Home » Language IDEs » Java Development Tools (JDT) » jdk 1.5, and early release stuff
jdk 1.5, and early release stuff [message #49222] Wed, 04 June 2003 18:12 Go to next message
Originally posted by: tgm1024SiteNameMispelled.hotmale.com
If I were to install the sun early adopter stuff for experimenting with
generics and other things, will eclipse work ok with it even though the
eclipse syntax engine itself will not like things like
List<String> list = new ArrayList<String>();
Thanks.
Re: jdk 1.5, and early release stuff [message #49417 is a reply to message #49222] Wed, 04 June 2003 19:06 Go to previous messageGo to next message
Originally posted by: faust.acm.org
This won't work until the Eclipse compiler supports it (on the 3.0 plan).You
can turn off all compilation and use ANT to build. And you can associate
..java files with the default text editor instead of the Java editor if
that's giving you grief. So I suppose if you hack around, you can get this
to "work."
Randy
"Muad'Dib" <tgm1024SiteNameMispelled@hotmale.com> wrote in message
news:bblqvd$ps4$1@rogue.oti.com...
> Thanks.
Re: jdk 1.5, and early release stuff [message #49476 is a reply to message #49417] Wed, 04 June 2003 19:25 Go to previous messageGo to next message
Sounds like time for vi or emacs as my IDE for experimenting with the early
adoption releases. Thanks for yor reply!
In news:bblu2n$rjv$1@rogue.oti.com,
Randy Faust <faust@acm.org> spoke unto us:
> plan).You can turn off all compilation and use ANT to build. And you
> can associate .java files with the default text editor instead of the
> Java editor if that's giving you grief. So I suppose if you hack
> around, you can get this to "work."
> Randy
>> with generics and other things, will eclipse work ok with it even
>> though the eclipse syntax engine itself will not like things like
>> Thanks.
Re: jdk 1.5, and early release stuff [message #49863 is a reply to message #49417] Thu, 05 June 2003 04:56 Go to previous messageGo to next message
plan).You
> to "work."
Maybe you just wait for the first milestone builds. Maybe
some of the requested features are implemented then
(including generics).
Martin (Kersten)
Re: jdk 1.5, and early release stuff [message #49922 is a reply to message #49863] Thu, 05 June 2003 05:54 Go to previous messageGo to next message
i think "wait for one of the last milestone builds to include these features"
is more what we can expect.
johan
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message news:bbn0g7$h3l$1@rogue.oti.com...
> plan).You
> > to "work."
> Martin (Kersten)
Re: jdk 1.5, and early release stuff [message #50528 is a reply to message #49922] Thu, 05 June 2003 11:54 Go to previous messageGo to next message
Why doesn't eclipse have a simple option:
O turn off jdk specifics
or
O Allow experimental jdk's such as early adoptions
To turn off specific syntax highlighting and the like?
In news:bbn3vq$k49$1@rogue.oti.com,
Johan Compagner <jcompagner@j-com.nl> spoke unto us:
> features"
> johan
>> plan).You
>>> Java editor if
>>> get this
>>> to "work."
>> Martin (Kersten)
Re: jdk 1.5, and early release stuff [message #50828 is a reply to message #50528] Thu, 05 June 2003 14:03 Go to previous messageGo to next message
Why would you turnf off syntax highlighting?
I just imported Test.java of the generics zip into Eclipse
and it colors it fine
The only problem is that Eclipse has an internal compiler
that doesn't reconize that code. That's the big problem.
johan
"Muad'Dib" <tgm1024SiteNameMispelled@hotmale.com> wrote in message news:bbnp7h$8u3$1@rogue.oti.com...
> or
> > features"
> > johan
> >> plan).You
> >>> Java editor if
> >>> get this
> >>> to "work."
> >> Martin (Kersten)
Re: jdk 1.5, and early release stuff [message #51404 is a reply to message #49922] Fri, 06 June 2003 05:14 Go to previous messageGo to next message
We are indeed considering the 1.5 effort in the second half of the
development cycle for 3.0.
"Johan Compagner" <jcompagner@j-com.nl> wrote in message
news:bbn3vq$k49$1@rogue.oti.com...
features"
> johan
> > plan).You
associate
this
> > > to "work."
> > Martin (Kersten)
Re: jdk 1.5, and early release stuff [message #52263 is a reply to message #50528] Sat, 07 June 2003 06:52 Go to previous messageGo to next message
What would that do?
> or
....and what would that do? You can use "experimental JDKs"
fine as it is.
That sounds worse than useless to me.
__________
|im |yler http://timtyler.org/ tim@tt1.org
Re: jdk 1.5, and early release stuff [message #52565 is a reply to message #52263] Sat, 07 June 2003 15:48 Go to previous messageGo to next message
In news:bbsg4u$hp2$1@rogue.oti.com,
Tim Tyler <tim@tt1.org> spoke unto us:
> What would that do?
Turn off anything within eclipse that was specific to a particular jdk
release.
>> or
> fine as it is.
You seem to be at odds with everyone else's post in this thread.
Re: jdk 1.5, and early release stuff [message #52622 is a reply to message #52565] Sat, 07 June 2003 17:16 Go to previous messageGo to next message
> > What would that do?
> release.
Such as?
What is specific to a particular JDK?
> >> or
> > fine as it is.
using a JDK (the jre of the jdk) can be used perfectly fine
(If you had the JDK1.5 beta now you could use it for running and debugging)
The problem with JDK1.5 that javac is changed pretty much and the internal
compiler of eclipse has to catchup.
johan
Re: jdk 1.5, and early release stuff [message #52649 is a reply to message #52622] Sat, 07 June 2003 18:09 Go to previous messageGo to next message
In news:bbtko3$2f2$1@rogue.oti.com,
>>> What would that do?
>> jdk release.
> Such as?
Numerous language changes in 1.5. Generics, for loop iterator enhancement,
Boxing/unboxing of primitives, yadda. These require a different javac.exe
and eclipse is bound to it's internal compiler's revs.
There should be a way to turn off the jdk revision specific stuff, hence
turn off its reliance upon the internal compiler, to just allow external
compilation. Visual Cafe for Java used to do just that, back when it was
alive before borland bought 'em. You had a crap load of fields to fill out,
but you could set it up to use any jdk release when they ended up obsoleting
the one built into the ide.
But you answer yourself in the following paragraphs.
>>>> or
>>> fine as it is.
> debugging)
Sure, if that's all you want it for. I tend to use an IDE for /compiling/
too.
> internal compiler of eclipse has to catchup.
> johan
RIGHT. Which according to folks here, means that I cannot develop using
1.5-isms with eclipse as it stands before rev 3.0.
Re: jdk 1.5, and early release stuff [message #53196 is a reply to message #52649] Mon, 09 June 2003 09:07 Go to previous messageGo to next message
Just turn off auto build and make a ANT builder that uses the javac command.
Of course the Java Editor will still not understand generics code
and i think there will be other problems that could also arise for
example with code completion..
> too.
with an ant builder this should be possible,
> > johan
1.5 isn't even out yet (and i mean out as the first beta)
of course you could use the early adaptor generices lib for looking at it.
But i wouldn't build any code with it as long as the first beta's or RC are
appearing. Because it is still a running target. That's why i believe
eclipse won't support it in the first Milestones of the 3.0 release.
Because then they are constantly playing catchup. Hopefully the generices
spec will stablelize as soon as possible.
But even if an ide had just a javac call. Then i still believe that the IDE
has to be alterd to support all the new syntax (think about the editor)
I also don't know exactly which roadmaps ends first the one of eclispe 3.0
or the one of 1.5? If i have to guess then i think we have Eclipse 3.0 final
long before a 1.5 final so if eclise supports it then it is fine by me.
johan
Re: jdk 1.5, and early release stuff [message #53274 is a reply to message #52649] Mon, 09 June 2003 11:21 Go to previous messageGo to next message
news:bbtnuc$3l1$1@rogue.oti.com...
> >>> What would that do?
> >> jdk release.
> > Such as?
enhancement,
A "turn off jdk specifics" option would help with this not in the slightest.
> compilation.
There already is - use javac, jikes - or whatever - as an external tool.
See the "Run > External tools" menu.
> to fill out, but you could set it up to use any jdk release when
> they ended up obsoleting the one built into the ide.
So - do that with Eclipse - if you really want.
It can call command-line utilities like the best of them.
__________
Re: jdk 1.5, and early release stuff [message #53412 is a reply to message #53196] Mon, 09 June 2003 14:02 Go to previous messageGo to next message
In news:bc2481$b63$1@rogue.oti.com,
....[snipity doo dah]...
> the IDE has to be alterd to support all the new syntax (think about
> the editor)
Not really---there could be an option like I suggested to turn off anything
in the editor (and anything else in the ide) that is language specific.
Ok, thanks for your suggestions though. I'll give them a whack.
Re: jdk 1.5, and early release stuff [message #66342 is a reply to message #53412] Tue, 24 June 2003 14:32 Go to previous message
To be honest - if you will turn off java support in eclipse, you end up
with quite big and not very good text editor. There is a plenty of
better tools out there for that. For me, strength of eclipse lies in
tight integration with content you are editing - all metadata about
source code available for entire IDE. Without it, eclipse editor itself
isn't worth enough. You can do a lot better with jedit.
Artur
Previous Topic:[ANN] release 1.3.2 of metrics plugin
Next Topic:Copying files from a plug-in subdirectory to a project subdirectory
Current Time: Wed Nov 12 08:49:46 EST 2025
Powered by FUDForum. Page generated in 0.05921 seconds
