| Getting the label at the center [message #4765] |
Thu, 03 August 2006 08:54  |
Originally posted by: sayed.shoed.tavant.com
I have a node which has a name property.I want to set the label for the
name at the vertical center of my node.I tried to use Constrained
toolbar layout but could not get the desired result.Could anyone please
tell me how to do it.
Sayed Aamir Shoeb
| Re: Getting the label at the center [message #6471 is a reply to message #6453] |
Fri, 04 August 2006 05:31   |
Hei,
Even we got the code, the following code will make the label come in the
center. I will try to make a layout of it
setLayoutManager(new StackLayout() {
public void layout(IFigure figure) {
Rectangle r = figure.getClientArea();
List children = figure.getChildren();
IFigure child;
Dimension d;
for (int i = 0; i < children.size(); i++) {
child = (IFigure)children.get(i);
d = child.getPreferredSize(r.width, r.height);
d.width = Math.min(d.width, r.width);
d.height = Math.min(d.height, r.height);
Rectangle childRect = new Rectangle(
r.x + (r.width - d.width)/2,
r.y + (r.height - d.height)/2,
d.width,
d.height);
child.setBounds(childRect);
Sayed Aamir Shoeb
Dmitry Stadnik wrote:
> Hello!
> Wow - it uses GeoShapeCylinderFigure that extends GeoShapeFigure
> that uses modified StackLayout to center content pane )))
> You could ask GMF runtime team to refactor this layout manager for
> public use or just copy the code.
> sayed wrote:
>> I think the geoshapes plugin example has this. For example, when you
>> create a cylinder figure you are prompted to enter some name and that
>> name appears in the center of the figure.
>> I started from CylinderEditPart(GeoShapeEditPart, ShapeNodeEditPart)
>> and digged through the subclasses to see the layout being used but
>> couldnt get hold of it. My guess is I do not have to write layouts
>> from scratch!!! Can someone point me to the classes where this is
>> being done in geoshapes?
>>> Hello!
>>> It's not that hard to write your own draw2d layout; StackLayout
>>> may be a good starting point.
>>> sayed wrote:
>>>> Hi,
>>>> the name at the vertical center of my node.I tried to use
>>>> Constrained toolbar layout but could not get the desired
>>>> result.Could anyone please tell me how to do it.
>>>> Thanks
>>>> Sayed Aamir Shoeb
| Re: Getting the label at the center [message #108992 is a reply to message #6471] |
Mon, 05 March 2007 15:08  |
Hi there,
I tried this to get the label of my elliptical node centred. But it
doesn't work. I put it in the CreateNodeFigure-method of *EditPart of
the Figure.
Is it the problem because of the rectangle as box for the ellipse? I
also iterated a step deeper with the children, so I can get the label of
the ellipse, but here too -> nothing happens with the label, I is top
centred but not vertically.
Thanks for help
Jens
sayed schrieb:
> Hei,
> IFigure child;
> Dimension d;
> d.width,
> d.height);
> Sayed Aamir Shoeb
>> Hello!
>> sayed wrote:
>>> Hi,
>>>> Hello!
>>>> sayed wrote:
>>>>> Hi,
>>>>> Thanks
>>>>> Sayed Aamir Shoeb
FUDForum. Page generated in 0.04300 seconds
