Home » Newcomers » Newcomers » Ant nobannerlogger in Eclipse?
Ant nobannerlogger in Eclipse? [message #56282] Fri, 22 April 2005 10:03 Go to next message
Originally posted by: mikecepek.FIX.yahoooooo.com
Is there a way to suppress the empty target output from Ant in Eclipse?
In the past I have used '-logger NoBannerLogger' on the Ant command-line.
But adding this to the Ant Arguments list (in the External Tools dialog in
Eclipse 3.1.0) causes my builds to just hang. Adding '-verbose' didn't
help either; the build still hung with no console output at all.
I suspect that Eclipse is using Ant's AnsiColorLogger by default to
generate the output for the Console window. This might also explain the
hang when I attempt to overwrite it as mentioned above.
Here is an example of my current Eclipse Console window Ant output:
Buildfile: C:\mike\Eclipse\src\java\com\spanlink\sqm\common\build.xml
init:
prereqs:
prereq-1:
prereq-2:
prereq-3:
prereq-5:
prereq-6:
compile:
build:
build:
build-test:
BUILD SUCCESSFUL
Total time: 1 second
All those "empty" target messages are just noise. Using NoBannerLogger
would reduce the above to just:
BUILD SUCCESSFUL
Obviously it helps even more with more complex (e.g. nested) build
scripts. The less noise there is, the easier it is for busy programmers
to find error and warning messages in the build output.
If anyone can recommend a more appropriate forum for this question, I'd
appreciate that as well. I'm pretty sure this is an Eclipse issue (rather
than anything specific to the Apache Ant project).
Thank you for your time.
Re: Ant nobannerlogger in Eclipse? [message #56284 is a reply to message #56282] Fri, 22 April 2005 10:11 Go to previous message
This is an Eclipse issue: see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=84608
We use our own custom loggers for integration within Eclipse and since only
one logger is allowed...
So there is no way currently to suppress the empty target output from Ant in
Eclipse.
Please log an enhancement for this feature (but it will be deferred to post
3.1 as we are no longer adding no features to Eclipse in the 3.1 timeframe).
Darins
"Mike Cepek" <mikecepek@FIX.yahoooooo.com> wrote in message
news:c208128e5f960bb3f37b4436a66331c3$1@www.eclipse.org...
> init:
> prereqs:
> prereq-1:
> prereq-2:
> prereq-3:
> prereq-5:
> prereq-6:
> compile:
> build:
> build:
> build-test:
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
Previous Topic:Debugging in Eclipse
Next Topic:Implementing editor-dependant menus
Current Time: Mon Oct 20 12:56:15 EDT 2025
Powered by FUDForum. Page generated in 0.08391 seconds
