Home » Language IDEs » PHP Development Tools (PDT) » Edit over ftp
Edit over ftp [message #52225] Mon, 17 September 2007 09:54 Go to next message
Originally posted by: fubarov.gmail.com
Will it be possible in 1.0 version of PDT to manage files/projects over
ftp?
Sorry if this has been discsussed, but i'm new here and look for Zend IDE
replacement and this is the only thing that still stops me to use eclipse
pdt...
Fubar
Re: Edit over ftp [message #52282 is a reply to message #52225] Mon, 17 September 2007 14:11 Go to previous messageGo to next message
Originally posted by: james.gnr-inc.com
> ftp?
> IDE replacement and this is the only thing that still stops me to use
> eclipse pdt...
> Fubar
You can try http://download.eclipse.org/dsdp/tm/downloads/ and use RSE.
I personally use JCraft's SFTP plugin and create local projects.
James
Re: Edit over ftp [message #52386 is a reply to message #52225] Mon, 17 September 2007 16:21 Go to previous messageGo to next message
Originally posted by: joakim.astrocalc.com
I use the aptana plugin for this, it has a builtin ftp client and also a
very nice syncronize feature so it's quite easy to work locally with a
project and then just sync changes with your online site. In software
updates add a new remote site
URL: http://update.aptana.com/install/3.2/
There are several plugins in the Aptana Web development tools, I am not
sure in which the ftp is as I have them all installed. I am quite new to
eclipse as well but the aptana plugins are a nice collection.
You may like to look at their site www.aptana.com as well
/JS
Re: Edit over ftp [message #52469 is a reply to message #52282] Tue, 18 September 2007 05:12 Go to previous messageGo to next message
Thanks very much for the quick answers, i'll try all proposed methods, i
hope i like at least one of them.
Re: Edit over ftp [message #52575 is a reply to message #52282] Tue, 18 September 2007 09:04 Go to previous messageGo to next message
>> ftp?
>> eclipse pdt...
>> Fubar
> James
Thanks James for the link to RSE - very usefull.
I wonder what happened to the "FTP & WebDAV support" which has been part
of eclipse platform build, but has now been removed. I could not find
anything in the changelogs.
I also tried aptana.. very huge thing
Re: Edit over ftp [message #52653 is a reply to message #52575] Tue, 18 September 2007 10:12 Go to previous messageGo to next message
JCraft's SFTP plugin (http://www.jcraft.com/eclipse-sftp/) is based on
FTP and WebDAV support.
The main difference that I see (in respect to this thread) is that RSE
lets you interact and edit files 'in place' on a Remote file system.
Where JCraft's, FTP and WebDAV make you edit a local copy and
synchronize the file with a remote file store.
Re: Edit over ftp [message #52866 is a reply to message #52386] Wed, 19 September 2007 03:13 Go to previous messageGo to next message
> /JS
Does this work with 3.3 Europa?
Jasmo Hiltula
http://blog.qkaasu.com
Re: Edit over ftp [message #52920 is a reply to message #52653] Wed, 19 September 2007 03:43 Go to previous messageGo to next message
Too bad SFTP plugin doesn't (like FTP and WebDAV before) allow you put any
filters or such a things to exporting list. If there's images or such on a
server, the plugin want's to synchronize them also. It's does not sound
like a big deal but after all, it starts to irritate me.
Jasmo Hiltula
Re: Edit over ftp [message #53129 is a reply to message #52866] Wed, 19 September 2007 13:21 Go to previous messageGo to next message
3.3 Europa is what I am running, so I guess so. However, I have just
noticed problems after an Aptana and PDT update, syncing of my site no
hangs and times out after a while. I don't know if it's because of the
updates, It might be something on my side as well. It has worked fine
until now though.
Re: Edit over ftp [message #53479 is a reply to message #53129] Thu, 20 September 2007 11:39 Go to previous messageGo to next message
Well after some fiddling I replaced my pure-ftpd server in favor of
proftpd and now the Aptana ftp syncing works beautifully. It's a very
handy solution, I work locally and after testing and debugging I just sync
with the online site.
Re: Edit over ftp [message #60834 is a reply to message #53479] Sat, 10 November 2007 05:24 Go to previous messageGo to next message
> sync with the online site.
What is done with file you delete locally? Will it be removed on the
server at the next synchronization?
That is what I'm looking for. I always used the ftp/webdav feature for
remote ftp synchronization. But with Europe 3.3 I cannot get this
feature working properly. I even tried the 3.3M6 version of the ftp/webdav.
regards,
Johnny
Re: Edit over ftp [message #60841 is a reply to message #60834] Sun, 11 November 2007 04:15 Go to previous messageGo to next message
I still use the "old" ftp/webdav feature in Eclipse Europe. It works ok
(like before)..
use the update site provided here:
regards,
Nikolai
> regards,
> Johnny
Re: Edit over ftp [message #60873 is a reply to message #60841] Sun, 11 November 2007 10:34 Go to previous messageGo to next message
Re: Edit over ftp [message #60882 is a reply to message #60841] Sun, 11 November 2007 10:38 Go to previous messageGo to next message
Re: Edit over ftp [message #69757 is a reply to message #60882] Tue, 06 May 2008 10:10 Go to previous message
Originally posted by: stefan.urkman.de
> Nikolai Plath said the following on 11-11-07 10:15:
>> (like before)..
>> regards,
>> Nikolai
>>> regards,
>>> Johnny
> OK already solved. I had to enable it. The ftp/webdav was disabled
> johnny
I have the same Problem. I can't install the sftp PlugIn and I get the
same error.
What do you mean with "enable" the ftp/webdav PlugIn? And how did you
install the ftp/webdav PlugIn?
I'm working on a Mac...
Thanks and greetings,
Stefan Sturm
Previous Topic:mysql function highlighting?
Next Topic:Blue Screen due to Eclipse (PDT?)
Current Time: Tue Sep 16 05:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.11606 seconds
