Home » Eclipse Projects » DTP » LDAP?
LDAP? [message #56249] Thu, 14 May 2009 09:54 Go to next message
I am a newbie to DTP.
Is it conceivable - or has it already been done - that a ODA data source
is not a tabular (eg, db, csv) but rather a hierarchical information
model (ie, LDAP) ? Or does my question make no sense ?
Thanks, chris
Re: LDAP? [message #56264 is a reply to message #56249] Thu, 14 May 2009 19:56 Go to previous messageGo to next message
Chris,
I presume you meant OLAP?
The ODA framework supports tabular result sets only at this point. There is
a yet to be scheduled enhancement to support multi-dimensional result sets
as well (Bugzilla 204345), but it is not going to be in the Galileo release.
Linda
Re: LDAP? [message #56399 is a reply to message #56264] Fri, 15 May 2009 14:53 Go to previous messageGo to next message
Hi Linda,
No, I really meant LDAP. The ODA documentation, if I recall correctly,
states the framework aims to support a broad variety of data sources,
including hierarchical data (eg, XML). Thus I wondered if anyone had
ever tried a LDAP data source.
Thanks, chris
Linda Chan wrote:
> Chris,
> Linda
Re: LDAP? [message #56423 is a reply to message #56399] Fri, 15 May 2009 17:15 Go to previous message
Chris,
I see. A data source's data may be hierarchical, and an ODA driver such as
the DTP enablement.oda.xml driver, flattens its hierarchical data into a
tabular ODA result set. So it is indeed feasible for an LDAP oda driver to
do similar.
Hope others in the community can respond if someone has implemented one for
LDAP.
Linda
Re: LDAP? [message #595735 is a reply to message #56249] Thu, 14 May 2009 19:56 Go to previous message
Chris,
Linda
Re: LDAP? [message #595744 is a reply to message #56264] Fri, 15 May 2009 14:53 Go to previous message
Hi Linda,
Thanks, chris
Linda Chan wrote:
> Chris,
> Linda
Re: LDAP? [message #595749 is a reply to message #56399] Fri, 15 May 2009 17:15 Go to previous message
Chris,
do similar.
LDAP.
Linda
Previous Topic:LDAP?
Next Topic:Simple example of ODA Consumer?
Current Time: Sun Nov 09 06:08:56 EST 2025
Powered by FUDForum. Page generated in 0.06299 seconds
