Problem with pluginPath (headless build) [message #49223] |
Wed, 04 March 2009 12:55  |
Originally posted by: birt.lewold.at
I have a very strange problem:
I have multiple plugins. To keep it simple assume PluginA depends on PluginB
Because of various reasons I don't want to build them in the same buildDirectory. (main
reason is, that two running headless builds conflict with each other if they use the same
buildDirectory).
So I build them in separate build directories and copy the resulting plugins into
/MyBuildResults/plugins
in build.properties i specify
pluginPath=/MyBuildResults
When building PluginB it seems to find PluginA (during "generateScript" it checks for
missing plugins, and PluginA is not listed there .... if I delete PluginA it gets listed).
But .... I get "the import cannot be resolved" ERRORs for all my classes in PluginA.
If I would build everything in the same plugin directory things work correct.
Can anyone out there enlighten me what I am doing wrong?
Chris
Re: Problem with pluginPath (headless build) [message #50081 is a reply to message #49381] |
Tue, 10 March 2009 15:25  |
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=157375
The problem is basically that the java compiler can't compile against
nested jars. So they will need to be extracted first.
PDE/Build doesn't (yet) do this extraction automatically.
-Andrew
Chris wrote:
> I checked that ... PluginA is contained in the classpath.
> I think I figured out the source of the problem .....
> PluginA is a plugin wrapping a "plain old java JAR file" and exporting
> the classes contained there (using the Runime page in the Manifest editor).
> It seems that the eclipse build process is not able to resolve such
> types of plugins.
> Chris
> Manuel Selva wrote:
>> May be you can have a look at the generated build.xml file for the
>> plug-in B which doesn't compile. Mainly you should check the @dot
>> target in charge of compiling the plug-in, check the classpath
>> attribute here to be sure that A is there ...
>> Manu
Re: Problem with pluginPath (headless build) [message #592769 is a reply to message #49223] |
Thu, 05 March 2009 02:35  |
First of all I want to correct a simple thing:
Of course I meant that PluginB depends on PluginA.
I found out some otherr thing ....
This does not work .....
/MyBuildResults/plugins/PluginA_1.1.0.20080303.jar
If I unpack the plugin so that it looks like
/MyBuildResults/plugins/PluginA_1.1.0.20080303 (folder containing the JARs contents)
Then everything works as expected.
Please please someone tell me I am doing something severely wrong.
Why does pluginPath not pick up plugin JAR files ??????
Chris
> PluginB
> buildDirectory. (main reason is, that two running headless builds
> conflict with each other if they use the same buildDirectory).
> plugins into
> it checks for missing plugins, and PluginA is not listed there .... if I
> in PluginA.
> correct.
> Chris
Re: Problem with pluginPath (headless build) [message #592794 is a reply to message #49223] |
Thu, 05 March 2009 04:36  |
May be you can have a look at the generated build.xml file for the plug-in
B which doesn't compile. Mainly you should check the @dot target in charge
of compiling the plug-in, check the classpath attribute here to be sure
that A is there ...
Manu
Re: Problem with pluginPath (headless build) [message #592808 is a reply to message #49351] |
Thu, 05 March 2009 06:20  |
PluginA is a plugin wrapping a "plain old java JAR file" and exporting the classes
It seems that the eclipse build process is not able to resolve such types of plugins.
Chris
Manuel Selva wrote:
> plug-in B which doesn't compile. Mainly you should check the @dot target
> in charge of compiling the plug-in, check the classpath attribute here
> Manu
Re: Problem with pluginPath (headless build) [message #593093 is a reply to message #49381] |
-Andrew
> types of plugins.
> Chris
> Manuel Selva wrote:
>> Manu
FUDForum. Page generated in 0.04577 seconds
