Home » Archived » Visual Editor (VE) » Support for javax.swing.Box?
Support for javax.swing.Box? [message #51215] Thu, 22 July 2004 07:23 Go to next message
I just started using VE. I have Eclipse 3.0.0-200406251208,
VE-runtime-S20040628, GEF-runtime-30, and emf-sdo-runtime-2.0.0.
I would like to use javax.swing.Box, but it is not in the Containers
list. If I create one manually, it shows as an opaque object in the
Beans view. It has no properties, and no components under it.
Does VE not support Box? If so, what am I doing wrong? If not, is
there a schedule for supporting it?
Thank you.
Jim McMaster
mailto:jim.mcmaster@comcast.net
Re: Support for javax.swing.Box? [message #51247 is a reply to message #51215] Thu, 22 July 2004 08:54 Go to previous messageGo to next message
Jim,
Using java.swing.Box is not currently supported by the VE. There's a
feature enhancement request for this support
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=49431) but it's not
likely to get much attention in the near future. This would be an
excellent contribution from the Open Source community, should someone
want to tackle it.
Sorry that I don't have better news,
- Jeff
> Thank you.
Re: Support for javax.swing.Box? [message #51355 is a reply to message #51247] Thu, 22 July 2004 10:15 Go to previous messageGo to next message
Originally posted by: mcmaster_j.cde.state.co.us
At 7/22/2004 6:54:03 AM, Jeff Myers wrote:
> Jim,
> want to tackle it.
I searched for an existing bug, but 49431 just says, "Provide easy way
to add Box struts." I thought there was some other problem. I really
cannot believe this was omitted from VE, and it really will impact my
development.
Thank you for the response. If I do want to work on this, how would I
go about it?
Jim McMaster
Re: Support for javax.swing.Box? [message #51383 is a reply to message #51355] Thu, 22 July 2004 10:36 Go to previous messageGo to next message
Hi Jim,
Sorry, I just took a look at the Box API again and realized that the
issue with supporting it isn't as simple as implementing tooling to
graphically manipulate a Box. The VE currently doesn't support calling
factory methods to create graphical components that it needs to know
about. So the issue is that we can't deal with the Box.createXXX() methods.
There's a bug open against this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=48597
This may be addressed sooner than my previous pessimistic prediction, as
these sort of factory methods are important for the SWT code style. We
haven't had many people using the Box class, so haven't had many
complaints about our lack of support for it.
- Jeff
> development.
> go about it?
Re: Support for javax.swing.Box? [message #51411 is a reply to message #51383] Thu, 22 July 2004 10:45 Go to previous message
At 7/22/2004 8:36:55 AM, Jeff Myers wrote:
> Hi Jim,
> calling factory methods to create graphical components that it needs
> to know about. So the issue is that we can't deal with the
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=48597 This may be
> addressed sooner than my previous pessimistic prediction, as these
That makes a lot more sense. My earlier question still stands, though.
If I wanted to work on the issue, how would I go about it?
Jim McMaster
Re: Support for javax.swing.Box? [message #595590 is a reply to message #51215] Thu, 22 July 2004 08:54 Go to previous message
Jim,
want to tackle it.
- Jeff
> Thank you.
Re: Support for javax.swing.Box? [message #595631 is a reply to message #51247] Thu, 22 July 2004 10:15 Go to previous message
> Jim,
> want to tackle it.
development.
go about it?
Jim McMaster
Re: Support for javax.swing.Box? [message #595642 is a reply to message #51355] Thu, 22 July 2004 10:36 Go to previous message
Hi Jim,
- Jeff
> development.
> go about it?
Re: Support for javax.swing.Box? [message #595649 is a reply to message #51383] Thu, 22 July 2004 10:45 Go to previous message
> Hi Jim,
Jim McMaster
Previous Topic:Browsing the VE Source
Next Topic:working on VE from different machines
Current Time: Thu Nov 20 06:02:48 EST 2025
Powered by FUDForum. Page generated in 0.13643 seconds
