Home » Archived » XML Schema Definition (XSD) » Use xsd library in java applet
Use xsd library in java applet [message #49200] Wed, 21 July 2004 03:04 Go to next message
Originally posted by: babytoys.mail.ru
Can I use xsd parser in applet transferred via net? If I start my applet
from browser I receive the following exception:
java.security.AccessControlException: access denied
(java.lang.RuntimePermission setContextClassLoader)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.Thread.setContextClassLoader(Unknown Source)
at org.eclipse.xsd.util.XSDParser.<init>(XSDParser.java:408)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:321)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
org.eclipse.xsd.impl.XSDSchemaImpl.getMagicSchemaForSchema(X SDSchemaImpl.java:553)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:631)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:708)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2040)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1485)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2241)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
at org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 88)
Re: Use xsd library in java applet [message #49407 is a reply to message #49200] Mon, 26 July 2004 08:27 Go to previous message
Vladimir,
In the past, we needed to play classloader games for Xerces/JAXP to work
properly, but I have a feeling we don't need to do that now that it's
part of the JDK. If you open a bugzilla, with a test case and
instructions for how to reproduce this failure, I'll investigate whether
we can remove/improve that code.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Use xsd library in java applet [message #589857 is a reply to message #49200] Mon, 26 July 2004 08:27 Go to previous message
Vladimir,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Duplicate name/target namespace error
Next Topic:Duplicate name/target namespace error
Current Time: Mon Nov 03 19:33:28 EST 2025
Powered by FUDForum. Page generated in 0.03610 seconds
