Home » Eclipse Projects » Mylyn » Generic Connector Login URL problems
Generic Connector Login URL problems [message #56447] |
Fri, 22 August 2008 09:25  |
Thanks to Steffen for previous help locating the Generic Connector. I now
have managed to install and configure the connector to retrieve tracker
items from my forge into Mylyn.
The current problem has to do with login.
When I click on one of the items in the Task List view, the item opens in a
web viewer as it should. However, forge returns a page that is used for
anonymous login. In order to receive web pages that contain the input
fields and a submit button associated with my login, it is necessary to
login into the forge using an external web browser.
I have monitored the network traffic using Microsoft Network Monitor and I
can see that the Login URL is sent, and exchanged with the servder, but the
links in the Task List do not appear to use the same session s was used to
retrieve the list.
I'm probably way of on my analysis here, but this is what I see.
I was not able to find much additional information regarding the login url
in the Mylyn users guide.
I suspect I'm missing something.
Here is the set of mylyn related plugins I have installed.
I hope someone can shed some light on this.
Michael
06/23/2008 01:25 PM 148,537
org.eclipse.mylyn.bugzilla.core_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 149,780
org.eclipse.mylyn.bugzilla.core_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 5,671
org.eclipse.mylyn.bugzilla.ide_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 5,676
org.eclipse.mylyn.bugzilla.ide_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 135,879
org.eclipse.mylyn.bugzilla.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 135,765
org.eclipse.mylyn.bugzilla.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 18,284
org.eclipse.mylyn.commons.core_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 18,279
org.eclipse.mylyn.commons.core_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 69,969
org.eclipse.mylyn.commons.net_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 69,974
org.eclipse.mylyn.commons.net_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 189,148
org.eclipse.mylyn.commons.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 191,717
org.eclipse.mylyn.commons.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 8,132
org.eclipse.mylyn.compatibility_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 8,131
org.eclipse.mylyn.compatibility_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 78,030
org.eclipse.mylyn.context.core_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 78,017
org.eclipse.mylyn.context.core_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 213,031
org.eclipse.mylyn.context.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 212,405
org.eclipse.mylyn.context.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 890,638
org.eclipse.mylyn.help.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 890,645
org.eclipse.mylyn.help.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 20,947
org.eclipse.mylyn.ide.ant_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 20,952
org.eclipse.mylyn.ide.ant_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 29,985
org.eclipse.mylyn.ide.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 29,988
org.eclipse.mylyn.ide.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 15,875
org.eclipse.mylyn.java.tasks_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 15,880
org.eclipse.mylyn.java.tasks_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 138,898
org.eclipse.mylyn.java.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 138,902
org.eclipse.mylyn.java.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 32,373
org.eclipse.mylyn.monitor.core_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 32,379
org.eclipse.mylyn.monitor.core_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 46,276
org.eclipse.mylyn.monitor.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 46,279
org.eclipse.mylyn.monitor.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 56,630
org.eclipse.mylyn.pde.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 56,635
org.eclipse.mylyn.pde.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 47,467
org.eclipse.mylyn.resources.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 47,476
org.eclipse.mylyn.resources.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 63,058
org.eclipse.mylyn.tasks.bugs_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 63,063
org.eclipse.mylyn.tasks.bugs_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 351,069
org.eclipse.mylyn.tasks.core_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 353,718
org.eclipse.mylyn.tasks.core_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 1,578,215
org.eclipse.mylyn.tasks.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 1,584,835
org.eclipse.mylyn.tasks.ui_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 17,446
org.eclipse.mylyn.team.cvs_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 17,452
org.eclipse.mylyn.team.cvs_3.0.1.v20080721-2100-e3x.jar
06/23/2008 01:25 PM 110,888
org.eclipse.mylyn.team.ui_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 110,889
org.eclipse.mylyn.team.ui_3.0.1.v20080721-2100-e3x.jar
08/21/2008 01:53 PM 70,836
org.eclipse.mylyn.web.tasks_3.0.1.v20080721-2100-e3x.jar
08/21/2008 01:58 PM 65,555
org.eclipse.mylyn.web.tasks_3.0.2.I20080821-0200-e3x.jar
06/23/2008 01:25 PM 6,635
org.eclipse.mylyn_3.0.0.v20080619-1900.jar
08/19/2008 03:28 PM 6,643
org.eclipse.mylyn_3.0.1.v20080721-2100-e3x.jar
Re: Generic Connector Login URL problems [message #592693 is a reply to message #56447] |
Fri, 22 August 2008 16:51  |
> a
The internal browser is separate from the implementation of the tasks
framework that synchronizes queries. At the moment it is necessary to
manually login in to create a session in the internal web browser. You can
find additional information on this bug report:
163120: investigate how to provide authentication credentials to browser
widget
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163120
I hope this answers your question.
Steffen
Current Time: Fri Oct 17 13:20:21 EDT 2025
Powered by FUDForum. Page generated in 0.04114 seconds
