Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » OCL and external mehtods
| OCL and external mehtods [message #53794] |
Thu, 28 September 2006 07:41  |
would the following thing b possible?
I want to do the following, I have an ocl expressions which uses a
method outside of my Ecore model.
maybe: OutSideHelper.checkName( self.name)
I there a way to do this.
Chris
| Re: OCL and external mehtods [message #54920 is a reply to message #54419] |
Fri, 29 September 2006 16:16   |
Hi, Chris,
No, sorry, there isn't any programmer's guide documentation for that, yet.
This would be a great comment to add to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156360.
There is a limited example in the JUnit tests for the parser's support for
UML-isms such as States and Signals (browse the hierarchy of the
Environment interface to find it).
Christian
Chris Lenz wrote:
> Is there somewhere a guide how to work with environments.
> Or examples to work with environments?
> Thanx Chris
> Christian W. Damus schrieb:
>> Yes,
>> You can define a custom Environment (extending AbstractEnvironment or
>> EcoreEnvironment is advisable) that the parser uses to look up type names
>> and operation signatures. You can provide fake EOperations as though
>> they had been defined on your model EClassifiers, and in a corresponding
>> custom EvaluationEnvironment implement the evaluate(EOperation, int,
>> Object, Object[]) method to "invoke" your "operation".
>> The IOCLHelper can be initialized with an EnvironmentFactory that you
>> provide, which is responsible for creating Environments and
>> EvaluationEnvironments when the parser needs them.
>> HTH,
>> Christian
>>> Chris
| Re: OCL and external mehtods [message #55730 is a reply to message #54920] |
Mon, 02 October 2006 12:55   |
I don't understand, what are states for OCL?? I found something in
OCL-Specification, but I am not sure I understand that.
To add a customized new function to OCLParser, to I have to add a new State?
I have also found lookup Pathname, which looksup the Classifiers.
"Helper.testfunction(self)"
so lookupPathname must have a Helper, is this right??
Chris
> Hi, Chris,
> Cheers,
> Christian
>> Thanx Chris
>>> Yes,
>>> HTH,
>>> Christian
>>>> Chris
| Re: OCL and external mehtods [message #56156 is a reply to message #55730] |
Tue, 03 October 2006 10:32   |
OK I saved the problem: here a bit of code
public static class MyEnvironmentFactory extends
AbstractEnvironmentFactory {
public EvaluationEnvironment createEvaluationEnvironment() {
EvaluationEnvironment evalEnv = new EvalEnvironment();
evalEnv.add("help", OCLHelperFactory.eINSTANCE.createHelper());
return evalEnv;
protected Environment createEnvironment(EPackage packageContext) {
return new MyEnvironment(packageContext);
protected EClassifier asEClassifier(Object context) {
return (EClassifier) context;
protected EOperation asEOperation(Object operation) {
return (EOperation) operation;
protected EStructuralFeature asEStructuralFeature(Object property) {
return (EStructuralFeature) property;
public Environment createEnvironment(Environment parent) {
return new MyEnvironment(parent);
private static class MyEnvironment extends EcoreEnvironment {
public MyEnvironment(EPackage packageContext) {
super(packageContext);
init();
private void init() {
Variable vdcl = ExpressionsFactory.eINSTANCE.createVariable();
vdcl.setName("help");
vdcl.setType(TypeUtil.resolveType(this,
OCLHelperPackage.eINSTANCE.getEClassifier("Helper")));
// vdcl.setInitExpression(initExp);
this.addElement("help", vdcl, true);
public MyEnvironment(Environment parent) {
super(parent);
init();
protected void collectStates(EClassifier owner, List pathPrefix,
List states) {
super.collectStates(owner, pathPrefix, states);
public EClassifier lookupPathName(List names) {
if (names.get(0).equals("Helper")) {
return OCLHelperPackage.eINSTANCE.getEClassifier((String)
names.get(0));
return super.lookupPathName(names);
> Chris
>> Hi, Chris,
>> Cheers,
>> Christian
>>> Thanx Chris
>>>> Yes,
>>>> HTH,
>>>> Christian
>>>>> Chris
| Re: OCL and external mehtods [message #56457 is a reply to message #55730] |
Wed, 04 October 2006 09:21   |
Hi, Chris,
States are only defined by the CompleteOCL because state machines are a UML
modeling construct, not EMOF. In UML, an OCL constraint can query what
State an instance of a particular Classifier is in (when that Classifier is
a BehavioredClassifier defining (or inheriting) at least one StateMachine.
So, as you indicated in your follow-up, these states have nothing to do with
your problem.
Christian
> State? I have also found lookup Pathname, which looksup the Classifiers.
> Chris
<snip>
| Re: OCL and external mehtods [message #56484 is a reply to message #56156] |
Wed, 04 October 2006 09:24  |
Hi, Chris,
That looks good. You'll have an implicitly defined variable named 'help' in
the context of every OCL expression that you parse. That's neat!
This would be a good example to post on the EMFT Wiki page for others to
follow who need to get started with customizing environments. I should see
about getting a faq/example-sharing forum started there.
Christian
> return evalEnv;
> init();
> super(parent);
> init();
> @Override
> List states) {
> @Override
> names.get(0));
<snip>
| Re: OCL and external mehtods [message #592528 is a reply to message #53794] |
Thu, 28 September 2006 09:25  |
Yes,
and operation signatures. You can provide fake EOperations as though they
had been defined on your model EClassifiers, and in a corresponding custom
EvaluationEnvironment implement the evaluate(EOperation, int, Object,
HTH,
Christian
> Chris
| Re: OCL and external mehtods [message #592673 is a reply to message #54065] |
Fri, 29 September 2006 04:24  |
Thanx Chris
> Yes,
> HTH,
> Christian
>> Chris
| Re: OCL and external mehtods [message #592905 is a reply to message #54419] |
Hi, Chris,
Christian
> Thanx Chris
>> Yes,
>> HTH,
>> Christian
>>> Chris
| Re: OCL and external mehtods [message #593238 is a reply to message #54920] |
Chris
> Hi, Chris,
> Cheers,
> Christian
>> Thanx Chris
>>> Yes,
>>> HTH,
>>> Christian
>>>> Chris
| Re: OCL and external mehtods [message #593453 is a reply to message #55730] |
return evalEnv;
init();
super(parent);
init();
List states) {
names.get(0));
> Chris
>> Hi, Chris,
>> Cheers,
>> Christian
>>> Thanx Chris
>>>> Yes,
>>>> HTH,
>>>> Christian
>>>>> Chris
| Re: OCL and external mehtods [message #593592 is a reply to message #55730] |
Hi, Chris,
your problem.
Christian
> Chris
<snip>
| Re: OCL and external mehtods [message #593604 is a reply to message #56156] |
Hi, Chris,
Christian
> return evalEnv;
> init();
> super(parent);
> init();
> @Override
> List states) {
> @Override
> names.get(0));
<snip>
Current Time: Sun Nov 09 08:46:57 EST 2025
Powered by FUDForum. Page generated in 0.08879 seconds
