Home » Eclipse Projects » Eclipse Platform » How do I make a separate all projects in a working set from all other projects ?
How do I make a separate all projects in a working set from all other projects ? [message #49022] Tue, 27 May 2003 03:46
Originally posted by: mikael.thorman.wirelesscar.com
I haven't been able to understand how I separate the projects in a working
set from all other projects (in other working sets).
If I select rebuild all I only want the projects in the selected working set
to be rebuilt not all open projects in other working sets.
It would also be great if I could filter the tasks in the task list on the
opened working space (without having to select it manually every time I
change working sets).
I have probably missed something here, but in JBuilder, which I have worked
with before, you can have workspaces with a list of projects, which are
totally separated from each other.
I have seen that one can have different workspaces in Eclipse as well, but
then I have to redo all settings and everything.
I only want to be able to have a working set with a list of projects that
belongs to a specific business project.
Am I misunderstanding the working flow for Eclipse or isn't this implemented
yet ?
Thanks for any help.
// Mikael
Previous Topic:[ANN] Eclipse profiler plugin, 0.5.22
Next Topic:how to interrupt/cancel the closing of a viewPart
Current Time: Thu Nov 06 11:44:53 EST 2025
Powered by FUDForum. Page generated in 0.03625 seconds
