message #66560] Sun, 05 July 2009 12:21 Go to previous messageGo to next message
A follow-up on this one..
I've got an Ant task that will create a properties file with
sign.excludes set to all the JARs I want to exclude. I realized that the
sign.excludes property has to be in a pack.properties file, not in the
main build.properties. This is a bit difficult to achieve without
creating a custom PDE build, since pack.properties has to live in the
"input" directory to JarProcessor, which is the repository that gets
created when I turn on p2.gathering. Getting the properties file in the
right place is probably doable so I will leave that alone for now..
For whatever reason, I'm not seeing the JARs get excluded. If I step
through JarProcessor it only seems to look at sign.excludes as its
processing individual JAR file entries, not the JARs themselves.
Am I misunderstanding how sign.excludes is supposed to work? Is it still
supported on 3.5? Is there a better way to do this?
Any help here would be appreciated
Cheers
Ben
> can use here?
> Thanks
> Ben
Re: Headless signing just our JARs [message #68286 is a reply to message #66752] Thu, 16 July 2009 21:14 Go to previous message
Might as well close the loop on this..
Rather than using JarProcessor and the signing properties already
available in build.properties, I decided to go the "customAssembly"
route. I'm hooking into "post.gather.bin.parts", and I just call the Ant
signJar task directly. I pass it a fileset, rooted at the
buildRepo/plugins directory, that only includes my company's JARs.
Hope that helps someone else.
Cheers
Ben
> Cheers
> Ben
>> I don't want to have to write a property entry that has a comma
>> delimited list of every JAR that is not ours. Especially when that
>> list might change if I add another Eclipse dependency in a feature
>> somewhere. It doesn't look like wildcards are supported. Is there any
>> other magic I can use here?
>> Thanks
>> Ben
Re: Headless signing just our JARs [message #595883 is a reply to message #56826] Mon, 20 April 2009 04:20 Go to previous message
> signJars=true
> sign.alias=<alias>
> Mike
Hello Mike,
Hope that helps
Mickael
Re: Headless signing just our JARs [message #598932 is a reply to message #57066] Thu, 02 July 2009 14:14 Go to previous message
can use here?
Ben
>> signJars=true
>> sign.alias=<alias>
>> Thanks,
>> Mike
> Hello Mike,
> Hope that helps
> Mickael
Re: Headless signing just our JARs [message #599009 is a reply to message #66560] Sun, 05 July 2009 12:21 Go to previous message
Cheers
Ben
> can use here?
> Thanks
> Ben
Re: Headless signing just our JARs [message #599474 is a reply to message #66752] Thu, 16 July 2009 21:14 Go to previous message
Cheers
Ben
> Cheers
> Ben
>> Thanks
>> Ben
Previous Topic:Semantic highlighting
Next Topic:New expert help, runtime plug-in error
Current Time: Fri Nov 07 07:30:47 EST 2025
Powered by FUDForum. Page generated in 0.04586 seconds
