Home » Newcomers » Newcomers » Can't run Eclipse
| Can't run Eclipse [message #54984] |
Tue, 19 April 2005 15:31  |
Originally posted by: mail.nikolaus-rupp.de
Hello everybody:
I'm trying to run the Eclipse on a RedHat Enterprise SE platform. I
downloaded the project and tried to open eclipse.
After a flash of the splash screen I get the following text in the log
file:
!SESSION Apr 19, 2005 18:17:59.192
eclipse.buildId=M200409161125
java.fullversion=GNU libgcj 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Apr 19, 2005 18:17:59.192
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: while resolving class:
org.eclipse.core.runtime.adaptor.EclipseAdaptor
at java.lang.VMClassLoader.resolveClass(java.lang.Class)
(/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.initializeClass() (/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String, boolean,
java.lang.ClassLoader) (/usr/lib/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String) (/usr/lib/libgcj.so.5.0.0)
at org.eclipse.core.runtime.adaptor.EclipseStarter.createAdapto r()
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable) (Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
at _Jv_CallAnyMethodA(java.lang.Object, java.lang.Class, _Jv_Method,
boolean, boolean, java.lang.Class[], jvalue, jvalue, boolean)
boolean, java.lang.Class[], java.lang.Object[]) (/usr/lib/libgcj.so.5.0.0)
at java.lang.reflect.Method.invoke(java.lang.Object,
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown
Source)
Caused by: java.lang.ClassNotFoundException:
org.xml.sax.helpers.DefaultHandler not found in
[file:/opt/eclipse/plugins/org.eclipse.osgi_3.0.1/core.jar,
file:/opt/eclipse/plugins/org.eclipse.osgi_3.0.1/console.jar ,
file:/opt/eclipse/plugins/org.eclipse.osgi_3.0.1/osgi.jar,
file:/opt/eclipse/plugins/org.eclipse.osgi_3.0.1/resolver.ja r,
file:/opt/eclipse/plugins/org.eclipse.osgi_3.0.1/defaultAdap tor.jar,
file:/opt/eclipse/plugins/org.eclipse.osgi_3.0.1/eclipseAdap tor.jar]
at java.net.URLClassLoader.findClass(java.lang.String)
at java.lang.ClassLoader.loadClass(java.lang.String, boolean)
at _Jv_FindClass(_Jv_Utf8Const, java.lang.ClassLoader)
at _Jv_ClassReader.handleClassBegin(int, int, int)
at _Jv_ClassReader.parse() (/usr/lib/libgcj.so.5.0.0)
at _Jv_DefineClass(java.lang.Class, byte[], int, int)
at java.lang.VMClassLoader.defineClass(java.lang.ClassLoader,
java.lang.String, byte[], int, int, java.security.ProtectionDomain)
at java.lang.ClassLoader.defineClass(java.lang.String, byte[], int,
int, java.security.ProtectionDomain) (/usr/lib/libgcj.so.5.0.0)
at java.security.SecureClassLoader.defineClass(java.lang.String ,
byte[], int, int, java.security.CodeSource) (/usr/lib/libgcj.so.5.0.0)
at _Jv_PrepareCompiledClass(java.lang.Class) (/usr/lib/libgcj.so.5.0.0)
at _Jv_WaitForState(java.lang.Class, int) (/usr/lib/libgcj.so.5.0.0)
at java.lang.VMClassLoader.linkClass0(java.lang.Class)
...12 more
!SESSION Tue Apr 19 18:17:59 GMT-01:00 2005
!ENTRY org.eclipse.core.launcher 4 0 Apr 19, 2005 18:17:59.318
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at java.lang.Object.getClass() (/usr/lib/libgcj.so.5.0.0)
Source)
Source)
at gnu.gcj.runtime.FirstThread.call_main() (/usr/lib/libgcj.so.5.0.0)
at gnu.gcj.runtime.FirstThread.run() (/usr/lib/libgcj.so.5.0.0)
at _Jv_ThreadRun(java.lang.Thread) (/usr/lib/libgcj.so.5.0.0)
at _Jv_RunMain(java.lang.Class, byte const, int, byte const, boolean)
at __gcj_personality_v0 (/root/java.version=1.4.2)
at __libc_start_main (/lib/tls/libc-2.3.4.so)
at _Jv_RegisterClasses (/root/java.version=1.4.2)
Anybody can help?
Niko
| Re: Can't run Eclipse [message #55305 is a reply to message #54984] |
Wed, 20 April 2005 03:12  |
> file:
I am not sure if Eclipse runs with the GNU JAVA VM. Maybe you should
consider using the SUN VM (http://java.sun.com/j2se/1.4.2/download.html)
I already run Eclipse with several versions of the SUN VM (1.3.1, 1.4.2,
1.5) on Debian GNU/Linux and do not have similar problems.
Best Regards,
Andreas
Current Time: Sat Nov 08 23:55:32 EST 2025
Powered by FUDForum. Page generated in 0.09769 seconds
