Home » Eclipse Projects » Nebula » Gallery: make getGroup() public?
Gallery: make getGroup() public? [message #54199] Fri, 06 June 2008 05:19 Go to next message
Question for Nicolas I guess!
Can Gallery.getGroup() be exposed as public??
I need this for drag'n'drop support... obviously there's no GalleryItem in
empty areas so can't getParentItem.
Justin
Re: Gallery: make getGroup() public? [message #54413 is a reply to message #54199] Wed, 11 June 2008 04:04 Go to previous messageGo to next message
There are 2 options here :
* make getGroup public
* change getItem so it returns the group if there is no child item under
the mouse. But this can break some applications.
I'm not sure which one is the best right now. I have to check Table and
Tree API.
Would this 2 options work for you ?
Nicolas
> in empty areas so can't getParentItem.
> Justin
Re: Gallery: make getGroup() public? [message #54438 is a reply to message #54413] Wed, 11 June 2008 05:31 Go to previous messageGo to next message
Hi Nicolas,
I can't remember what cut of the code I have but I did try the 2nd idea of
changing getItem and, as you say, it broke things big time. I made
getGroup public and this did the trick - this is what I'd prefer as it'd
be the most straightforward change with no side effects on others.
Justin
Nicolas Richeton wrote:
> Tree API.
> Nicolas
>> Thanks,
>> Justin
Re: Gallery: make getGroup() public? [message #54738 is a reply to message #54438] Sat, 21 June 2008 05:55 Go to previous message
Hi Justin,
getGroup() is now public, see latest version on CVS.
Nicolas
> Hi Nicolas,
> of changing getItem and, as you say, it broke things big time. I made
> Justin
>> under the mouse. But this can break some applications.
>> and Tree API.
>> Nicolas
>>> GalleryItem in empty areas so can't getParentItem.
>>> Thanks,
>>> Justin
Re: Gallery: make getGroup() public? [message #590416 is a reply to message #54199] Wed, 11 June 2008 04:04 Go to previous message
Tree API.
Nicolas
> Justin
Re: Gallery: make getGroup() public? [message #590425 is a reply to message #54413] Wed, 11 June 2008 05:31 Go to previous message
Hi Nicolas,
Justin
> Tree API.
> Nicolas
>> Thanks,
>> Justin
Re: Gallery: make getGroup() public? [message #590548 is a reply to message #54438] Sat, 21 June 2008 05:55 Go to previous message
Hi Justin,
Nicolas
> Hi Nicolas,
> Justin
>> and Tree API.
>> Nicolas
>>> Thanks,
>>> Justin
Previous Topic:position of image
Next Topic:Patch for CDateTime behaviour
Current Time: Thu Nov 06 22:06:43 EST 2025
Powered by FUDForum. Page generated in 0.05227 seconds
