Home » Eclipse Projects » Plugin Development Environment (PDE) » Generate source using PDE
Generate source using PDE [message #54604] Mon, 13 April 2009 07:11 Go to next message
I have a feature and a plugin and I am able to build this feature using
PDE headless mode. So I want to create a feature source, so I add
generated.feature to the build.properties of my feature. Here is what my
feature.xml looks like:
bin.includes = feature.xml
generate.feature@com.test.feature.source = com.test.feature
I expect PDE Build to generate 2 features:
com.test.feature
But I don't see the com.test.feature.source gets generated. Any ideas?
Re: Generate source using PDE [message #54630 is a reply to message #54604] Mon, 13 April 2009 09:34 Go to previous messageGo to next message
> com.test.feature
Which version of Eclipse are you using?
http://wiki.eclipse.org/PDEBuild/Individual_Source_Bundles
I would make sure you have this property:
individualSourceBundles=true
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Generate source using PDE [message #54657 is a reply to message #54630] Mon, 13 April 2009 11:32 Go to previous messageGo to next message
Hi Chris,
Thanks for your suggestion. I added it to the build.properties but
still didn't work.
Here is the new build.properties looks like:
generate.plugin@com.test.source = com.test
I am not sure if I setup my feature/plugin correctly. Do I need a new
SDK feature as suggested in the Eclipse InfoCenter?
Here is what the pdebuild.log looks like:
Buildfile:
c:/IBM/SDPShared/plugins/org.eclipse.pde.build_3.4.1.R34x_v2 0080805/scripts/build.xml
main:
preBuild:
preSetup:
checkLocalMaps:
getMapFiles:
[concat] No existing resources and no nested text, doing nothing
postSetup:
checkLocalBase:
getBaseComponents:
fetch:
generate:
preGenerate:
[echo] create jazzsrc.zip
buildSrcZip:
[mkdir] Created dir: c:\temp\team.build\working.dir\build.artifacts
[zip] Building zip:
c:\temp\team.build\working.dir\build.artifacts\jazzsrc-xxx.z ip
allElements:
init:
generateScript:
postGenerate:
process:
preProcess:
allElements:
init:
processElement:
init:
build.jars:
init:
all.features:
all.plugins:
properties:
init:
build.jars:
properties:
init:
@dot:
c:\temp\team.build\working.dir\plugins\com.test\temp.folder\ @dot.bin
[javac] Compiling 2 source files to
[copy] Copying 2 files to
c:\temp\team.build\working.dir\plugins\com.test\@dot
[delete] Deleting directory
update.feature:
all.children:
postProcess:
assemble:
preAssemble:
allElements:
init:
assembleElement:
main:
assemble.com.test.feature:
main:
[mkdir] Created dir: c:\temp\team.build\working.dir\tmp
properties:
init:
gather.bin.parts:
c:\temp\team.build\working.dir\tmp\eclipse\plugins\com.test_ 1.0.0
[copy] Copying 3 files to
customAssembly:
init:
gather.bin.parts:
c:\temp\team.build\working.dir\tmp\eclipse\features\com.test .feature_1.0.0
children:
[copy] Copying 1 file to
rootFiles:
rootFiles*_*_*:
customAssembly:
customAssembly:
jarUp:
jarIng:
[jar] Building jar:
c:\temp\team.build\working.dir\tmp\eclipse\plugins\com.test_ 1.0.0.jar
customAssembly:
generate.p2.metadata:
customAssembly:
[zip] Building zip:
c:\temp\team.build\working.dir\build.artifacts\com.test.feat ure-xxx.zip
[zip] Updating zip:
[delete] Deleting directory c:\temp\team.build\working.dir\tmp
postAssemble:
package:
prePackage:
allElements:
init:
packageElement:
main:
main:
customAssembly:
customAssembly:
customAssembly:
postPackage:
postBuild:
postBuild:
gatherLogs:
c:\temp\team.build\working.dir\build.artifacts\compilelogs
allElements:
init:
gatherLogs:
init:
zip.logs:
[mkdir] Created dir: c:\temp\team.build\working.dir\compile.logs.temp
init:
all.features:
all.plugins:
properties:
init:
gather.logs:
c:\temp\team.build\working.dir\compile.logs.temp\plugins\com .test_1.0.0
update.feature:
all.children:
[zip] Building zip:
c:\temp\team.build\working.dir\features\com.test.feature\com .test.feature_1.0.0.log.zip
[unzip] Expanding:
into c:\temp\team.build\working.dir\build.artifacts\compilelogs
allElements:
init:
gatherSources:
init:
build.sources:
init:
all.features:
all.plugins:
properties:
init:
build.sources:
properties:
init:
src.zip:
zip.src.zip:
[zip] Building zip:
c:\temp\team.build\working.dir\plugins\com.test\src.zip
update.feature:
all.children:
init:
zip.sources:
c:\temp\team.build\working.dir\features\com.test.feature\fea ture.temp.folder
init:
all.features:
all.plugins:
properties:
init:
gather.sources:
c:\temp\team.build\working.dir\features\com.test.feature\fea ture.temp.folder\plugins\null\src\com.test_1.0.0
properties:
init:
copy.src.includes:
update.feature:
all.children:
[zip] Building zip:
c:\temp\team.build\working.dir\features\com.test.feature\com .test.feature_1.0.0.src.zip
[mkdir] Created dir: c:\temp\team.build\working.dir\coverage-src
[unzip] Expanding:
c:\temp\team.build\working.dir\plugins\com.test\src.zip into
generateUpdateSite:
[mkdir] Created dir: c:\temp\team.build\working.dir\updateSiteStaging
c:\temp\team.build\working.dir\updateSiteStaging\features
c:\temp\team.build\working.dir\updateSiteStaging\plugins
allElements:
updateSiteExport:
init:
build.update.jar:
init:
all.features:
all.plugins:
properties:
init:
build.update.jar:
properties:
init:
build.jars:
properties:
init:
@dot:
properties:
init:
gather.bin.parts:
c:\temp\team.build\working.dir\plugins\com.test\temp.folder\ com.test_1.0.0
[jar] Building jar:
c:\temp\team.build\working.dir\updateSiteStaging\plugins\com .test_1.0.0.jar
[jar] Building jar:
update.feature:
all.children:
c:\temp\team.build\working.dir\features\com.test.feature\fea ture.temp.folder\features\com.test.feature_1.0.0
init:
gather.bin.parts:
children:
rootFiles:
[jar] Building jar:
c:\temp\team.build\working.dir\updateSiteStaging\features\co m.test.feature_1.0.0.jar
BUILD SUCCESSFUL
BUILD SUCCESSFUL
Total time: 6 seconds
Chris Aniszczyk wrote:
>> using PDE headless mode. So I want to create a feature source, so I
>> add generated.feature to the build.properties of my feature. Here is
>> what my feature.xml looks like:
>> com.test.feature
> Cheers,
Re: Generate source using PDE [message #54683 is a reply to message #54657] Mon, 13 April 2009 13:21 Go to previous message
You need to include "com.test.feature.source" before it will be
generated. The generate.feature property goes with the feature that
will include the generated source feature.
The normal layout is to do something like this :
com.test.sdk.feature
-(generate.feature@com.test.feature.source=com.test.feature)
- includes com.test.feature
- includes com.test.feature.source
Essentially build goes through the feature hierarchy, and if it hits an
inclusion that doesn't exist (com.test.feature.source) then it consults
the generate properties to see if it can be generated.
You generally don't need both generate.feature and generate.plugin. The
generate.feature will automatically generate source plugins for
everything included in the feature you are basing the source on.
You would use the generate.plugin if you didn't want a source feature
and just wanted source plugins. (And similar to generating the feature,
someone would need to include the source plugin before it got generated.)
-Andrew
hung wrote:
> Hi Chris,
> still didn't work.
> Buildfile:
> main:
> preBuild:
> preSetup:
> checkLocalMaps:
> getMapFiles:
> postSetup:
> checkLocalBase:
> getBaseComponents:
> fetch:
> generate:
> preGenerate:
> buildSrcZip:
> [zip] Building zip:
> allElements:
> init:
> generateScript:
> postGenerate:
> process:
> preProcess:
> allElements:
> init:
> processElement:
> init:
> build.jars:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> update.feature:
> all.children:
> postProcess:
> assemble:
> preAssemble:
> allElements:
> init:
> assembleElement:
> main:
> main:
> properties:
> init:
> gather.bin.parts:
> customAssembly:
> init:
> gather.bin.parts:
> children:
> rootFiles:
> rootFiles*_*_*:
> customAssembly:
> customAssembly:
> jarUp:
> jarIng:
> [jar] Building jar:
> customAssembly:
> customAssembly:
> [zip] Building zip:
> [zip] Updating zip:
> postAssemble:
> package:
> prePackage:
> allElements:
> init:
> packageElement:
> main:
> main:
> customAssembly:
> customAssembly:
> customAssembly:
> postPackage:
> postBuild:
> postBuild:
> gatherLogs:
> allElements:
> init:
> gatherLogs:
> init:
> zip.logs:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.logs:
> update.feature:
> all.children:
> [zip] Building zip:
> [unzip] Expanding:
> allElements:
> init:
> gatherSources:
> init:
> build.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.sources:
> properties:
> init:
> src.zip:
> zip.src.zip:
> [zip] Building zip:
> update.feature:
> all.children:
> init:
> zip.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.sources:
> properties:
> init:
> copy.src.includes:
> update.feature:
> all.children:
> [zip] Building zip:
> [unzip] Expanding:
> generateUpdateSite:
> allElements:
> updateSiteExport:
> init:
> build.update.jar:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.update.jar:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> properties:
> init:
> gather.bin.parts:
> [jar] Building jar:
> [jar] Building jar:
> update.feature:
> all.children:
> init:
> gather.bin.parts:
> children:
> rootFiles:
> [jar] Building jar:
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
>>> com.test.feature
>> Cheers,
Re: Generate source using PDE [message #594978 is a reply to message #54604] Mon, 13 April 2009 09:34 Go to previous message
> com.test.feature
Re: Generate source using PDE [message #594988 is a reply to message #54630] Mon, 13 April 2009 11:32 Go to previous message
Hi Chris,
still didn't work.
Buildfile:
main:
preBuild:
preSetup:
checkLocalMaps:
getMapFiles:
postSetup:
checkLocalBase:
getBaseComponents:
fetch:
generate:
preGenerate:
buildSrcZip:
[zip] Building zip:
allElements:
init:
generateScript:
postGenerate:
process:
preProcess:
allElements:
init:
processElement:
init:
build.jars:
init:
all.features:
all.plugins:
properties:
init:
build.jars:
properties:
init:
@dot:
update.feature:
all.children:
postProcess:
assemble:
preAssemble:
allElements:
init:
assembleElement:
main:
main:
properties:
init:
gather.bin.parts:
customAssembly:
init:
gather.bin.parts:
children:
rootFiles:
rootFiles*_*_*:
customAssembly:
customAssembly:
jarUp:
jarIng:
[jar] Building jar:
customAssembly:
customAssembly:
[zip] Building zip:
[zip] Updating zip:
postAssemble:
package:
prePackage:
allElements:
init:
packageElement:
main:
main:
customAssembly:
customAssembly:
customAssembly:
postPackage:
postBuild:
postBuild:
gatherLogs:
allElements:
init:
gatherLogs:
init:
zip.logs:
init:
all.features:
all.plugins:
properties:
init:
gather.logs:
update.feature:
all.children:
[zip] Building zip:
[unzip] Expanding:
allElements:
init:
gatherSources:
init:
build.sources:
init:
all.features:
all.plugins:
properties:
init:
build.sources:
properties:
init:
src.zip:
zip.src.zip:
[zip] Building zip:
update.feature:
all.children:
init:
zip.sources:
init:
all.features:
all.plugins:
properties:
init:
gather.sources:
properties:
init:
copy.src.includes:
update.feature:
all.children:
[zip] Building zip:
[unzip] Expanding:
generateUpdateSite:
allElements:
updateSiteExport:
init:
build.update.jar:
init:
all.features:
all.plugins:
properties:
init:
build.update.jar:
properties:
init:
build.jars:
properties:
init:
@dot:
properties:
init:
gather.bin.parts:
[jar] Building jar:
[jar] Building jar:
update.feature:
all.children:
init:
gather.bin.parts:
children:
rootFiles:
[jar] Building jar:
BUILD SUCCESSFUL
BUILD SUCCESSFUL
>> com.test.feature
> Cheers,
Re: Generate source using PDE [message #594994 is a reply to message #54657] Mon, 13 April 2009 13:21 Go to previous message
-Andrew
hung wrote:
> Hi Chris,
> still didn't work.
> Buildfile:
> main:
> preBuild:
> preSetup:
> checkLocalMaps:
> getMapFiles:
> postSetup:
> checkLocalBase:
> getBaseComponents:
> fetch:
> generate:
> preGenerate:
> buildSrcZip:
> [zip] Building zip:
> allElements:
> init:
> generateScript:
> postGenerate:
> process:
> preProcess:
> allElements:
> init:
> processElement:
> init:
> build.jars:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> update.feature:
> all.children:
> postProcess:
> assemble:
> preAssemble:
> allElements:
> init:
> assembleElement:
> main:
> main:
> properties:
> init:
> gather.bin.parts:
> customAssembly:
> init:
> gather.bin.parts:
> children:
> rootFiles:
> rootFiles*_*_*:
> customAssembly:
> customAssembly:
> jarUp:
> jarIng:
> [jar] Building jar:
> customAssembly:
> customAssembly:
> [zip] Building zip:
> [zip] Updating zip:
> postAssemble:
> package:
> prePackage:
> allElements:
> init:
> packageElement:
> main:
> main:
> customAssembly:
> customAssembly:
> customAssembly:
> postPackage:
> postBuild:
> postBuild:
> gatherLogs:
> allElements:
> init:
> gatherLogs:
> init:
> zip.logs:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.logs:
> update.feature:
> all.children:
> [zip] Building zip:
> [unzip] Expanding:
> allElements:
> init:
> gatherSources:
> init:
> build.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.sources:
> properties:
> init:
> src.zip:
> zip.src.zip:
> [zip] Building zip:
> update.feature:
> all.children:
> init:
> zip.sources:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> gather.sources:
> properties:
> init:
> copy.src.includes:
> update.feature:
> all.children:
> [zip] Building zip:
> [unzip] Expanding:
> generateUpdateSite:
> allElements:
> updateSiteExport:
> init:
> build.update.jar:
> init:
> all.features:
> all.plugins:
> properties:
> init:
> build.update.jar:
> properties:
> init:
> build.jars:
> properties:
> init:
> @dot:
> properties:
> init:
> gather.bin.parts:
> [jar] Building jar:
> [jar] Building jar:
> update.feature:
> all.children:
> init:
> gather.bin.parts:
> children:
> rootFiles:
> [jar] Building jar:
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
>>> com.test.feature
>> Cheers,
Previous Topic:Generate source using PDE
Next Topic:Build Error: ${launcherName}.app\Contents\MacOS not found
Current Time: Wed Oct 22 22:06:55 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
