Home » Archived » BIRT » API Description Getting A Report To Run
API Description Getting A Report To Run [message #48022] Sun, 19 June 2005 18:19 Go to next message
Hi All,
In the ...engine.api description there is sample code:
ReportEngine engine = new ReportEngine(null);
IReportRunnable design = engine.openReportDesign("C:/temp/test.rptdesign");
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
IOutputSetting setting = new OutputSetting();
setting.setOutputFileName("C:/temp/test.html");
task.setOutputSetting(setting);
task.run();
Where do you import IOutputSetting and OutputStting from. Don't see them in
the API.
Thanks for any help.
Tom
Re: API Description Getting A Report To Run [message #51835 is a reply to message #48022] Mon, 27 June 2005 13:16 Go to previous message
Hi, Tom,
The correct interface to use is IRenderOption.
Stanley Wang
BIRT Engine
Previous Topic:width of cells?
Next Topic:page number
Current Time: Fri Nov 21 04:06:38 EST 2025
Powered by FUDForum. Page generated in 0.04315 seconds
