Home » Modeling » TMF (Xtext) » [XText] Attaching a behavioral extension
[XText] Attaching a behavioral extension [message #46734] Sun, 31 May 2009 12:53 Go to next message
Hi guys,
I'm currently trying to add a behavioral extension implemented using a
content adapter to a model managed by XText.
I already managed to achieve it in an EMF.Edit generated editor and I'm
looking around the TMF XText generated editor to find a place where to
attach my adaptor.
I would be most greatfull if you could point me to the right place in
the generated code.
Kind Regards,
Cédric Vidal
PS: I'm using TMF Xtext 0.7RC2 bundle from Itemis
http://oaw.itemis.com/openarchitectureware/language=en/2837/ downloads
Re: [XText] Attaching a behavioral extension [message #46769 is a reply to message #46734] Sun, 31 May 2009 17:08 Go to previous messageGo to next message
Ok,
I found out the following solution. I subclassed XtextEditor:
public class MyXtextEditor extends XtextEditor {
public void createPartControl(Composite parent) {
super.createPartControl(parent);
IXtextDocument document = getDocument();
document.modify(new IUnitOfWork<Object, XtextResource>() {
public Object exec(XtextResource resource) throws Exception {
attachBehavior(resource);
return null;
document.addModelListener(new IXtextModelListener() {
public void modelChanged(XtextResource resource) {
private void attachBehavior(XtextResource resource) {
// attach adaptor
and changed plugin.xml editor configuration to use mine instead of
default XtextEditor.
So far it works for me.
Kind regards,
Cédric
Cédric Vidal a écrit :
> Hi guys,
> attach my adaptor.
> the generated code.
> Kind Regards,
> Cédric Vidal
Re: [XText] Attaching a behavioral extension [message #46857 is a reply to message #46769] Mon, 01 June 2009 15:35 Go to previous messageGo to next message
As the editor usually is created by guice, there might be some component
declaring a dependency on XtextEditor. You should change the
configuration in the ui module instead of changing the contents of
plugin.xml. We might inject the editor somewhere else.
To do so add a binding like this:
public class MyLanguageUiModule extends AbstractMyLanguageUiModule {
public Class<? extends XtextEditor> bindEditor() {
return MySpecialEditor.class;
Sven
Cédric Vidal schrieb:
> Ok,
> @Override
> @Override
> return null;
> @Override
> // attach adaptor
> Kind regards,
> Cédric
>> Hi guys,
>> I'm looking around the TMF XText generated editor to find a place
>> where to attach my adaptor.
>> the generated code.
>> Kind Regards,
>> Cédric Vidal
Re: [XText] Attaching a behavioral extension [message #49016 is a reply to message #46857] Sun, 07 June 2009 11:33 Go to previous message
Hi Sven,
Thanx for the correction. I'll try that as soon as I get the chance.
Cédric
> Cheers,
> Sven
>> Ok,
>> @Override
>> @Override
>> return null;
>> @Override
>> // attach adaptor
>> Kind regards,
>> Cédric
>>> Hi guys,
>>> a content adapter to a model managed by XText.
>>> the generated code.
>>> Kind Regards,
>>> Cédric Vidal
Previous Topic:Using the EMF classes and from a new plugin
Next Topic:[XText] Attaching a behavioral extension in a non intrusive way
Current Time: Sun Nov 09 06:55:51 EST 2025
Powered by FUDForum. Page generated in 0.03984 seconds
