Home » Modeling » TMF (Xtext) » Recipe framework gone?
Recipe framework gone? [message #56323] Wed, 08 July 2009 12:55 Go to next message
Looking at the old OAW documentation, I came across the Recipe framework.
http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/recipe.html
I don't seem to be able to find the TMF equivalent - has this been dropped
from TMF, or am I just looking under the wrong names?
If it has been dropped - would the old oaw stuff be compatible with TMF
models/generated code (it's all Ecore under the covers...)?
Re: Recipe framework gone? [message #56359 is a reply to message #56323] Wed, 08 July 2009 14:09 Go to previous messageGo to next message
Hi Antony,
the recipe framework is not part of Xtext.
All secondary oAW components (recipe, XWeave, etc.) will be updated and
further developed as soon as there are people pushing it forward. You
might try to trigger Markus Völter (the original author) or find any
other volunteers.
I'm pretty sure that there's no explicit dependency to Xtext.
So it should work. That said, I'm not so sure if there are dependencies
to Xpand. So you might be forced to use Xpand from oAW 4.3.1 (which
works with TMF Xtext) in order to use Recipe from oAW 4.3.1.
It's maybe best to ask in the openarchitectureware.org forum.
Sven
Re: Recipe framework gone? [message #56387 is a reply to message #56359] Wed, 08 July 2009 14:35 Go to previous messageGo to next message
Hi Antony,
state of now Recipe is considered deprecated for oaw5. Until now we have no volunteers for this component willing to migrate.
"Old oaw stuff" will be mostly the same, but since namespaces changed during migration to Eclipse Modeling projects must be migrated. Migration effort
is relative few.
Kind regards,
~Karsten
On 08.07.09 20:09, Sven Efftinge wrote:
> Hi Antony,
> other volunteers.
>> TMF models/generated code (it's all Ecore under the covers...)?
> Cheers,
> Sven
Re: Recipe framework gone? [message #56462 is a reply to message #56387] Wed, 08 July 2009 17:27 Go to previous messageGo to next message
Thanks, both of you, for your responses.
I'll have a look into converting it myself (obviously to contribute it
back) - I can't promise anything, being newish to EMF. I'll at least look
into the Recipe source code, though...
So - I'm slightly unclear as to the relationship oAW and the components
have now. Is it true to say that oAW still exists, but would now build on
top of the TMF versions of components like Xtext, Xpand, Xtend, etc?
Actually - this is probably the wrong place to ask that... I'll have a
look at the oaw forums...
Re: Recipe framework gone? [message #56489 is a reply to message #56462] Wed, 08 July 2009 18:03 Go to previous messageGo to next message
Hmmm - okay - I seem to have no trouble converting the code in oaw CVS
oaw_v4/recipe. It had a couple of explicit dependencies to oaw plugins
and classes, each with easy to find direct replacements in TMF.
I've not tested this properly yet, but given the nature of the changes, I
would expect very few problems.
Assuming it tests okay, or any problems I find are ones I can fix, where
would I submit it back? To oaw, or to tmf?
Re: Recipe framework gone? [message #56570 is a reply to message #56489] Thu, 09 July 2009 04:13 Go to previous messageGo to next message
If you find it useful and want to maintain it over time, you maybe
should found a little new project at sourceforge or googlecode (or what
you prefer).
I guess you should ask on the brand new oaw working group mailinglist
over at : https://dev.eclipse.org/mailman/listinfo/oaw-wg
Sven
> I would expect very few problems.
Re: Recipe framework gone? [message #56598 is a reply to message #56462] Thu, 09 July 2009 04:16 Go to previous messageGo to next message
> on top of the TMF versions of components like Xtext, Xpand, Xtend, etc?
It's ok to ask this here. :-)
oAW has become a working group at eclipse and future releases will be
based on Eclipse Modeling technology (that is not only Xtext and Xpand
but also GMF, EMF and stuff like Ecore Tools). It also will include some
non IP approved not-at-eclipse hosted stuff. But those bits have to be
made available from an external site.
You all can participate. It's open!
Just subscribe to the mailinglist and participate in any discussions you
find interesting : https://dev.eclipse.org/mailman/listinfo/oaw-wg
Sven
Re: Recipe framework gone? [message #56703 is a reply to message #56570] Thu, 09 July 2009 08:01 Go to previous message
Thanks, Sven.
I've asked at oaw, and if they're not interested I'll host it/maintain
myself :)
It's a nice little tool - I think it's of quite limited use - normally I
find I can prevent the need for the checks it does - but occasionally it
proves very handy indeed.
Previous Topic:Generate model to ecore file
Next Topic:Using existing .uml file in textuell modell?
Current Time: Fri Nov 07 05:29:19 EST 2025
Powered by FUDForum. Page generated in 0.04446 seconds
