Home » Archived » XML Schema Definition (XSD) » xsd:any - namespace problem
xsd:any - namespace problem [message #49795] Thu, 05 August 2004 10:44 Go to next message
Originally posted by: alastair.dunsmore.mottmac.com
I have been trying to import an XML Schema file (via Eclipse into a new
EMF Java project) and each time it came back with the same error:
Problems were detected while validating and converting the XML Schemas
Error: XSD: The element 'http://www.trip.org/schema/trip#name' may not
overlap with a wildcard allowing its namespace : URI
file:/C:/appdev/HAREGISTRY/problem_example.xsd Line 4 Column 3
Error: XSD: The element 'http://www.trip.org/schema/trip#linkDistance'
may not overlap with a wildcard allowing its namespace : URI
I have included below a cut down version of the schema that highlights the
problem. It does import if (1) the xsd:any is removed or (2) the
minOccurs="0"
is removed for the xsd:element name="linkDistance"?
Can anyone suggest if this is an issue/bug with XSD or with the XML Schema
I
am dealing with?
Thanks for any help,
Alastair
<xsd:schema targetNamespace="http://www.trip.org/schema/trip"
elementFormDefault="qualified" version="2.0"
xmlns="http://www.tript.org/schema/trip"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:complexType name="RaceSubject">
<xsd:sequence>
<xsd:element name="name" type="xsd:string" minOccurs="0"/>
<xsd:element name="linkDistance" type="xsd:decimal"
minOccurs="0"/>
<xsd:any minOccurs="0" maxOccurs="unbounded"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Re: xsd:any - namespace problem [message #49825 is a reply to message #49795] Thu, 05 August 2004 11:04 Go to previous messageGo to next message
Alastair,
Your schema violates the Unique Particle Attribute rule from appendix H
in the spec. This is a very hard constraint to check, so many
validators don't bother. When parsing an instance that starts with
<name> and is followed by <linkDistance> it will be ambiguous whether
<linkDistance> matches the <linkDistance> element in the grammar, or
whether it matches the <any> in the grammar, with the <linkDistance>
element being missing as allowed by the fact that it's optional in the
grammar.
Alastair Dunsmore wrote:
>Hi,
>minOccurs="0"
>I
>am dealing with?
>Alastair
><?xml version="1.0" encoding="UTF-8"?>
> <xsd:sequence>
>minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
></xsd:schema>
Re: xsd:any - namespace problem [message #49855 is a reply to message #49825] Thu, 05 August 2004 11:31 Go to previous message
Thanks very much for your help and quick reply,
Alastair.
Ed Merks wrote:
> Alastair,
> grammar.
> >Hi,
> >minOccurs="0"
> >I
> >am dealing with?
> >Alastair
> > <xsd:sequence>
> >minOccurs="0"/>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:schema>
Re: xsd:any - namespace problem [message #590011 is a reply to message #49795] Thu, 05 August 2004 11:04 Go to previous message
Alastair,
grammar.
>Hi,
>minOccurs="0"
>I
>am dealing with?
>Alastair
> <xsd:sequence>
>minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
></xsd:schema>
Re: xsd:any - namespace problem [message #590022 is a reply to message #49825] Thu, 05 August 2004 11:31 Go to previous message
Alastair.
Ed Merks wrote:
> Alastair,
> grammar.
> >Hi,
> >minOccurs="0"
> >I
> >am dealing with?
> >Alastair
> > <xsd:sequence>
> >minOccurs="0"/>
> > </xsd:sequence>
> > </xsd:complexType>
> ></xsd:schema>
Previous Topic:xsd:any - namespace problem
Next Topic:Correct insertion point for child elements according to schema
Current Time: Sat Nov 22 13:08:46 EST 2025
Powered by FUDForum. Page generated in 0.04082 seconds
