Home » Language IDEs » AspectJ » Information about AJDT release streams
Information about AJDT release streams [message #55404] Mon, 25 July 2005 10:34 Go to next message
Originally posted by: mchapman.uk.ibm.com
As we work towards better support for Eclipse 3.1, we have had to separate
AJDT into two release streams. The AJDT 1.2 line will continue to support
Eclipse 3.0, with the next release being 1.2.1. The AJDT 1.3 line will
support Eclipse 3.1, beginning with 1.3.0 which is planned for September.
Both of these releases will contain the same function and bug fixes,
except of course for anything specific to either of the Eclipse versions.
The development builds section of the AJDT download page:
http://www.eclipse.org/ajdt/downloads/#dev
has been updated to show the most recent development builds for each
release stream. The latest builds for Eclipse 3.1 now have appropriate
version numbers beginning 1.3.0.
There is also a build report link for each build, showing exactly what has
changed in that build compared with the previous one.
Extra information for those working with the AJDT source code:
CVS HEAD contains the source code for the AJDT 1.3 line, and the new
"ajdt1_2" branch contains the AJDT 1.2 line. For more details, see
updated FAQ entry 4.3: How do I setup an AJDT development environment in
Eclipse?
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Information about AJDT release streams [message #55431 is a reply to message #55404] Mon, 25 July 2005 15:45 Go to previous messageGo to next message
What version of aspectj is the 3.1 stream currently using? Is it always the latest dev release?
-barry
Re: Information about AJDT release streams [message #55512 is a reply to message #55431] Tue, 26 July 2005 05:53 Go to previous message
It is using a dev build of aspectj from 20 June. It is only updated when
aspectj reaches a stable point, such as a milestone release, or when a
particular fix or change is needed urgently.
Matt.
Re: Information about AJDT release streams [message #589600 is a reply to message #55404] Mon, 25 July 2005 15:45 Go to previous message
-barry
Re: Information about AJDT release streams [message #589634 is a reply to message #55431] Tue, 26 July 2005 05:53 Go to previous message
Matt.
Previous Topic:how to catch debug joint points?
Next Topic:AspectJ model
Current Time: Mon Nov 03 01:46:39 EST 2025
Powered by FUDForum. Page generated in 0.05407 seconds
