| Inherited attributes [message #46846] |
Thu, 03 June 2004 05:57  |
Originally posted by: invalid.soft-gems.net
Hi group,
Currently I'm trying to collect all attributes from a given type in my
schemas. Essentially, this is my code for this task:
EList xsdAttributes = complexType.getAttributeContents();
iterator = xsdAttributes.iterator();
while (iterator.hasNext())
XSDAttributeUse attributeContent = (XSDAttributeUse) iterator.next();
XMLAttribute attribute = new XMLAttribute(this, attributeContent);
attributes.add(attribute);
Here is an element I'm trying to analyze:
<xs:element name="page" substitutionGroup="odie:tableGroup">
<xs:complexType>
<xs:complexContent>
<xs:extension base="odie:tableType">
<xs:attribute name="cols" type="xs:positiveInteger"
default="80"/>
<xs:attribute name="rows" type="xs:positiveInteger"
default="20"/>
<xs:attribute name="id" type="xs:positiveInteger"
use="required"/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:element>
My problem is that only the 3 here declared attributes are returned by the
above code. In the base type there are more attributes, which I also need.
Is there a single call to get all effective attributes of a given type?
Mike
www.soft-gems.net
| Re: Inherited attributes [message #47113 is a reply to message #47085] |
Thu, 03 June 2004 14:25   |
Mike,
I know that the documentation could be a lot less sparse, but there's never
time to make it less sparse. So I don't mind answering questions...
The XSDComplexTypeDefinition.getContentType() method, for the case of
non-empty complex content, will return a particle that represents the whole
content model. In general, you should look for methods that say they
represent an "infoset property" as these represent things from the abstract
component model as defined in the XML Schema spec and are typically things
that are computed from the concrete syntax (i.e., the methods that say they
are "concrete").
Mike Lischke wrote:
> Ed Merks wrote
> >I see you figured this out in 8 minutes. Probably you read the Javadoc
> to look
> >for useful methods. ;-)
> ;-) It would be cool it would have been so. No, I tried about 2 hours
> before I dared to post a question to the newsgroup (I simply did not
> realize the other method). I'm maintaing a bunch of private news groups
> myself and have a web forum too, so I know what it means to bother others
> with beginners questions. Unfortunately, I can't stop it entirely...
> Btw: a related question, why can I get all inherited attributes but not
> all inherited particles? Currently I'm going through all base types
> recursively to find all elements.
> Mike
> www.soft-gems.net
| Re: Inherited attributes [message #47285 is a reply to message #47265] |
Fri, 04 June 2004 14:57  |
Mike,
Yes, I've often had the distinct feeling that XML Schema is unnecessarily
complex, and as the expression goes, it's very difficult to make a silk purse
out of a sow's ear...
Mike Lischke wrote:
> Ed Merks wrote
> >Use XSDModelGroup.getParticles, which is the infoset property.
> Thank you Ed, I'll try this out on monday. Btw: have you ever had a vague
> feeling that the API is unnessecarily complex ;-) ?
> Mike
> www.soft-gems.net
| Re: Inherited attributes [message #588022 is a reply to message #46846] |
Thu, 03 June 2004 06:05  |
I think the answer is complexType.getAttributeUses(). The documentation
really needs some improvement.
Thank you for reading, anyway.
Mike
www.soft-gems.net
| Re: Inherited attributes [message #588035 is a reply to message #46876] |
Thu, 03 June 2004 06:52  |
Mike,
I see you figured this out in 8 minutes. Probably you read the Javadoc to look
> Mike
> www.soft-gems.net
| Re: Inherited attributes [message #588108 is a reply to message #46903] |
Thu, 03 June 2004 13:59  |
to look
Mike
www.soft-gems.net
| Re: Inherited attributes [message #588119 is a reply to message #47085] |
Mike,
are "concrete").
Mike Lischke wrote:
> to look
> Mike
> www.soft-gems.net
| Re: Inherited attributes [message #588164 is a reply to message #47113] |
Fri, 04 June 2004 06:44  |
> content model.
This does not work. I used this code:
XSDComplexTypeContent content = complexType.getContentType();
if (content instanceof XSDParticle)
XSDParticle contentParticle = (XSDParticle) content;
XSDModelGroup group = (XSDModelGroup) contentParticle.getTerm();
compositor = group.getCompositor().getValue();
EList xsdParticles = group.getContents();
Iterator iterator = xsdParticles.iterator();
XSDParticle xsdParticle = (XSDParticle) iterator.next();
XMLParticle particle = new XMLParticle(this, xsdParticle);
particles.add(particle);
and do not get *any* particle for a complex type like:
<xs:complexType name="controlType_combobox">
<xs:complexContent>
<xs:extension base="controlType_text_focusable">
<xs:sequence>
<xs:element name="itemlist" minOccurs="0">
<xs:complexType>
<xs:choice>
<xs:element ref="datasource"/>
<xs:sequence>
<xs:element name="key" type="datasourceType"/>
<xs:element name="value" type="datasourceType"/>
</xs:sequence>
</xs:choice>
<xs:attribute name="rows" type="xs:positiveInteger"/>
</xs:complexType>
</xs:element>
</xs:sequence>
</xs:extension>
</xs:complexType>
while the recursive approach collects all particles correctly.
> are "concrete").
This is interesting information. I thought already it must have been
something along this line but didn't bring this thought to an end. It is
generally difficult for me to find time to dive into theoretic stuff like
the info set model or any formal description. I have to learn the matter
while I'm writing products.
Thank you very much.
Mike
www.soft-gems.net
| Re: Inherited attributes [message #588176 is a reply to message #47217] |
Fri, 04 June 2004 07:11  |
Mike,
XSDModelGroup.getContents is a concrete property and you are calling it on a
synthesized model group that does not populate that property. That model group
acts as a logical parent for the local content model and the inherited content
model. Use XSDModelGroup.getParticles, which is the infoset property.
> > content model.
> <xs:complexContent>
> <xs:sequence>
> <xs:complexType>
> <xs:choice>
> <xs:sequence>
> </xs:sequence>
> </xs:choice>
> </xs:complexType>
> </xs:element>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> > are "concrete").
> Mike
> www.soft-gems.net
| Re: Inherited attributes [message #588187 is a reply to message #47235] |
Fri, 04 June 2004 14:40  |
Mike
www.soft-gems.net
| Re: Inherited attributes [message #588199 is a reply to message #47265] |
Mike,
> Mike
> www.soft-gems.net
FUDForum. Page generated in 1.05176 seconds
