Not getting Chart Designer [message #53670] |
Tue, 05 July 2005 17:32  |
Originally posted by: sumesh.bhagat.dwango.com
I am using eclipse 3.1 and I have all the BIRT plug-ins in my plug-in
folder.
When I am trying to design a report with chart , i get error
"The extension name "null" of element "Chart" is not found".
I don't get the chart designer ot the chart on the report to edit it.
Any help will be higlly appreciated.
Thanks in advance.
Re: Not getting Chart Designer [message #55824 is a reply to message #55018] |
Mon, 11 July 2005 04:11   |
Originally posted by: none.none.com
It seems there is still something in your environment that is causing the
issue, this normally works fine.
Are you running Eclipse under Linux or Windows? If you use Linux, please
provide some details about which version you are using.
Did you make a fresh install or did you override your Eclipse file back to
3.0.1? If you did override, I suggest to create a new workspace, and if it
still doesn't work, to do a fresh install in a empty directory. Some files
of the older version might still be used.
David
"Sumesh" <sumesh.bhagat@dwango.com> wrote in message
news:202fb46afb0ef037843c31fed8fbc770$1@www.eclipse.org...
> Hi David
> I reverted eclipse back to 3.0.1 and installed EMF.
> Now I am able to get the chart designer and it works.
> But I am having problem with property editor. It doen't open.
> Also when I create style , I can't change the font.
> Here is the stack trace from .log.
> !ENTRY org.eclipse.core.runtime 4 2 Jul 07, 2005 17:14:39.483
> !MESSAGE Problems occurred when invoking code from plug-in:
> "org.eclipse.core.runtime".
> !STACK 0
> org.eclipse.swt.SWTException: Widget is disposed
> at org.eclipse.swt.SWT.error(SWT.java:2691)
> at org.eclipse.swt.SWT.error(SWT.java:2616)
> at org.eclipse.swt.SWT.error(SWT.java:2587)
> at org.eclipse.swt.widgets.Widget.error(Widget.java:546)
> at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:296)
> at org.eclipse.swt.widgets.Control.setVisible(Control.java:2595 )
> at org.eclipse.swt.widgets.TabItem.releaseChild(TabItem.java:18 0)
> at org.eclipse.swt.widgets.Widget.dispose(Widget.java:480)
> at
> org.eclipse.birt.report.designer.ui.views.attributes.Default PageGenerator.createTabItems(DefaultPageGenerator.java:43)
> at
> org.eclipse.birt.report.designer.ui.views.attributes.Categor yPageGenerator.createTabItems(CategoryPageGenerator.java:218 )
> at
> org.eclipse.birt.report.designer.ui.views.attributes.Atrribu tesBuilder.createPages(AtrributesBuilder.java:66)
> at
> org.eclipse.birt.report.designer.ui.views.attributes.Attribu teView.resetTabFolder(AttributeView.java:229)
> at
> org.eclipse.birt.report.designer.ui.views.attributes.Attribu teView.selectionChanged(AttributeView.java:342)
> at
> org.eclipse.ui.internal.AbstractSelectionService$3.run(Abstr actSelectionService.java:153)
> at
> org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
> at org.eclipse.core.runtime.Platform.run(Platform.java:747)
> at
> org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelectionService.java:151)
> at
> org.eclipse.ui.internal.AbstractSelectionService$1.selection Changed(AbstractSelectionService.java:66)
> at
> org.eclipse.ui.part.MultiPageSelectionProvider$1.run(MultiPa geSelectionProvider.java:70)
> at
> at
> org.eclipse.ui.part.MultiPageSelectionProvider.fireSelection Changed(MultiPageSelectionProvider.java:68)
> at
> org.eclipse.ui.part.MultiPageEditorSite.handleSelectionChang ed(MultiPageEditorSite.java:299)
> at
> org.eclipse.ui.part.MultiPageEditorSite$1.selectionChanged(M ultiPageEditorSite.java:247)
> at
> at
> at
> at
> at
> at
> org.eclipse.gef.ui.parts.AbstractEditPartViewer.fireSelectio nChanged(AbstractEditPartViewer.java:240)
> at
> org.eclipse.birt.report.designer.internal.ui.editors.parts.D eferredGraphicalViewer.access$001(DeferredGraphicalViewer.ja va:58)
> at
> org.eclipse.birt.report.designer.internal.ui.editors.parts.D eferredGraphicalViewer$1.run(DeferredGraphicalViewer.java:30 4)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
> at
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2754)
> at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2537)
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
> at
> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:324)
> at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
> at org.eclipse.core.launcher.Main.run(Main.java:704)
> at org.eclipse.core.launcher.Main.main(Main.java:688)
FUDForum. Page generated in 0.05097 seconds
