Home » Modeling » M2T (model-to-text transformation) » Xpand: invoking getValue() leads to an invocation target exception
Xpand: invoking getValue() leads to an invocation target exception [message #56776] Mon, 02 February 2009 07:48 Go to next message
I'm currently working on a template parsing UML2 activity diagrams. now
trying to invoke getValue on an element to get a tagged value from an
applied stereotype on that same element from inside the template file
yields to an invocation target exception anyone got a clue why this
occurs? Are there any special imports or classpath modifications to be
considered?
thanks in advance!
cheers,
philipp
Re: Xpand: invoking getValue() leads to an invocation target exception [message #56803 is a reply to message #56776] Mon, 02 February 2009 14:54 Go to previous messageGo to next message
Philipp Zech schrieb:
> considered?
> thanks in advance!
> cheers,
> philipp
resolved
Re: Xpand: invoking getValue() leads to an invocation target exception [message #57084 is a reply to message #56803] Sun, 08 February 2009 07:45 Go to previous message
>> now trying to invoke getValue on an element to get a tagged value from
>> an applied stereotype on that same element from inside the template
>> file yields to an invocation target exception anyone got a clue why
>> this occurs? Are there any special imports or classpath modifications
>> to be considered?
>> thanks in advance!
>> cheers,
>> philipp
> resolved
For reasons of completeness, the error occurred as i wrote down the name
of the tagged value whose value i wanted to received with a starting
upper case letter and not lower case.
Previous Topic:OAW: issues with outlet path declaration in generator.oaw file
Next Topic:calling a java extension from inside an Xpand file
Current Time: Fri Nov 14 03:36:58 EST 2025
Powered by FUDForum. Page generated in 0.04498 seconds
