| selection problem [message #52171] |
Fri, 03 January 2003 11:49  |
I got an MyGraphicalEditPart where I packed several Figures onto, a Label
etc., and finally a plain figure.This figure is returned in method
MyGraphicalEditPart#getContentPane. Then GEF fills this content pane with
other Labels.
In the Editor I can select MyGraphicalEditPart without problem, but I cannot
select any Labels inside MyGraphicalEditPart's content pane, though GEF put
several labels inside. It seems that Figure#findDescendantAtExcluding does
not find any figure inside the content pane, but only the figure
representing the container, and so it does not paint any selection around
the label. But the selection itself is correctly propagated to another
Eclipse View with selected object as my EditPart whose figure is the
selected Label.
Any ideas?
Chris
| Re: selection problem [message #52197 is a reply to message #52171] |
Fri, 03 January 2003 12:57  |
Originally posted by: hudsonr.us.eye-bee-em.com
"Chris" <wibni@web.de> wrote in message news:av4e7q$v4c$1@rogue.oti.com...
> Hello,
> other Labels.
cannot
put
> selected Label.
I don't understand. You are contradicting yourself. How is it that the
correct selection is propogated if the figure (and therefore EditPart)
wasn't found? That isn't possible. The EditPart is probably selected, but
the selection (i.e. handles) is not appearing for some reason.
> Any ideas?
> Chris
FUDForum. Page generated in 0.19613 seconds
