Home » Language IDEs » Java Development Tools (JDT) » Can I add a copyifnewer to ant1.4
Can I add a copyifnewer to ant1.4 [message #5042] Thu, 24 April 2003 17:08 Go to next message
Originally posted by: susan_sugao.hotmail.com
I am trying to using ant to copy files. The selected files are based on
the certain timestamp and other name patterns. Because the ant1.4 doesn't
support SELECTOR like ant1.5, can I add a class (copyifnewer.java) to
support this requirement? If possible by adding a plugin? Do you know when
eclipse will
add ant1.5 to the product?
Thanks.
Re: Can I add a copyifnewer to ant1.4 [message #5111 is a reply to message #5042] Thu, 24 April 2003 17:25 Go to previous messageGo to next message
For quite some time Eclipse has been on the Ant 1.5.* stream.
Eclipse 2.1 is Ant 1.5.2
The latest integration build (I20030422) is Ant 1.5.3
HTH
Darins
"Susan" <susan_sugao@hotmail.com> wrote in message
news:b89jni$pn3$1@rogue.oti.com...
> eclipse will
> Thanks.
Re: Can I add a copyifnewer to ant1.4 [message #5180 is a reply to message #5111] Thu, 24 April 2003 17:44 Go to previous messageGo to next message
Hi Darin,
I am using Eclipse through the Websphere studio application developer
which use the Ant 1.4+. Could you please tell me if I can add the
copyifnewer function to ANT1.4 through a plug in to WSAD(internal Eclipse)?
> HTH
> Darins
> > eclipse will
> > Thanks.
Re: Can I add a copyifnewer to ant1.4 [message #5248 is a reply to message #5180] Thu, 24 April 2003 18:13 Go to previous message
I did that on your crosspost to the Ant mailing list:
For others:
http://eclipsewiki.swiki.net/118#ant15
HTH
Darins
"susan" <susan_sugao@hotmail.com> wrote in message
news:b89ls8$r50$1@rogue.oti.com...
> Hi Darin,
Eclipse)?
> > HTH
> > Darins
on
doesn't
when
> > > eclipse will
> > > Thanks.
Previous Topic:projects and checked-out CVS projects
Next Topic:How do I set the font for a text viewer?
Current Time: Fri Nov 07 00:44:13 EST 2025
Powered by FUDForum. Page generated in 0.04845 seconds
